Re: MSD Crank Trigger Sensor Gap Symptoms
[Re: FastmOp]
#2330216
07/02/17 03:52 PM
07/02/17 03:52 PM
Posts: 1,824 Wind Gap,Pa.
Sammy
Wind Gap,Pa.
Not sure of issues with to tight a gap but the wheel must have the arrow pointed clockwise or it will cause issues. Thankyou, arrow is going in the right direction.
[Re: Sammy]
#2330399
07/02/17 10:30 PM
07/02/17 10:30 PM
Posts: 31,043 Oregon
AndyF
Trying to figure out if too tight would cause the engine to stop pulling right around the 1200 foot mark through the traps. Same thing every pass but pulls fine through all the first and second gear but feels like I'm out of throttle pedal. And yes .050 not .50. No that isn't the trigger wheel. You have a different problem, maybe running out of fuel or some other issue.
[Re: Sammy]
#2330606
07/03/17 12:02 PM
07/03/17 12:02 PM
Posts: 19,367 Las Vegas
Al_Alguire
Las Vegas
To small an air gap is not going to cause any issue other than possible interference of parts. You might wanna recheck rotor phasing for sure...
[Re: Al_Alguire]
#2331043
07/03/17 10:28 PM
07/03/17 10:28 PM
dartman366
Mt. Vernon, Ohio
To small an air gap is not going to cause any issue other than possible interference of parts. You might wanna recheck rotor phasing for sure... MSD calls out a .050to.080 gap range, I set mine at .060 and forget it, and I am with Al on the rotor phasing.
[Re: dartman366]
#2331047
07/03/17 10:36 PM
07/03/17 10:36 PM
Sammy
Wind Gap,Pa.
To small an air gap is not going to cause any issue other than possible interference of parts. You might wanna recheck rotor phasing for sure... MSD calls out a .050to.080 gap range, I set mine at .060 and forget it, and I am with Al on the rotor phasing. Going to check again the phasing but I believe I'm dead on with the leading edge. U just regapped it to .055
[Re: B1MAXX]
#2331250
07/04/17 11:30 AM
07/04/17 11:30 AM
Posts: 19,421 north of coder
moparx
Fastener Dia. has no effect on threads per inch. you are correct ! MY MISTAKE ! i was thinking of something else ! please disregard my comment ! ["oldtimers" in action can bite you every time, as this BIT me !] and i KNOW better ! now i feel like an azz.........
[Re: moparx]
#2331344
07/04/17 01:20 PM
07/04/17 01:20 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
Fastener Dia. has no effect on threads per inch. you are correct ! MY MISTAKE ! i was thinking of something else ! please disregard my comment ! ["oldtimers" in action can bite you every time, as this BIT me !] and i KNOW better ! now i feel like an azz......... Welcome to Moparts!
[image][/image]
