Is an Air Grabber switch repairable? (71-72)
#2319102
06/10/17 09:33 PM
06/10/17 09:33 PM
Posts: 1,185 Nanaimo, BC
NOrrTH
Nanaimo, BC
I think my switch is leaking air. You can hear it when I turn the motor off. I've played with the hoses, the rubber plug they go into and then mount to the switch. Pretty sure that seal is good.
There doesn't seem to be anyway the switch comes apart to repair it and repo's are going for $300.
Any thoughts?
'71 GTX N96 auto 3:55
'74 Challenger 440+6 4spd 4:10
'71 Duster 340 auto 4:10
Re: Is an Air Grabber switch repairable? (71-72)
[Re: NOrrTH]
#2319125
06/10/17 10:34 PM
06/10/17 10:34 PM
Posts: 4,922 new berlin wisconsin
Mr T2U
i am not 100% sure about this. but your switch should leak air after the car is shut off. this allows the flap to close on the hood. their is a solenoid hooked into the switch just for this.
now if it leaks air while the car is running then there is a problem with the switch.
perception is 90% of reality
[Re: NOrrTH]
#2319190
06/11/17 12:12 AM
06/11/17 12:12 AM
Posts: 5,108 Chicago Blackhawks
hemicar1971
Chicago Blackhawks
I have a few of those switches that need that repair. This is commom with these switches having broken hose hook ups.
1971 HEMI E BODY REGISTRY
[Re: NOrrTH]
#2319215
06/11/17 12:48 AM
06/11/17 12:48 AM
NOrrTH
Nanaimo, BC
Thanks guys. I'll take you up on that Convx4
