Re: Calvert front segment #/lenght
[Re: mopar dave]
#2300719
05/07/17 03:14 PM
05/07/17 03:14 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
You're going to have to call Calvert for this info, I'm sure.
[Re: mopar dave]
#2300754
05/07/17 04:48 PM
05/07/17 04:48 PM
Thumperdart
State of confusion
I went to the 25" ft segment but not to move the rear back but to take advantage of the extra leverage...........
[Re: mopar dave]
#2300848
05/07/17 08:56 PM
05/07/17 08:56 PM
Posts: 4,705 Wichita
GY3
Wichita
I remeasured with tires on and looks like 1/2" longer would be perfect. 21" would be back too far. They are split mono's. Redrill and put the center pin where you need it. I had to on mine.
[Re: GY3]
#2300851
05/07/17 09:01 PM
05/07/17 09:01 PM
Posts: 2,873 Pattison Texas
CSK
Pattison Texas
I remeasured with tires on and looks like 1/2" longer would be perfect. 21" would be back too far. They are split mono's. Redrill and put the center pin where you need it. I had to on mine. Did mine the same way.
[Re: mopar dave]
#2300892
05/07/17 10:35 PM
05/07/17 10:35 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
How hard is it to drill thru those springs? if you move the rear end back a full inch the Bar will be and inch too short.. I was comfortable with three quarters of an inch... that was the minimum thread engagement on the Himes that I was comfortable with
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: mopar dave]
#2300906
05/07/17 10:52 PM
05/07/17 10:52 PM
Posts: 1,646 Ontario,Canada
firefighter3931
Ontario,Canada
I remeasured with tires on and looks like 1/2" longer would be perfect. 21" would be back too far. Just put a 1/2 in shim/spacer in front of the front hanger. ![wink wink](/ubbthreads/images/graemlins/custom/wink.gif) Ron
[Re: firefighter3931]
#2300909
05/07/17 10:57 PM
05/07/17 10:57 PM
WHITEDART
bean town ....Ca
I remeasured with tires on and looks like 1/2" longer would be perfect. 21" would be back too far. Just put a 1/2 in shim/spacer in front of the front hanger. ![wink wink](/ubbthreads/images/graemlins/custom/wink.gif) Ron providing they're not welded in
[Re: mopar dave]
#2300965
05/08/17 12:40 AM
05/08/17 12:40 AM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
How hard is it to drill thru those springs? Pretty damn tuff, but it can be done. Do the 1/2" spacer that Firefighter suggests.
[Re: mopar dave]
#2301032
05/08/17 08:18 AM
05/08/17 08:18 AM
Posts: 159 australia
charger410
australia
How hard is it to drill thru those springs? I drilled mine to. It's hard steel, but you can drill it.
Peter. Australian Charger, alloy block injected 410in, w9 na 9.03@148 leafs 3000lb
1967 barracuda 605 hemi Stage5 millennium 8.2@170
