thick torsion bar grease #2570319
10/27/18 07:26 PM
10/27/18 07:26 PM
md
mopars4ever Online content OP
mopars4ever  Online Content OP
md
Who sells the thick grease that is used on the torsion bar end. Does mopar still sell it? if not what brand to use?
Re: thick torsion bar grease [Re: mopars4ever] #2570325
10/27/18 07:43 PM
10/27/18 07:43 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The original stuff was long-strand fibrous grease but grease has come a long way so I'd use a synthetic like Green Grease.
Re: thick torsion bar grease [Re: mopars4ever] #2570395
10/27/18 10:28 PM
10/27/18 10:28 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Mopar Multi mile cassis from the dealer.
Re: thick torsion bar grease [Re: 71birdJ68] #2570425
10/28/18 12:06 AM
10/28/18 12:06 AM
Use whatever grease you have on hand. Not a critical (special need) area, as far as I can tell.
Re: thick torsion bar grease [Re: mopars4ever] #2570468
10/28/18 03:00 AM
10/28/18 03:00 AM
AndyF Offline
AndyF  Offline
I agree, any grease or grease like substance should work. I doubt there are any torsion bar cars that get driven a lot of miles in bad weather anymore so the grease probably isn't even a requirement. I have only a very thin film of high pressure grease on the bars in my Coronet. I pull the bars out at least once a year for some reason or another and I don't drive the car more than 1000 miles a year so the grease hardly even knows it has a job to do.
Re: thick torsion bar grease [Re: mopars4ever] #2570541
10/28/18 11:52 AM
10/28/18 11:52 AM
md
md
I would have preferred the original type grease. Amalie has a #4 grease that seems to be close to what I wanted but I don`t want to pay $45 plus for a small tub of it and not need it again. I really just want something that doesn`t leak and drip oils like some grease does. It is for a transverse torsion bar which seems to use some more grease then the older straight t bars.
Re: thick torsion bar grease [Re: mopars4ever] #2570615
10/28/18 03:28 PM
10/28/18 03:28 PM
AndyF Offline
AndyF  Offline
Is it a daily driver or just a fair weather cruiser? If it is a daily driver then I'd pack it full of a long fiber chassis grease which you can buy at any parts store. A fair weather cruiser that only gets driven a few times a year I'd just use a light coating of heavy grease.
Re: thick torsion bar grease [Re: mopars4ever] #2570795
10/28/18 11:21 PM
10/28/18 11:21 PM
Maryland
MoparMike1974 Offline
Maryland
Look for "high impact" grease
Re: thick torsion bar grease [Re: RapidRobert] #2570808
10/28/18 11:55 PM
10/28/18 11:55 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I use 100,000 mile grease, or whatever is open on the shelf that is visible. laugh2
You will not live long enough to outlast it.
Re: thick torsion bar grease [Re: mopars4ever] #2570882
10/29/18 10:31 AM
10/29/18 10:31 AM
Torq37 Offline
Torq37  Offline
Seems like all modern greases have a high bleed out rate (drip, drip, drip) I've yet to find one that doesn't
I have a 30 year old can of Lubriplate 930 that doesn't bleed out as much as most so that's what I use when I'm concerned about dripping. It's not lithium base so I only use where I won't be mixing greases.
You might check with a local industrial bearing supplier for recommendations.
Re: thick torsion bar grease [Re: mopars4ever] #2571155
10/29/18 06:53 PM
10/29/18 06:53 PM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
Falk ltg or moible xtc grease
Re: thick torsion bar grease [Re: The Shadow] #2571484
10/30/18 10:23 AM
10/30/18 10:23 AM
Torq37 Offline
Torq37  Offline
Winner. Never heard of this stuff but after looking at data sheets it looks like the perfect solution. Thanks
Re: thick torsion bar grease [Re: Torq37] #2571513
10/30/18 11:32 AM
10/30/18 11:32 AM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Seems like 5th wheel trailer plate grease would work too?
Re: thick torsion bar grease [Re: Neil] #2571632
10/30/18 03:26 PM
10/30/18 03:26 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
So what do you guys think the real purpose(s) the grease serves here on TB's?
Re: thick torsion bar grease [Re: jcc] #2571641
10/30/18 03:46 PM
10/30/18 03:46 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Maybe to keep it from "clicking or Creaking" in there?
Re: thick torsion bar grease [Re: jcc] #2571668
10/30/18 04:24 PM
10/30/18 04:24 PM
I would think rust/keeping water splash out/as said noise/a side bennie- ease of removal (if ever needed). With em normally being in there for life I would think Ma's main thought was "noise" as minimizing customer complaints (to the dealership) might not be #1 but it is for sure close to it.
Re: thick torsion bar grease [Re: jcc] #2571672
10/30/18 04:32 PM
10/30/18 04:32 PM
AndyF Offline
AndyF  Offline
Keeps them from rusting tight and snapping. The bar moves back and forth a little bit during use so if the bars rusted solid then they probably snap. It is a harsh environment for a daily driver. Especially a car in the midwest with salted roads.
Re: thick torsion bar grease [Re: mopars4ever] #2571737
10/30/18 06:58 PM
10/30/18 06:58 PM
A727Tflite Offline
A727Tflite  Offline
Early torsion bar equipped cars regularly broke torsion bars - they went in dry on the assembly line.
The fix was grease.
Was common to see the early ‘57’s dragging the front on one or both sides of the car.
My dad bought one and limped it home, fixed it and he drive it for a couple years without a problem - except the rust starting over the headlight “eye brows”.
Re: thick torsion bar grease [Re: Torq37] #2571772
10/30/18 08:31 PM
10/30/18 08:31 PM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
Wear disposable gloves because it sticks like poo on a baby's blanket
