Small block mopar, 727 trans and a mid plate
#2290794
04/20/17 12:35 AM
04/20/17 12:35 AM
Posts: 733 jacksonville,FLORIDA
slammedR/T
Well it is time to install a mid platen on my turtle, running a small block Mopar with a 727 transmission. Any suggestions on a mid plate get and what to do about spacing the converter to the flex plate? ARP make a longer torque converter bolt in a 7/16" for us Mopar people?
2000 Dakota R/T, 408 magnum, 727, Indy heads 1000cfm 4150 carb, 93 octane fuel. motor; 10.258 @ 132.78 200 shot; 9.262 @ 144.69 racemagnum
Re: Small block mopar, 727 trans and a mid plate
[Re: slammedR/T]
#2290805
04/20/17 01:02 AM
04/20/17 01:02 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I use .090 for the mid plate.. just open up the starter area so the starter sets against the bell housing.. I never used a longer snout on any of my convs
[Re: MR_P_BODY]
#2291135
04/20/17 06:21 PM
04/20/17 06:21 PM
slammedR/T
Did you use a flex plate shim or spacers between converter and flexplate?
[Re: slammedR/T]
#2291150
04/20/17 06:50 PM
04/20/17 06:50 PM
Posts: 12,591 Great Neck,LI,new york
hemi-itis
Saw you posting on that "other" site.I am installing a midplate myself right now.After 15+ years with an engine plate and a rubber trans mount I'm overdue.The midplate came with the crank spacer.It came untrimmed so you can shape it the way you want.
[Re: slammedR/T]
#2291157
04/20/17 07:01 PM
04/20/17 07:01 PM
MR_P_BODY
No... it pulls the conv out of the pump .090.. I never had any issues that way.. if you want you can shim the conv back with washers
[Re: slammedR/T]
#2291251
04/20/17 09:43 PM
04/20/17 09:43 PM
slammedR/T
Suggest any vendor to buy from? before I order it from summit racing.
[Re: slammedR/T]
#2291292
04/20/17 10:59 PM
04/20/17 10:59 PM
MR_P_BODY
Suggest any vendor to buy from? before I order it from summit racing. I made my mid plate.. super simple if you have a trans handy.. just leave a big ear off of each side
[Re: slammedR/T]
#2291297
04/20/17 11:11 PM
04/20/17 11:11 PM
slammedR/T
I just ordered a mid plate from summit racing, thanks for all the advice peoples
