I had the same type of issue on a rebuilt mc from advanced auto. There are two Pistons separated inside by a spring. The spring keeps the spacing between the Pistons the correct distance, but with mine the Pistons were chewed up and would stick and not allow the spring to correct the spacing. So it would just block one port and allow no pressure out. Felt just like you put plugs in the ports. ROCK hard.
