468 ci sb- Single plane vs Tunnel ram #2268252
03/12/17 08:58 PM
03/12/17 08:58 PM
Edmonton Alberta, Canada
R3DART Offline OP
R3DART  Offline OP
Hey folks, looking for some help/opinion on swaping my 360-3 for Pro Dominator.
My current combo is as follows;
468 ci
360-3 w/ 1050 dominator
360-1 245 rp
12.4-1
Solid Roller
724/693
277/284 @ .050
110 lsa installed at 106
1 7/8 tti
904 / 5200 stall
3.91 Gear
3200 lb a-body
I would like to run the pro dominator on this combo.
I have talked to a few very knowledgable people on this, and as expected the opinions vary.
First question is, will I see gains going to the w2 pro dominator on this combo ( I realize we will have to change to rec port)
Second question, what size carbs should I use.
Looking forward to the responses on this.
Les.
Re: 468 ci sb- Single plane vs Tunnel ram [Re: R3DART] #2268288
03/12/17 09:38 PM
03/12/17 09:38 PM
Washington
madscientist Offline
Washington
468 ci
360-1 245 rp
12.4-1
Solid Roller
724/693
277/284 @ .050
1 7/8 tti
904 / 5200 stall
3.91 Gear
3200 lb a-body
Les.
I would consider changing the cam at the same time. You can use less duration to get the same peak RPM. If you don't get a cam for a TR, you will see a soft middle RPM, and a very narrow power curve. A tunnel ram can and will make more power everywhere if the cam timing is correct.
I think tunnel ram intakes can run a narrower LSA to keep them from making power past peak any further than you need to.
I'd do it in a heartbeat. Also, thumperdart or jmark should go through the carbs.
Re: 468 ci sb- Single plane vs Tunnel ram [Re: R3DART] #2268367
03/12/17 11:27 PM
03/12/17 11:27 PM
SoCal
Brian Hafliger Offline
SoCal
Once you open the ports at the flange to match the heads, you'll need to correct the taper in the TR ports all the way into the plenum. Once you do that, it should work really well.
I would use 2 950's or 2 1000 carbs but you could try 2 edelbrock 800 carbs....believe it or not they work very good in TR applications.
The cam looks good to me, but what do I know...
Brian Hafliger
Re: 468 ci sb- Single plane vs Tunnel ram [Re: R3DART] #2268375
03/12/17 11:37 PM
03/12/17 11:37 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
I'm a big fan of tunnel rams, although not that involved with small blocks. I really liked the old 660 center squirters when I ran a 440 cube 440 block and Weiand TR. My new build is a 500 cube 440 with a TRE sheet metal manifold and 2 850's with the choke horns milled off. If you get the 660's look for the version with both front and rear metering blocks. The later ones had a metering plate style (4160).
[image][/image]
Re: 468 ci sb- Single plane vs Tunnel ram [Re: R3DART] #2268383
03/12/17 11:46 PM
03/12/17 11:46 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
468 ci
360-1 245 rp
12.4-1
Solid Roller
724/693
277/284 @ .050
1 7/8 tti
904 / 5200 stall
3.91 Gear
3200 lb a-body
Les.
what is the bore stroke combination.... I would think that would have a lot to do with your options
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: 468 ci sb- Single plane vs Tunnel ram [Re: WHITEDART] #2268403
03/13/17 12:25 AM
03/13/17 12:25 AM
R3DART Offline OP
R3DART  Offline OP
Thanks for the replies fella's, I appreciate it.
Bore: 4.185
Stroke: 4.250
Re: 468 ci sb- Single plane vs Tunnel ram [Re: R3DART] #2268407
03/13/17 12:38 AM
03/13/17 12:38 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Leave the cam as is.. open up the intake
and you might change the rear gear
EDIT
A pair of 1000 cfm or 1050s
wave
Re: 468 ci sb- Single plane vs Tunnel ram [Re: R3DART] #2268677
03/13/17 03:56 PM
03/13/17 03:56 PM
R3DART Offline OP
R3DART  Offline OP
Thanks again for the help.
Seems to be a big spread of opinion on carb sizes. I've been told everything from 650's right up to 1050's.
If buying new, unless I'm missing something (which is very likely!!) it seems it would make sense to go as large possible (without sacrafising performance). This would give room for growth in the future.
Les.
Re: 468 ci sb- Single plane vs Tunnel ram [Re: R3DART] #2268684
03/13/17 04:09 PM
03/13/17 04:09 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Where will it be shifted and what fuel. Had good luck lately w/boat TR's but prefer a single and if you look around, you will see MANY fast cars w/one carb and in your case maybe a 1250 HP-Dommy........... thumbs
Re: 468 ci sb- Single plane vs Tunnel ram [Re: R3DART] #2268719
03/13/17 04:56 PM
03/13/17 04:56 PM
R3DART Offline OP
R3DART  Offline OP
Dom;
I've been shifting it at 7000 but was not able to get it out to the track last year due to a few issues whitch we are rectifying now.
It runs on run pump gas.
To be honest, I love the look of the pro dominator and I have one. If it will gain me some performance to do the swap, I would like to.
Re: 468 ci sb- Single plane vs Tunnel ram [Re: R3DART] #2268724
03/13/17 05:07 PM
03/13/17 05:07 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Pro-dominator.............???????
Re: 468 ci sb- Single plane vs Tunnel ram [Re: R3DART] #2268726
03/13/17 05:08 PM
03/13/17 05:08 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
That's what Holley used to call their tunnel rams.
68 Barracuda Formula S 340
Re: 468 ci sb- Single plane vs Tunnel ram [Re: Bad340fish] #2268758
03/13/17 06:20 PM
03/13/17 06:20 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Gotcha...........I prefer what works over "looks" any day.........
Re: 468 ci sb- Single plane vs Tunnel ram [Re: R3DART] #2268774
03/13/17 06:52 PM
03/13/17 06:52 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Bore: 4.185
Stroke: 4.250
work
What block?
Is that a 2.0 Rod crank?
Pump gas at 12.4 CR?
Any projection on HP?
Yours sounds nice. up I am working on a similar slightly smaller motor, but 7000 is too risky for my application
Re: 468 ci sb- Single plane vs Tunnel ram [Re: R3DART] #2268899
03/13/17 09:50 PM
03/13/17 09:50 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
two 750s over a 1050 dominater was two tenths on my combo.... 511ci INDY heads
1.39 9.85 - 137 mph
Re: 468 ci sb- Single plane vs Tunnel ram [Re: Thumperdart] #2268901
03/13/17 09:51 PM
03/13/17 09:51 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
put two 750s on
1.39 9.85 - 137 mph
Re: 468 ci sb- Single plane vs Tunnel ram [Re: jcc] #2268916
03/13/17 10:02 PM
03/13/17 10:02 PM
R3DART Offline OP
R3DART  Offline OP
Bore: 4.185
Stroke: 4.250
work
What block?
Thanks!
-Ritter aluminum block.
-Yes. 2.0 rod BPE crank
-Yes, been running 94 octane pump gas
- we did dyno it, was up over 700. Will get it to the track this summer and figure out where it's at.
Re: 468 ci sb- Single plane vs Tunnel ram [Re: Thumperdart] #2268923
03/13/17 10:06 PM
03/13/17 10:06 PM
R3DART Offline OP
R3DART  Offline OP
Yeah, I hear what you are saying. That's the reason I'm asking for opinions. If it's gonna make me go backwards, no point. If it's gonna work better and look cool, I'm good with that!
Re: 468 ci sb- Single plane vs Tunnel ram [Re: R3DART] #2269012
03/13/17 11:31 PM
03/13/17 11:31 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
My high 9 second 73 Dart was a good tenth and a half quicker with the TR than a single Dominator. I loved it, seemed more streetable and the 60 foot was the same or better than the Dominator.
Re: 468 ci sb- Single plane vs Tunnel ram [Re: R3DART] #2269030
03/13/17 11:56 PM
03/13/17 11:56 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I have a W2 416 with the Indy-3 intake. It is fuel injected with a 1000CFM throttle body on it. It is actually pulling some vacuum on the throttle body at wide open. I bought a nice W2 Pro Dominator from a moparts member to have converted to EFI so I can add another 1000CFM throttle body.
