1969 Daytona 727 transmission
#2722366
12/07/19 06:27 PM
12/07/19 06:27 PM
Posts: 1,058 Dallas, Texas
FC7cuda
Dallas, Texas
This transmission was removed from a 69 Daytona back in 1972 by the current owner. It has a Feb. date on it but was not VIN stamped?? Is it possible this is/was the original transmission or is the lack of partial VIN mean it’s a warranty replacement?
68 Charger 70 Cuda
Re: 1969 Daytona 727 transmission
[Re: Morty426]
#2722460
12/08/19 07:49 AM
12/08/19 07:49 AM
Posts: 2,655 western PA
mopar4ya
western PA
Not likely to be the original but might be a warranty replacement
2/3/69 on the date
How is the date determined ?
[Re: NANKET]
#2722468
12/08/19 09:09 AM
12/08/19 09:09 AM
Posts: 6,407 Abilene, Texas
fastmark
Abilene, Texas
A trans stamped like that came from a car on the assembly line. They just forgot the VIN. That’s not a replacement trans. What brings you to that conclusion? Those numbers had to do with application, date they were built and unit built. Then they were put in inventory to be installed. If they were not installed, they then stayed in inventory as excess parts. My question was the motor stamped or not? May have missed them both. What’s the SPD of the car? What are the dates stamped on other parts. Start digging, Tom. Lol.
[Re: mopar4ya]
#2722478
12/08/19 10:03 AM
12/08/19 10:03 AM
Posts: 43,560 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
2/3/69 on the date
How is the date determined ? 10,000 day calendar the second set of numbers on the trans.
JB Rhinehart, Realist
A-Body's RULE!
[Re: Rhinodart]
#2722508
12/08/19 12:09 PM
12/08/19 12:09 PM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
2/3/69 on the date
How is the date determined ? 10,000 day calendar the second set of numbers on the trans. Yep 2747 is from the 10000 calendar that they used.
[Re: fastmark]
#2722509
12/08/19 12:11 PM
12/08/19 12:11 PM
Morty426
Sacramento CA
A trans stamped like that came from a car on the assembly line. They just forgot the VIN. That’s not a replacement trans. What brings you to that conclusion? Those numbers had to do with application, date they were built and unit built. Then they were put in inventory to be installed. If they were not installed, they then stayed in inventory as excess parts. My question was the motor stamped or not? May have missed them both. What’s the SPD of the car? What are the dates stamped on other parts. Start digging, Tom. Lol. I have a 671 70 transmission and it is like this one with no VIN. I think it is an early field replacement
[Re: NANKET]
#2722522
12/08/19 12:46 PM
12/08/19 12:46 PM
Posts: 25,827 Rio Linda, CA
John_Kunkel
Rio Linda, CA
A trans stamped like that came from a car on the assembly line. They just forgot the VIN. That’s not a replacement trans. Elaborate.
[Re: JDMopar]
#2723214
12/11/19 12:07 PM
12/11/19 12:07 PM
FC7cuda
Dallas, Texas
Did you look on the top edge of the bellhousing? I had a numbers matching 69 Charger R/T that had the engine and trans vin stamped on the top of the flanges of the motor and transmission. Both the motor, and transmission had the full VIN stamped on them, and they were right next to each other on the flanges. Similar to what was common in 68? I don't recall seeing any number there, but will confirm again tonight. As far as any VIN numbers on the block, I will be checking with the owner but will not have answer till January at best. Thanks
68 Charger 70 Cuda
[Re: FC7cuda]
#2723283
12/11/19 05:02 PM
12/11/19 05:02 PM
Morty426
Sacramento CA
Did you look on the top edge of the bellhousing? I had a numbers matching 69 Charger R/T that had the engine and trans vin stamped on the top of the flanges of the motor and transmission. Both the motor, and transmission had the full VIN stamped on them, and they were right next to each other on the flanges. Similar to what was common in 68? I don't recall seeing any number there, but will confirm again tonight. As far as any VIN numbers on the block, I will be checking with the owner but will not have answer till January at best. Thanks If that was done in early 69 that would have been a mistake.
[Re: Morty426]
#2723428
12/12/19 11:41 AM
12/12/19 11:41 AM
FC7cuda
Dallas, Texas
Did you look on the top edge of the bellhousing? I had a numbers matching 69 Charger R/T that had the engine and trans vin stamped on the top of the flanges of the motor and transmission. Both the motor, and transmission had the full VIN stamped on them, and they were right next to each other on the flanges. Similar to what was common in 68? I don't recall seeing any number there, but will confirm again tonight. As far as any VIN numbers on the block, I will be checking with the owner but will not have answer till January at best. Thanks If that was done in early 69 that would have been a mistake. anomaly yes, mistake no.
68 Charger 70 Cuda
[Re: FC7cuda]
#2724418
12/16/19 10:49 AM
12/16/19 10:49 AM
Posts: 8,489 Candler,NC / Myrtle Beach, SC
JDMopar
I sold that car to a Moparts member in the early 2000's, but I don't remember who? I wish I had taken pics of the VIN stamps, because I remember thinking it was odd. The car was F8 green, and IIRC, it went to Minnesnowda.
