MSD Crank Trigger Sensor Gap Symptoms #2330207
07/02/17 03:16 PM
07/02/17 03:16 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
I just for the first time installed a MSD crank trigger on our dart big block.
Went to the track yesterday for the only the second time this year. 1st outing with a crank trigger and was wondering what would the symptoms be for the wrong gap from the magnet wheel to the sensor?
Let's just say I was at .19-.23 gap. IIRC it should be at around .55-.57. I think the gap was too tight.
Re: MSD Crank Trigger Sensor Gap Symptoms [Re: Sammy] #2330209
07/02/17 03:21 PM
07/02/17 03:21 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Not sure of issues with to tight a gap but the wheel must have the arrow pointed clockwise or it will cause issues.
Re: MSD Crank Trigger Sensor Gap Symptoms [Re: FastmOp] #2330216
07/02/17 03:52 PM
07/02/17 03:52 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Thankyou, arrow is going in the right direction.
Re: MSD Crank Trigger Sensor Gap Symptoms [Re: Sammy] #2330244
07/02/17 05:06 PM
07/02/17 05:06 PM
MR_P_BODY Offline
MR_P_BODY  Offline
On my injection that gap is .040
wave
Re: MSD Crank Trigger Sensor Gap Symptoms [Re: Sammy] #2330247
07/02/17 05:17 PM
07/02/17 05:17 PM
AndyF Offline
AndyF  Offline
Only issue with a tight gap is that the parts might run into each other if the crank flexes a bit. Look at your wheel to see if it is digging into the sensor. If the parts aren't running into each other then leave tight. And your numbers are wrong, you are missing a zero. MSD wants the gap clearance to be 0.050 not 1/2 inch.
Re: MSD Crank Trigger Sensor Gap Symptoms [Re: Sammy] #2330255
07/02/17 05:32 PM
07/02/17 05:32 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Trying to figure out if too tight would cause the engine to stop pulling right around the 1200 foot mark through the traps. Same thing every pass but pulls fine through all the first and second gear but feels like I'm out of throttle pedal. And yes .050 not .50.
Re: MSD Crank Trigger Sensor Gap Symptoms [Re: Sammy] #2330266
07/02/17 05:54 PM
07/02/17 05:54 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
i had mine too close and it rubbed the wheel,moved it out and there was no diff in the way it ran but it probly saved me some future head aches. rolleyes
Re: MSD Crank Trigger Sensor Gap Symptoms [Re: Sammy] #2330399
07/02/17 10:30 PM
07/02/17 10:30 PM
AndyF Offline
AndyF  Offline
No that isn't the trigger wheel. You have a different problem, maybe running out of fuel or some other issue.
Re: MSD Crank Trigger Sensor Gap Symptoms [Re: Sammy] #2330606
07/03/17 12:02 PM
07/03/17 12:02 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
To small an air gap is not going to cause any issue other than possible interference of parts. You might wanna recheck rotor phasing for sure...
Re: MSD Crank Trigger Sensor Gap Symptoms [Re: Al_Alguire] #2331043
07/03/17 10:28 PM
07/03/17 10:28 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
MSD calls out a .050to.080 gap range, I set mine at .060 and forget it, and I am with Al on the rotor phasing.
Re: MSD Crank Trigger Sensor Gap Symptoms [Re: dartman366] #2331047
07/03/17 10:36 PM
07/03/17 10:36 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Going to check again the phasing but I believe I'm dead on with the leading edge.
U just regapped it to .055
Re: MSD Crank Trigger Sensor Gap Symptoms [Re: Sammy] #2331141
07/04/17 02:09 AM
07/04/17 02:09 AM
Mobile Alabama
SB412DUSTER Offline
SB412DUSTER  Offline
Mobile Alabama
if you turn it in till it touches the wheel then turn it out 1 turn it will be .062. the threads are 3/4-16 so 1 turn is 1/16
Re: MSD Crank Trigger Sensor Gap Symptoms [Re: SB412DUSTER] #2331234
07/04/17 11:08 AM
07/04/17 11:08 AM
moparx Offline
moparx  Offline
um, the 16 is 16 threads per inch. one inch will give you the .062 per one turn. to get a "turn" value on thread sizes less than one inch, you divide .750 [the thread size] by 16 [the thread pitch]. that equals .0468[and change] per one turn on a 3/4-16 thread.
beer
Re: MSD Crank Trigger Sensor Gap Symptoms [Re: moparx] #2331242
07/04/17 11:21 AM
07/04/17 11:21 AM
Apollo, PA.
B1MAXX Online content
B1MAXX  Online Content
Apollo, PA.
Fastener Dia. has no effect on threads per inch.
Re: MSD Crank Trigger Sensor Gap Symptoms [Re: B1MAXX] #2331250
07/04/17 11:30 AM
07/04/17 11:30 AM
moparx Offline
moparx  Offline
you are correct ! MY MISTAKE ! blush i was thinking of something else ! please disregard my comment ! ["oldtimers" in action can bite you every time, as this BIT me !]
beer
and i KNOW better ! now i feel like an azz.........
Re: MSD Crank Trigger Sensor Gap Symptoms [Re: moparx] #2331344
07/04/17 01:20 PM
07/04/17 01:20 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
beer
Welcome to Moparts!
[image][/image]
