Small block mopar, 727 trans and a mid plate #2290794
04/20/17 12:35 AM
04/20/17 12:35 AM
jacksonville,FLORIDA
slammedR/T Offline OP
Well it is time to install a mid platen on my turtle, running a small block Mopar with a 727 transmission.
Any suggestions on a mid plate get and what to do about spacing the converter to the flex plate? ARP make a longer torque converter bolt in a 7/16" for us Mopar people?
2000 Dakota R/T, 408 magnum, 727, Indy heads
1000cfm 4150 carb, 93 octane fuel.
motor; 10.258 @ 132.78
200 shot; 9.262 @ 144.69
racemagnum
Re: Small block mopar, 727 trans and a mid plate [Re: slammedR/T] #2290805
04/20/17 01:02 AM
04/20/17 01:02 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I use .090 for the mid plate.. just open up
the starter area so the starter sets against
the bell housing.. I never used a longer snout
on any of my convs
wave
Re: Small block mopar, 727 trans and a mid plate [Re: MR_P_BODY] #2291135
04/20/17 06:21 PM
04/20/17 06:21 PM
Did you use a flex plate shim or spacers between converter and flexplate?
racemagnum
Re: Small block mopar, 727 trans and a mid plate [Re: slammedR/T] #2291150
04/20/17 06:50 PM
04/20/17 06:50 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Saw you posting on that "other" site.I am installing a midplate myself right now.After 15+ years with an engine plate and a rubber trans mount I'm overdue.The midplate came with the crank spacer.It came untrimmed so you can shape it the way you want.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Small block mopar, 727 trans and a mid plate [Re: slammedR/T] #2291157
04/20/17 07:01 PM
04/20/17 07:01 PM
MR_P_BODY Offline
MR_P_BODY  Offline
No... it pulls the conv out of the pump .090.. I
never had any issues that way.. if you want you
can shim the conv back with washers
wave
Re: Small block mopar, 727 trans and a mid plate [Re: hemi-itis] #2291185
04/20/17 07:50 PM
04/20/17 07:50 PM
ccarson Offline
ccarson  Offline
Wow I thought I trimmed my cross member, hope I cut enough.
I'm using the Milodon rear sump Truck pan.
Re: Small block mopar, 727 trans and a mid plate [Re: slammedR/T] #2291251
04/20/17 09:43 PM
04/20/17 09:43 PM
Suggest any vendor to buy from? before I order it from summit racing.
racemagnum
Re: Small block mopar, 727 trans and a mid plate [Re: slammedR/T] #2291292
04/20/17 10:59 PM
04/20/17 10:59 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I made my mid plate.. super simple if you have
a trans handy.. just leave a big ear off of
each side
wave
Re: Small block mopar, 727 trans and a mid plate [Re: slammedR/T] #2291297
04/20/17 11:11 PM
04/20/17 11:11 PM
I just ordered a mid plate from summit racing, thanks for all the advice peoples smile
racemagnum
