which 426 alum.Hemi Heads to get?
#2377802
09/27/17 05:00 PM
09/27/17 05:00 PM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
innovation moves real fast. So i'm looking to get rid of steel heads and get alum ones. mopar ,edelbrock and stage V its for a street strip car. whats best bang for buck?
Hell Hath No Fury Like Mine
Re: which 426 alum.Hemi Heads to get?
[Re: sixpacksteve]
#2377826
09/27/17 05:42 PM
09/27/17 05:42 PM
Posts: 7,495 Minnesota
Hemi_Joel
Minnesota
Are you bracket racing, or heads up? If the ultimate power is most important, Stave V. If the most bang for the $ is important, E-brock
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: 469runner]
#2377845
09/27/17 06:21 PM
09/27/17 06:21 PM
Posts: 1,132 Home of the Bluegrass
MoparJunkie
I went with Eddys.... Very pleased with my decision!
"It takes a Mopar to catch a Mopar” 1971 Roadrunner FJ6 Sassy Grass 505"RB, 18 spline 4 speed, and Dana 60 with 3.54 2022 Hellcat Charger Widebody Redeye Jailbreak: Hellraisin with 8 speed auto
[Re: sixpacksteve]
#2377874
09/27/17 06:57 PM
09/27/17 06:57 PM
Posts: 2,299 NE Ohio
DoubleD
NE Ohio
edelbrocks Victor jr's will do more than you need for strip street - but piston design can get tricky because of the changed exhaust valve angle. Also edlebrocks need a big bore as they were designed for the 4.5" bore blocks Edlebrock rep recommended a Min. Bore 4.375” - I am guessing they will work on a smaller bore but may require some additional work. My New HEMI is a 572 with the eddies and we will dyno it hopefully next week
[Re: sixpacksteve]
#2377901
09/27/17 08:02 PM
09/27/17 08:02 PM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
Don't understand what you mean by inaovate moves real fast???? Irion heads will make more power when all things equal.
JAKES AUTOMOTIVE
[Re: JAKE68]
#2377967
09/27/17 09:47 PM
09/27/17 09:47 PM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
the Hemi's have come a long way since the 60's. in the last few, tech is moving faster than ever. more sources than just one.
[Re: sixpacksteve]
#2377975
09/27/17 09:56 PM
09/27/17 09:56 PM
Posts: 12,400 Taxes & Virus's R-US, NY
Dragula
innovation moves real fast. So i'm looking to get rid of steel heads and get alum ones. mopar ,edelbrock and stage V its for a street strip car. whats best bang for buck? For the money, Indy big valve Hi Po Hemi heads....I have the flow numbers. Almost 460cfm if I remember...Call Bob George Racing for pricing. The Eddy heads, need a specific piston to not have interference issues.
[Re: sixpacksteve]
#2377988
09/27/17 10:14 PM
09/27/17 10:14 PM
Posts: 3,089 Michigan
A727Tflite
Correct me if I am wrong but the only Edelbrock hemi head needing special piston notching is the latest edelbrock head with the big intake - the exhaust has a different guide angle requiring the special notch. The earlier edelbrock head sold through Mopar Performance ( with conventional valve train oiling ) does NOT need the special exhaust notch.
[Re: A727Tflite]
#2378170
09/28/17 10:32 AM
09/28/17 10:32 AM
Posts: 13,376 Marion, South Carolina [><]
an8sec70cuda
Correct me if I am wrong but the only Edelbrock hemi head needing special piston notching is the latest edelbrock head with the big intake - the exhaust has a different guide angle requiring the special notch. The earlier edelbrock head sold through Mopar Performance ( with conventional valve train oiling ) does NOT need the special exhaust notch. Yes, the Edelbrock Victor Jr. hemi head is the one w/ the different valve angle. The older Mopar Performance heads that were cast by Edelbrock are all stock style stuff. They just have the Edelbrock "E" cast into them under the valve cover.
[Re: A727Tflite]
#2378235
09/28/17 12:52 PM
09/28/17 12:52 PM
Posts: 2,663 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
Correct me if I am wrong but the only Edelbrock hemi head needing special piston notching is the latest edelbrock head with the big intake - the exhaust has a different guide angle requiring the special notch. The earlier edelbrock head sold through Mopar Performance ( with conventional valve train oiling ) does NOT need the special exhaust notch. Just because the valve angle is different doesn't mean that you need different pistons, or that it's going to cause you problems, etc. This isn't the 60's. Back then people would shave the heads and deck the block to get more compression. This would give you more compression but would decrease the piston to valve clearance. Most engines that people put together now are strokers. With a stroker you can get all the compression you want. Strokers take a lot less dome on the piston. Your street/strip application will probably be for pump gas and not have much dome. My guess is if you check your valve to piston clearance you will find you have a mile. When using Victor Jr's you do have to check the intake valve to bore clearance if you are using a small bore.
2011 Drag Pak Challenger
[Re: DoubleD]
#2378301
09/28/17 02:49 PM
09/28/17 02:49 PM
Posts: 4,575 Motor City
6PKRTSE
Motor City
I have the regular ole Mopar Performance Crate Hemi heads on my 528". They flowed around 426 as cast on our flow bench but it still made 853/697 with only 10.5:1 on pump gas, so I am happy enough with them for now.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: DoubleD]
#2378308
09/28/17 03:11 PM
09/28/17 03:11 PM
Posts: 16 Oslo
Cuda 1968
Oslo
Quality on the E-brock valves, are they good for a.800 + roller cam?
TAS.
