Help!! Going crazy[ier] w/318
#271988
03/30/09 08:54 PM
03/30/09 08:54 PM
Posts: 12,812 Tulsa, Oklahoma
Wagonmaster
Tulsa, Oklahoma
Ok, here's the deal.
I have vehicle with a '71 318 BBD carbed engine. Granny-gear 4-speed. Through 1st and 2nd, it pulls like a freight train up to about 4K RPM. I don't like turning it tighter than that.
Go into 3rd or 4th, at around 2,500 - 2,600 it falls flat on its face.
Here's what I have done to date:
Fresh distriutor Fresh plug wires Fresh plugs. The ballast tests good. Haven't tested the coil, yet, but it has been great, it is an MSD blaster.
What's next? I need to make this rig dependable! It is my driver!
Re: Help!! Going crazy[ier] w/318
[Re: RapidRobert]
#271991
03/30/09 10:58 PM
03/30/09 10:58 PM
Posts: 15,481 the boonies
aarcuda
the boonies
Take off the gas line from the pump inlet & plug it. hookup a can of gas to the fuel pump inlet & take her out.
wouldnt 2400 rpm in 1st or 2nd use the same amount of gas as it would in 3rd at the same rpm (or there abouts)
[Re: aarcuda]
#271993
03/30/09 11:10 PM
03/30/09 11:10 PM
Posts: 5,161 CT
GTX MATT
CT
Whats the timing at? When you set the initial were you sure to disconnect the vacuum advance?
[Re: aarcuda]
#271994
03/30/09 11:10 PM
03/30/09 11:10 PM
RapidRobert
Correct but a partly plugged sock for instance will alot times not end up finally starving it out until you're into 3rd gear & the delivery cant keep up.
[Re: RapidRobert]
#271995
03/30/09 11:18 PM
03/30/09 11:18 PM
Posts: 9,099 Rogue River, OR
Jeremiah
Rogue River, OR
