46RH and 46RE Cases
#2636622
03/24/19 08:25 PM
03/24/19 08:25 PM
Posts: 1,511 AZ
Mike P
AZ
It's probably been asked before but I can't seem to find the answer.
Are 46RE and 46RH cases interchangeable?
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold 1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold 1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears)
Re: 46RH and 46RE Cases
[Re: A727Tflite]
#2636820
03/25/19 09:10 AM
03/25/19 09:10 AM
Posts: 2,864 Pattison Texas
CSK
Pattison Texas
RE cases have a round plug behind the manual shaft lever where the RH has an oblong plug.
You need a control module to run the RE where the RH can use a simple switch to control overdrive ( and lockup if so equipped ). CRT John Cope has a manual valve body for the RE & RH
[Re: moparx]
#2636921
03/25/19 11:39 AM
03/25/19 11:39 AM
Guitar Jones
Actually both plugs are round where they go through the case but I believe the RE plug is larger so there is a bigger hole there.
[Re: moparx]
#2636925
03/25/19 11:56 AM
03/25/19 11:56 AM
CSK
Pattison Texas
i'm sure a guy can get the oblong plug for the RH, but i don't remember where. i didn't see it on cope's site. any help fo this dum old guy ? TIA ! https://board.moparts.org/ubbthread...e-race-only-trans-brake.html#Post2578239he has street versions also, they fit 518,46,47,48 rh & re
[Re: CSK]
#2636986
03/25/19 02:15 PM
03/25/19 02:15 PM
Posts: 3,083 Michigan
A727Tflite
The “plug” is round on the RE versus the oval “plug” for the RH. The plug is the external connector or female which attaches to the solenoid connector
The body for the solenoid “connector or male end” in the case is round in both applications.
RE is about 1.980” where the RH is about .920”.
[Re: A727Tflite]
#2637424
03/26/19 04:47 PM
03/26/19 04:47 PM
Posts: 1,511 AZ
Mike P
AZ
Thanks everybody. My question was actually whether the cases themselves interchange. I'm looking into having another 46RH built and my trans guy can come up with all the parts except a good 46RH case.
