Calvert front segment #/lenght #2300691
05/07/17 02:16 PM
05/07/17 02:16 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
Trying to move axle rearward. which ones go in to do this? Lf426-445 and lf 120-345. Just took the 120-345 out. The 120-345 look longer. I need something longer than this
Re: Calvert front segment #/lenght [Re: mopar dave] #2300719
05/07/17 03:14 PM
05/07/17 03:14 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
You're going to have to call Calvert for this info, I'm sure.
Re: Calvert front segment #/lenght [Re: StealthWedge67] #2300742
05/07/17 04:24 PM
05/07/17 04:24 PM
Mt Morris Michigan
Mt Morris Michigan
Yeah i think so. Couldnt find anything on their site or on the web. I put it back together. This can wait til next year. Too many other things to do . thanks
Re: Calvert front segment #/lenght [Re: mopar dave] #2300754
05/07/17 04:48 PM
05/07/17 04:48 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I went to the 25" ft segment but not to move the rear back but to take advantage of the extra leverage...........
Re: Calvert front segment #/lenght [Re: Thumperdart] #2300820
05/07/17 07:39 PM
05/07/17 07:39 PM
Mt Morris Michigan
Mt Morris Michigan
Ok. The ones in it now are 120-345 20" segments. I think a 22 would be all i need to center the tire in the well.
Re: Calvert front segment #/lenght [Re: mopar dave] #2300832
05/07/17 08:15 PM
05/07/17 08:15 PM
New Smyrna Beach FL
scottb Online content
scottb  Online Content
New Smyrna Beach FL
They also make a 21 inch to move the tire back 1inch
Re: Calvert front segment #/lenght [Re: scottb] #2300846
05/07/17 08:54 PM
05/07/17 08:54 PM
Mt Morris Michigan
Mt Morris Michigan
I remeasured with tires on and looks like 1/2" longer would be perfect. 21" would be back too far.
Re: Calvert front segment #/lenght [Re: mopar dave] #2300848
05/07/17 08:56 PM
05/07/17 08:56 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
They are split mono's. Redrill and put the center pin where you need it. I had to on mine.
Re: Calvert front segment #/lenght [Re: GY3] #2300851
05/07/17 09:01 PM
05/07/17 09:01 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Did mine the same way.
Re: Calvert front segment #/lenght [Re: CSK] #2300861
05/07/17 09:22 PM
05/07/17 09:22 PM
Mt Morris Michigan
Mt Morris Michigan
How hard is it to drill thru those springs?
Re: Calvert front segment #/lenght [Re: mopar dave] #2300892
05/07/17 10:35 PM
05/07/17 10:35 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
if you move the rear end back a full inch the Bar will be and inch too short.. I was comfortable with three quarters of an inch... that was the minimum thread engagement on the Himes that I was comfortable with
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Calvert front segment #/lenght [Re: mopar dave] #2300906
05/07/17 10:52 PM
05/07/17 10:52 PM
Ontario,Canada
firefighter3931 Offline
Ontario,Canada
Just put a 1/2 in shim/spacer in front of the front hanger. wink
Ron
Re: Calvert front segment #/lenght [Re: firefighter3931] #2300909
05/07/17 10:57 PM
05/07/17 10:57 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
Ron
providing they're not welded in
Re: Calvert front segment #/lenght [Re: mopar dave] #2300965
05/08/17 12:40 AM
05/08/17 12:40 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Pretty damn tuff, but it can be done. Do the 1/2" spacer that Firefighter suggests. up
Re: Calvert front segment #/lenght [Re: firefighter3931] #2300967
05/08/17 12:40 AM
05/08/17 12:40 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Ron
iagree up
Re: Calvert front segment #/lenght [Re: WHITEDART] #2300978
05/08/17 01:12 AM
05/08/17 01:12 AM
Mt Morris Michigan
Mt Morris Michigan
I think theres enough to move the rear back 3/8". Thanks for that, didn't even occur to me. The boxes are moved in and welded. Gonna leave as is for now. I'll work next year when I get the bigger tires. thanks
Re: Calvert front segment #/lenght [Re: mopar dave] #2300985
05/08/17 01:27 AM
05/08/17 01:27 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
Bridgeport. smile
Re: Calvert front segment #/lenght [Re: mopar dave] #2301032
05/08/17 08:18 AM
05/08/17 08:18 AM
australia
charger410 Offline
charger410  Offline
australia
I drilled mine to. It's hard steel, but you can drill it.
Peter. Australian Charger, alloy block injected 410in, w9 na 9.03@148 leafs 3000lb
1967 barracuda 605 hemi Stage5 millennium 8.2@170
Re: Calvert front segment #/lenght [Re: charger410] #2301064
05/08/17 11:20 AM
05/08/17 11:20 AM
Mt Morris Michigan
Mt Morris Michigan
I have a drill press and some new drill bits, I will give it a try when I need to. I would like to get a 29" rear tire on it and may give it a try next year or thru the winter months.
Re: Calvert front segment #/lenght [Re: GY3] #2301068
05/08/17 11:23 AM
05/08/17 11:23 AM
moparx Offline
moparx  Offline
Bridgeport. smile
iagree use a carbide center cut endmill or carbide drill. cuts like butter.
beer
