1969 Daytona 727 transmission #2722366
12/07/19 06:27 PM
12/07/19 06:27 PM
Dallas, Texas
FC7cuda Offline OP
FC7cuda  Offline OP
Dallas, Texas
This transmission was removed from a 69 Daytona back in 1972 by the current owner. It has a Feb. date on it but was not VIN stamped?? Is it possible this is/was the original transmission or is the lack of partial VIN mean it’s a warranty replacement?
68 Charger
70 Cuda
Re: 1969 Daytona 727 transmission [Re: FC7cuda] #2722447
12/08/19 12:57 AM
12/08/19 12:57 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Not likely to be the original but might be a warranty replacement
2/3/69 on the date
Re: 1969 Daytona 727 transmission [Re: Morty426] #2722453
12/08/19 01:40 AM
12/08/19 01:40 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
A trans stamped like that came from a car on the assembly line. They just forgot the VIN. That’s not a replacement trans.
Re: 1969 Daytona 727 transmission [Re: Morty426] #2722460
12/08/19 07:49 AM
12/08/19 07:49 AM
western PA
mopar4ya Offline
mopar4ya  Offline
western PA
2/3/69 on the date
How is the date determined ?
Re: 1969 Daytona 727 transmission [Re: NANKET] #2722468
12/08/19 09:09 AM
12/08/19 09:09 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
What brings you to that conclusion? Those numbers had to do with application, date they were built and unit built. Then they were put in inventory to be installed. If they were not installed, they then stayed in inventory as excess parts.
My question was the motor stamped or not? May have missed them both. What’s the SPD of the car? What are the dates stamped on other parts. Start digging, Tom. Lol.
Re: 1969 Daytona 727 transmission [Re: mopar4ya] #2722478
12/08/19 10:03 AM
12/08/19 10:03 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
2/3/69 on the date
10,000 day calendar the second set of numbers on the trans.
JB Rhinehart, Realist
A-Body's RULE!
Re: 1969 Daytona 727 transmission [Re: Rhinodart] #2722508
12/08/19 12:09 PM
12/08/19 12:09 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
2/3/69 on the date
Yep 2747 is from the 10000 calendar that they used.
Re: 1969 Daytona 727 transmission [Re: fastmark] #2722509
12/08/19 12:11 PM
12/08/19 12:11 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
I have a 671 70 transmission and it is like this one with no VIN.
I think it is an early field replacement
Re: 1969 Daytona 727 transmission [Re: NANKET] #2722522
12/08/19 12:46 PM
12/08/19 12:46 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Elaborate.
Re: 1969 Daytona 727 transmission [Re: Morty426] #2722856
12/10/19 12:48 AM
12/10/19 12:48 AM
none
The Black Car Offline
none
I’ve got a 672 trans no VIN...I always assumed it was a warranty replacement.
I also have a 727 H/D, 4-planetary unit with Nothing stamped on it ANYWHERE. Only casting dates, but that’s in a one off executive Imperial Limousine.
Re: 1969 Daytona 727 transmission [Re: The Black Car] #2722876
12/10/19 07:04 AM
12/10/19 07:04 AM
A727Tflite Offline
A727Tflite  Offline
No number on the pan rail means it got a new case,
The plant would not ship a trans assembly without numbers on the pan rail.
Re: 1969 Daytona 727 transmission [Re: FC7cuda] #2723071
12/10/19 08:02 PM
12/10/19 08:02 PM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
Did you look on the top edge of the bellhousing? scope I had a numbers matching 69 Charger R/T that had the engine and trans vin stamped on the top of the flanges of the motor and transmission. Both the motor, and transmission had the full VIN stamped on them, and they were right next to each other on the flanges.
Re: 1969 Daytona 727 transmission [Re: JDMopar] #2723214
12/11/19 12:07 PM
12/11/19 12:07 PM
Dallas, Texas
FC7cuda Offline OP
FC7cuda  Offline OP
Dallas, Texas
Similar to what was common in 68? I don't recall seeing any number there, but will confirm again tonight.
As far as any VIN numbers on the block, I will be checking with the owner but will not have answer till January at best.
68 Charger
70 Cuda
Re: 1969 Daytona 727 transmission [Re: FC7cuda] #2723283
12/11/19 05:02 PM
12/11/19 05:02 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
If that was done in early 69 that would have been a mistake.
Re: 1969 Daytona 727 transmission [Re: Morty426] #2723428
12/12/19 11:41 AM
12/12/19 11:41 AM
Dallas, Texas
FC7cuda Offline OP
FC7cuda  Offline OP
Dallas, Texas
anomaly yes, mistake no.
68 Charger
70 Cuda
Re: 1969 Daytona 727 transmission [Re: FC7cuda] #2724418
12/16/19 10:49 AM
12/16/19 10:49 AM
JDMopar Offline
JDMopar  Offline
I sold that car to a Moparts member in the early 2000's, but I don't remember who? I wish I had taken pics of the VIN stamps, because I remember thinking it was odd. The car was F8 green, and IIRC, it went to Minnesnowda.
