46RH and 46RE Cases #2636622
03/24/19 08:25 PM
03/24/19 08:25 PM
AZ
Mike P Offline OP
Mike P  Offline OP
AZ
It's probably been asked before but I can't seem to find the answer.
Are 46RE and 46RH cases interchangeable?
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold
1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold
1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears)
Re: 46RH and 46RE Cases [Re: Mike P] #2636722
03/24/19 11:21 PM
03/24/19 11:21 PM
A727Tflite Offline
A727Tflite  Offline
RE cases have a round plug behind the manual shaft lever where the RH has an oblong plug.
You need a control module to run the RE where the RH can use a simple switch to control overdrive ( and lockup if so equipped ).
Re: 46RH and 46RE Cases [Re: A727Tflite] #2636820
03/25/19 09:10 AM
03/25/19 09:10 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
CRT John Cope has a manual valve body for the RE & RH
Re: 46RH and 46RE Cases [Re: CSK] #2636892
03/25/19 10:33 AM
03/25/19 10:33 AM
moparx Offline
moparx  Offline
i'm sure a guy can get the oblong plug for the RH, but i don't remember where. i didn't see it on cope's site.
any help fo this dum old guy ? TIA !
beer
Re: 46RH and 46RE Cases [Re: moparx] #2636921
03/25/19 11:39 AM
03/25/19 11:39 AM
Guitar Jones Offline
Actually both plugs are round where they go through the case but I believe the RE plug is larger so there is a bigger hole there.
Re: 46RH and 46RE Cases [Re: moparx] #2636925
03/25/19 11:56 AM
03/25/19 11:56 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
beer
https://board.moparts.org/ubbthread...e-race-only-trans-brake.html#Post2578239
he has street versions also, they fit 518,46,47,48 rh & re
Re: 46RH and 46RE Cases [Re: CSK] #2636986
03/25/19 02:15 PM
03/25/19 02:15 PM
A727Tflite Offline
A727Tflite  Offline
The “plug” is round on the RE versus the oval “plug” for the RH. The plug is the external connector or female which attaches to the solenoid connector
The body for the solenoid “connector or male end” in the case is round in both applications.
RE is about 1.980” where the RH is about .920”.
Re: 46RH and 46RE Cases [Re: A727Tflite] #2637424
03/26/19 04:47 PM
03/26/19 04:47 PM
AZ
Mike P Offline OP
Mike P  Offline OP
AZ
Thanks everybody. My question was actually whether the cases themselves interchange. I'm looking into having another 46RH built and my trans guy can come up with all the parts except a good 46RH case.
Re: 46RH and 46RE Cases [Re: Mike P] #2637447
03/26/19 06:08 PM
03/26/19 06:08 PM
A727Tflite Offline
A727Tflite  Offline
The cases are interchangeable. The overdrive piston support differs between the RE and RH but that is a bolt in.
If you have a RE I guess you could have a sleeve (reducer) made that would allow the RH connector to fit the RE case.
Stay away from the real late RE case as they have E-PRNDL instead of the normal N/S switch. It looks like a box instead of the normal looking switch.
