Help!! Going crazy[ier] w/318 #271988
03/30/09 08:54 PM
03/30/09 08:54 PM
Tulsa, Oklahoma
Wagonmaster Offline OP
Tulsa, Oklahoma
Ok, here's the deal.
I have vehicle with a '71 318 BBD carbed engine. Granny-gear 4-speed. Through 1st and 2nd, it pulls like a freight train up to about 4K RPM. I don't like turning it tighter than that.
Go into 3rd or 4th, at around 2,500 - 2,600 it falls flat on its face.
Here's what I have done to date:
Fresh distriutor
Fresh plug wires
Fresh plugs.
The ballast tests good.
Haven't tested the coil, yet, but it has been great, it is an MSD blaster.
What's next? I need to make this rig dependable! It is my driver!
Re: Help!! Going crazy[ier] w/318 [Re: Wagonmaster] #271989
03/30/09 10:08 PM
03/30/09 10:08 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
what hapens when you try and start out in 3rd.
the only thing i could think of is the tranny is messed up
Re: Help!! Going crazy[ier] w/318 [Re: Wagonmaster] #271990
03/30/09 10:48 PM
03/30/09 10:48 PM
Take off the gas line from the pump inlet & plug it. hookup a can of gas to the fuel pump inlet & take her out.
Re: Help!! Going crazy[ier] w/318 [Re: RapidRobert] #271991
03/30/09 10:58 PM
03/30/09 10:58 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
wouldnt 2400 rpm in 1st or 2nd use the same amount of gas as it would in 3rd at the same rpm (or there abouts)
Re: Help!! Going crazy[ier] w/318 [Re: aarcuda] #271992
03/30/09 11:09 PM
03/30/09 11:09 PM
Florida STAYcation
dOc ! Online penguin-006
The village idiot's idiot
dOc !  Online Penguin-006
Florida STAYcation
IF you are running-it-through the gears .... you could be running out of fuel pressure.
Put a fuel pressure gauge on it.
Now if it is NOT THAT .... see if the exh heat crossover is plugged in the intake manifold. Your choke could be closing.
Re: Help!! Going crazy[ier] w/318 [Re: aarcuda] #271993
03/30/09 11:10 PM
03/30/09 11:10 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Whats the timing at? When you set the initial were you sure to disconnect the vacuum advance?
Re: Help!! Going crazy[ier] w/318 [Re: aarcuda] #271994
03/30/09 11:10 PM
03/30/09 11:10 PM
Correct but a partly plugged sock for instance will alot times not end up finally starving it out until you're into 3rd gear & the delivery cant keep up.
Re: Help!! Going crazy[ier] w/318 [Re: RapidRobert] #271995
03/30/09 11:18 PM
03/30/09 11:18 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Re: Help!! Going crazy[ier] w/318 [Re: Jeremiah] #271996
04/01/09 11:48 AM
04/01/09 11:48 AM
Tulsa, Oklahoma
Tulsa, Oklahoma
Well, problem solved. Back to school for me...
Dooh...fuel filter.
The other stuff didn't hurt - hadn't had the plugs changed in 12 years.
