Re: hard brake pedal and cant get the back brakes to bleed. [Re: mopar muscle7271] #2627573
03/01/19 03:38 PM
03/01/19 03:38 PM
Spring City , Pa.
SIKPUP Offline
SIKPUP  Offline
Spring City , Pa.
I had a time where the front brakes worked so well that it didnt allow enough pedal travel to push the fluid to the rear.
Re: hard brake pedal and cant get the back brakes to bleed. [Re: SIKPUP] #2627578
03/01/19 04:05 PM
03/01/19 04:05 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
what you had was a misadjusted master cylinder pushrod or bad mc. The situation you described should not happen.
Re: hard brake pedal and cant get the back brakes to bleed. [Re: mopar muscle7271] #2628225
03/03/19 12:51 PM
03/03/19 12:51 PM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
I had the same type of issue on a rebuilt mc from advanced auto. There are two Pistons separated inside by a spring. The spring keeps the spacing between the Pistons the correct distance, but with mine the Pistons were chewed up and would stick and not allow the spring to correct the spacing. So it would just block one port and allow no pressure out. Felt just like you put plugs in the ports. ROCK hard.
best of 11.39 at 117 mph 1.60 60’. 68 340 S Barracuda Fastback F.A.S.T [IMG]http://i67.tinypic.com/2mnnnnt.jpg[/IMG]
Re: hard brake pedal and cant get the back brakes to bleed. [Re: mopar muscle7271] #2628761
03/04/19 05:05 PM
03/04/19 05:05 PM
las vegas,nv
mopar muscle7271 Offline OP
las vegas,nv
Well got i no fluid what so ever goin to back of car.i started at m/c took lines off there and pump the pedal and fluid was squirtin out of both ports on master cylinder.unscrew the line that goes to back to supply fluid and nothing.
Re: hard brake pedal and cant get the back brakes to bleed. [Re: Supercuda] #2628817
03/04/19 07:09 PM
03/04/19 07:09 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Originally Posted By Supercuda
sounds like the safety shuttle is tripped.
I reiterate
Don't be the exception.
Re: hard brake pedal and cant get the back brakes to bleed. [Re: Supercuda] #2628821
03/04/19 07:17 PM
03/04/19 07:17 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
I reiterate
And I agree with the reiteration................
Re: hard brake pedal and cant get the back brakes to bleed. [Re: mopar muscle7271] #2628890
03/04/19 10:39 PM
03/04/19 10:39 PM
las vegas,nv
las vegas,nv
How do you fix that?
Re: hard brake pedal and cant get the back brakes to bleed. [Re: mopar muscle7271] #2628894
03/04/19 10:55 PM
03/04/19 10:55 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
For 71 the FSM says to replace the valve. 73 and later have an external plunger nub you can reset it with.
I would take it apart, clean it recenter it and reseal it.
I suppose you could pull the switch and try to recenter the shuttle thru that port.
Re: hard brake pedal and cant get the back brakes to bleed. [Re: Supercuda] #2628966
03/05/19 01:40 AM
03/05/19 01:40 AM
with the valve been shifted over to the low psi side, with that corrected iirc there was something about slightly opening the high side making it now the low side & bumping the pedal to shift the valve back the other way to center it. Not sure how holding the "pin" valve open plays out with this procedure but others will clarify. I always thought the center valve was strickly an electrical on/off switch (to warn you of a leak on the "low" side) but did not shutoff flow so I learned something on this.
Re: hard brake pedal and cant get the back brakes to bleed. [Re: Supercuda] #2629156
03/05/19 02:16 PM
03/05/19 02:16 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
If nothing comes out of the M/C that is your issue.
Kinda why I would start at the master.
1st, being you didn't install it, are you sure it is the proper unit?
I have mechanical Aptitude.
I can screw up anything.
Re: hard brake pedal and cant get the back brakes to bleed. [Re: RapidRobert] #2629184
03/05/19 02:42 PM
03/05/19 02:42 PM
Mass
charge70 Offline
charge70  Offline
Mass
I believe to reset the valve the electrical switch must be removed.Open a bleeder on the brake circuit that works and have someone push the pedal down.If the shuffle valve is not jammed or or stuck that should re-center the valve.Install the switch and everything should bleed normally.
1970 Dodge Charger R/T S.E. 1969 Dodge Dart GTS 440 M-Code 1970 Dodge Charger 500 383/4-speed w/A.C.
Re: hard brake pedal and cant get the back brakes to bleed. [Re: charge70] #2629188
03/05/19 02:46 PM
03/05/19 02:46 PM
^^^ noted
Re: hard brake pedal and cant get the back brakes to bleed. [Re: bboogieart] #2629199
03/05/19 03:16 PM
03/05/19 03:16 PM
las vegas,nv
las vegas,nv
If you know to read thats what I did.
Re: hard brake pedal and cant get the back brakes to bleed. [Re: mopar muscle7271] #2629859
03/07/19 04:44 AM
03/07/19 04:44 AM
las vegas,nv
las vegas,nv
I notice fluid was leakin where the safety trip is.i tried to spray brake cleaner on of the rear ports of portioning valve to see if it would shoot out to the oher side of rear portioning valve hole it didnt.looks like its clogged or jammed up.
Re: hard brake pedal and cant get the back brakes to bleed. [Re: mopar muscle7271] #2634605
03/19/19 09:37 PM
03/19/19 09:37 PM
las vegas,nv
las vegas,nv
Are the inline tube portioning valves any good? I ended up orderin one form them.
Re: hard brake pedal and cant get the back brakes to bleed. [Re: mopar muscle7271] #2634614
03/19/19 09:48 PM
03/19/19 09:48 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Never used their stuff.
I always grabbed one out of a Diplomat, just match the rear drum sizing.
Re: hard brake pedal and cant get the back brakes to bleed. [Re: Supercuda] #2634787
03/20/19 12:00 PM
03/20/19 12:00 PM
Colorado front range
BcudaChris Offline
BcudaChris  Offline
That combination valve is fairly easy to re-seal. I've since ditched it but if I recall correctly, just a teflon and a couple of o-rings I sourced from a hydraulic shop. Off the shelf stuff, at least in the 90's. As long as the housing and shuttle aren't dinged or pitted...
Re: hard brake pedal and cant get the back brakes to bleed. [Re: BcudaChris] #2649704
04/27/19 10:39 PM
04/27/19 10:39 PM
middle Tennessee
mopower440 Offline
mopower440  Offline
middle Tennessee
I need to re-set my prop valve i believe..How did you go about doing this? I 'think' its not letting fluid to the rears..
Re: hard brake pedal and cant get the back brakes to bleed. [Re: mopower440] #2649711
04/27/19 10:52 PM
04/27/19 10:52 PM
Just thinking out loud & someone may clarify better if this ain't right. I would crack the line slightly (a bit downstream from the prop valve) on the side that was not opened/leaking & pump the pedal (fast/brief) (till the light goes out) to shift the valve back the other way to centered.
