Is an Air Grabber switch repairable? (71-72) #2319102
06/10/17 09:33 PM
06/10/17 09:33 PM
Nanaimo, BC
N
NOrrTH Offline OP
NOrrTH  Offline OP
N
Nanaimo, BC
I think my switch is leaking air. You can hear it when I turn the motor off. I've played with the hoses, the rubber plug they go into and then mount to the switch. Pretty sure that seal is good.
There doesn't seem to be anyway the switch comes apart to repair it and repo's are going for $300.
Any thoughts?
'71 GTX N96 auto 3:55 '74 Challenger 440+6 4spd 4:10 '71 Duster 340 auto 4:10
Re: Is an Air Grabber switch repairable? (71-72) [Re: NOrrTH] #2319125
06/10/17 10:34 PM
06/10/17 10:34 PM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
i am not 100% sure about this. but your switch should leak air after the car is shut off. this allows the flap to close on the hood. their is a solenoid hooked into the switch just for this.
now if it leaks air while the car is running then there is a problem with the switch.
perception is 90% of reality
Re: Is an Air Grabber switch repairable? (71-72) [Re: NOrrTH] #2319130
06/10/17 10:38 PM
06/10/17 10:38 PM
St Louis, MO 63026
convx4 Offline
convx4  Offline
St Louis, MO 63026
I repair original and repop air grabber switches. Most of the time the three nubs on the back , where the vacuum hose hooks up to, are cracked and or broken off. This will cause an air leak. After disassembly for inspection. I machine new nubs they are heavy duty and better fitted to the air lines. These are then inserted into the body. I then reassemble and test the switch with a hand pump and two vacuum gauges. All this and a one year warranty for $100. Shipping included to the US.
Re: Is an Air Grabber switch repairable? (71-72) [Re: NOrrTH] #2319190
06/11/17 12:12 AM
06/11/17 12:12 AM
Chicago Blackhawks
hemicar1971 Online content
hemicar1971  Online Content
Chicago Blackhawks
I have a few of those switches that need that repair. This is commom with these switches having broken hose hook ups.
1971 HEMI E BODY REGISTRY
Re: Is an Air Grabber switch repairable? (71-72) [Re: NOrrTH] #2319215
06/11/17 12:48 AM
06/11/17 12:48 AM
Nanaimo, BC
N
NOrrTH Offline OP
NOrrTH  Offline OP
N
Nanaimo, BC
Thanks guys. I'll take you up on that Convx4
Re: Is an Air Grabber switch repairable? (71-72) [Re: NOrrTH] #2319308
06/11/17 10:00 AM
06/11/17 10:00 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I have a 70 model that works but the red handle is missing. Can you repair that?
Re: Is an Air Grabber switch repairable? (71-72) [Re: NOrrTH] #2320018
06/12/17 05:34 PM
06/12/17 05:34 PM
Nanaimo, BC
N
NOrrTH Offline OP
NOrrTH  Offline OP
N
Nanaimo, BC
Convx4 you have a PM :0)
Re: Is an Air Grabber switch repairable? (71-72) [Re: NOrrTH] #2320215
06/12/17 10:42 PM
06/12/17 10:42 PM
St Louis, MO 63026
convx4 Offline
convx4  Offline
St Louis, MO 63026
NOrrTH- I responded to your Pm
Hemicar1971- Yes, For the ones I see.
fastmark- I have a chrome 70 style chrome handle that I paint red. They don't break like the red plastic ones do.
Any one can PM me thru the board.
A few warnings:
I don't always log in when I visit and I don't have a smart phone.
