Page 1 of 3 1 2 3
which 426 alum.Hemi Heads to get? #2377802
09/27/17 05:00 PM
09/27/17 05:00 PM
N.Y.
sixpacksteve Offline OP
N.Y.
innovation moves real fast. So i'm looking to get rid of steel heads and get alum ones. mopar ,edelbrock and stage V its for a street strip car.
whats best bang for buck?
Hell Hath No Fury Like Mine
Re: which 426 alum.Hemi Heads to get? [Re: sixpacksteve] #2377807
09/27/17 05:14 PM
09/27/17 05:14 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Edelbrock by far. High flow and low price.
2011 Drag Pak Challenger
Re: which 426 alum.Hemi Heads to get? [Re: sixpacksteve] #2377826
09/27/17 05:42 PM
09/27/17 05:42 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
Are you bracket racing, or heads up? If the ultimate power is most important, Stave V. If the most bang for the $ is important, E-brock
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: which 426 alum.Hemi Heads to get? [Re: sixpacksteve] #2377841
09/27/17 06:15 PM
09/27/17 06:15 PM
North Carolina
469runner Offline
469runner  Offline
North Carolina
Stage V. Looks stock if that is important to you. Can be ported for more flow than Edelbrocks.
Re: which 426 alum.Hemi Heads to get? [Re: 469runner] #2377845
09/27/17 06:21 PM
09/27/17 06:21 PM
Home of the Bluegrass
MoparJunkie Offline
MoparJunkie  Offline
I went with Eddys....
Very pleased with my decision!
"It takes a Mopar to catch a Mopar”
1971 Roadrunner FJ6 Sassy Grass 505"RB, 18 spline 4 speed, and Dana 60 with 3.54
2022 Hellcat Charger Widebody Redeye Jailbreak: Hellraisin with 8 speed auto
Re: which 426 alum.Hemi Heads to get? [Re: sixpacksteve] #2377850
09/27/17 06:28 PM
09/27/17 06:28 PM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
Stage V big valve.
Re: which 426 alum.Hemi Heads to get? [Re: sixpacksteve] #2377874
09/27/17 06:57 PM
09/27/17 06:57 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
edelbrocks Victor jr's will do more than you need for strip street - but piston design can get tricky because of the changed exhaust valve angle. Also edlebrocks need a big bore as they were designed for the 4.5" bore blocks Edlebrock rep recommended a Min. Bore 4.375” - I am guessing they will work on a smaller bore but may require some additional work. My New HEMI is a 572 with the eddies and we will dyno it hopefully next week
Re: which 426 alum.Hemi Heads to get? [Re: sixpacksteve] #2377901
09/27/17 08:02 PM
09/27/17 08:02 PM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
Don't understand what you mean by inaovate moves real fast???? Irion heads will make more power when all things equal.
JAKES AUTOMOTIVE
Re: which 426 alum.Hemi Heads to get? [Re: JAKE68] #2377967
09/27/17 09:47 PM
09/27/17 09:47 PM
N.Y.
N.Y.
the Hemi's have come a long way since the 60's. in the last few, tech is moving faster than ever. more sources than just one.
Re: which 426 alum.Hemi Heads to get? [Re: sixpacksteve] #2377975
09/27/17 09:56 PM
09/27/17 09:56 PM
Taxes & Virus's R-US, NY
Dragula Online content
Dragula  Online Content
For the money, Indy big valve Hi Po Hemi heads....I have the flow numbers. Almost 460cfm if I remember...Call Bob George Racing for pricing.
The Eddy heads, need a specific piston to not have interference issues.
Re: which 426 alum.Hemi Heads to get? [Re: sixpacksteve] #2377988
09/27/17 10:14 PM
09/27/17 10:14 PM
A727Tflite Offline
A727Tflite  Offline
Correct me if I am wrong but the only Edelbrock hemi head needing special piston notching is the latest edelbrock head with the big intake - the exhaust has a different guide angle requiring the special notch. The earlier edelbrock head sold through Mopar Performance ( with conventional valve train oiling ) does NOT need the special exhaust notch.
Re: which 426 alum.Hemi Heads to get? [Re: sixpacksteve] #2378033
09/27/17 11:43 PM
09/27/17 11:43 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Stage V on my 572 ported by FHO
Re: which 426 alum.Hemi Heads to get? [Re: rowin4] #2378091
09/28/17 01:37 AM
09/28/17 01:37 AM
florida dade
cesar perez Offline
cesar perez  Offline
florida dade
rowin what did your heads flow
Re: which 426 alum.Hemi Heads to get? [Re: A727Tflite] #2378170
09/28/17 10:32 AM
09/28/17 10:32 AM
an8sec70cuda Offline
Yes, the Edelbrock Victor Jr. hemi head is the one w/ the different valve angle.
The older Mopar Performance heads that were cast by Edelbrock are all stock style stuff. They just have the Edelbrock "E" cast into them under the valve cover.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: which 426 alum.Hemi Heads to get? [Re: A727Tflite] #2378235
09/28/17 12:52 PM
09/28/17 12:52 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Just because the valve angle is different doesn't mean that you need different pistons, or that it's going to cause you problems, etc. This isn't the 60's. Back then people would shave the heads and deck the block to get more compression. This would give you more compression but would decrease the piston to valve clearance. Most engines that people put together now are strokers. With a stroker you can get all the compression you want. Strokers take a lot less dome on the piston. Your street/strip application will probably be for pump gas and not have much dome. My guess is if you check your valve to piston clearance you will find you have a mile.
When using Victor Jr's you do have to check the intake valve to bore clearance if you are using a small bore.
Re: which 426 alum.Hemi Heads to get? [Re: sixpacksteve] #2378244
09/28/17 12:57 PM
09/28/17 12:57 PM
A727Tflite Offline
A727Tflite  Offline
Rickseeman - agreed on several of your points - a good engine builder will always check piston to head and piston to valve clearance on any engine and on a hemiroid - valve to valve clearance. Takes the worry out of being close - too close.
Re: which 426 alum.Hemi Heads to get? [Re: rickseeman] #2378252
09/28/17 01:10 PM
09/28/17 01:10 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
here are the eddy head specific pistons - these are 13-1 customs
Re: which 426 alum.Hemi Heads to get? [Re: DoubleD] #2378301
09/28/17 02:49 PM
09/28/17 02:49 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I have the regular ole Mopar Performance Crate Hemi heads on my 528". They flowed around 426 as cast on our flow bench but it still made 853/697 with only 10.5:1 on pump gas, so I am happy enough with them for now.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: which 426 alum.Hemi Heads to get? [Re: DoubleD] #2378308
09/28/17 03:11 PM
09/28/17 03:11 PM
Oslo
Cuda 1968 Offline
Cuda 1968  Offline
Oslo
Quality on the E-brock valves, are they good for a.800 + roller cam?
TAS.
Re: which 426 alum.Hemi Heads to get? [Re: DoubleD] #2378319
09/28/17 03:25 PM
09/28/17 03:25 PM
PA
RBRE Offline
RBRE  Offline
PA
The Edelbrock and Stage V Big Valve heads are rolled on the exhaust and even though they are the wrong angle for a standard valve angle head, you will have at lease .100" more piston to valve clearance than a stock head. - Ray
Page 1 of 3 1 2 3
