Re: thick torsion bar grease
[Re: mopars4ever]
#2570325
10/27/18 07:43 PM
10/27/18 07:43 PM
Posts: 25,831 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The original stuff was long-strand fibrous grease but grease has come a long way so I'd use a synthetic like Green Grease.
[Re: 71birdJ68]
#2570425
10/28/18 12:06 AM
10/28/18 12:06 AM
RapidRobert
Use whatever grease you have on hand. Not a critical (special need) area, as far as I can tell.
[Re: RapidRobert]
#2570808
10/28/18 11:55 PM
10/28/18 11:55 PM
Posts: 22,696 Bitopia
jcc
Bitopia
Use whatever grease you have on hand. Not a critical (special need) area, as far as I can tell. I use 100,000 mile grease, or whatever is open on the shelf that is visible. You will not live long enough to outlast it.
[Re: mopars4ever]
#2570882
10/29/18 10:31 AM
10/29/18 10:31 AM
Torq37
I would have preferred the original type grease. Amalie has a #4 grease that seems to be close to what I wanted but I don`t want to pay $45 plus for a small tub of it and not need it again. I really just want something that doesn`t leak and drip oils like some grease does. It is for a transverse torsion bar which seems to use some more grease then the older straight t bars. Seems like all modern greases have a high bleed out rate (drip, drip, drip) I've yet to find one that doesn't I have a 30 year old can of Lubriplate 930 that doesn't bleed out as much as most so that's what I use when I'm concerned about dripping. It's not lithium base so I only use where I won't be mixing greases. You might check with a local industrial bearing supplier for recommendations.
[Re: The Shadow]
#2571484
10/30/18 10:23 AM
10/30/18 10:23 AM
Torq37
Falk ltg or moible xtc grease Winner. Never heard of this stuff but after looking at data sheets it looks like the perfect solution. Thanks
[Re: Neil]
#2571632
10/30/18 03:26 PM
10/30/18 03:26 PM
jcc
Bitopia
So what do you guys think the real purpose(s) the grease serves here on TB's?
[Re: jcc]
#2571668
10/30/18 04:24 PM
10/30/18 04:24 PM
RapidRobert
I would think rust/keeping water splash out/as said noise/a side bennie- ease of removal (if ever needed). With em normally being in there for life I would think Ma's main thought was "noise" as minimizing customer complaints (to the dealership) might not be #1 but it is for sure close to it.
[Re: jcc]
#2571672
10/30/18 04:32 PM
10/30/18 04:32 PM
Posts: 31,044 Oregon
AndyF
So what do you guys think the real purpose(s) the grease serves here on TB's? Keeps them from rusting tight and snapping. The bar moves back and forth a little bit during use so if the bars rusted solid then they probably snap. It is a harsh environment for a daily driver. Especially a car in the midwest with salted roads.
[Re: Torq37]
#2571772
10/30/18 08:31 PM
10/30/18 08:31 PM
Posts: 2,175 Duloc
The Shadow
Duloc
Falk ltg or moible xtc grease Winner. Never heard of this stuff but after looking at data sheets it looks like the perfect solution. Thanks Wear disposable gloves because it sticks like poo on a baby's blanket
