Re: 468 ci sb- Single plane vs Tunnel ram
[Re: R3DART]
#2268288
03/12/17 09:38 PM
03/12/17 09:38 PM
Posts: 4,457 Washington
madscientist
Washington
Hey folks, looking for some help/opinion on swaping my 360-3 for Pro Dominator.
My current combo is as follows;
468 ci 360-3 w/ 1050 dominator 360-1 245 rp 12.4-1 Solid Roller 724/693 277/284 @ .050 110 lsa installed at 106 1 7/8 tti
904 / 5200 stall 3.91 Gear 3200 lb a-body
I would like to run the pro dominator on this combo. I have talked to a few very knowledgable people on this, and as expected the opinions vary.
First question is, will I see gains going to the w2 pro dominator on this combo ( I realize we will have to change to rec port)
Second question, what size carbs should I use.
Looking forward to the responses on this.
Les.
I would consider changing the cam at the same time. You can use less duration to get the same peak RPM. If you don't get a cam for a TR, you will see a soft middle RPM, and a very narrow power curve. A tunnel ram can and will make more power everywhere if the cam timing is correct. I think tunnel ram intakes can run a narrower LSA to keep them from making power past peak any further than you need to. I'd do it in a heartbeat. Also, thumperdart or jmark should go through the carbs.
[Re: R3DART]
#2268367
03/12/17 11:27 PM
03/12/17 11:27 PM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
Once you open the ports at the flange to match the heads, you'll need to correct the taper in the TR ports all the way into the plenum. Once you do that, it should work really well.
I would use 2 950's or 2 1000 carbs but you could try 2 edelbrock 800 carbs....believe it or not they work very good in TR applications.
The cam looks good to me, but what do I know...
Brian Hafliger
[Re: R3DART]
#2268375
03/12/17 11:37 PM
03/12/17 11:37 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
I'm a big fan of tunnel rams, although not that involved with small blocks. I really liked the old 660 center squirters when I ran a 440 cube 440 block and Weiand TR. My new build is a 500 cube 440 with a TRE sheet metal manifold and 2 850's with the choke horns milled off. If you get the 660's look for the version with both front and rear metering blocks. The later ones had a metering plate style (4160).
[image][/image]
[Re: R3DART]
#2268383
03/12/17 11:46 PM
03/12/17 11:46 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
Les.
what is the bore stroke combination.... I would think that would have a lot to do with your options
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: R3DART]
#2268407
03/13/17 12:38 AM
03/13/17 12:38 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Leave the cam as is.. open up the intake and you might change the rear gear EDIT A pair of 1000 cfm or 1050s
[Re: R3DART]
#2268724
03/13/17 05:07 PM
03/13/17 05:07 PM
Thumperdart
State of confusion
Pro-dominator.............???????
[Re: R3DART]
#2268726
03/13/17 05:08 PM
03/13/17 05:08 PM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
That's what Holley used to call their tunnel rams.
68 Barracuda Formula S 340
[Re: Bad340fish]
#2268758
03/13/17 06:20 PM
03/13/17 06:20 PM
Thumperdart
State of confusion
Gotcha...........I prefer what works over "looks" any day.........
[Re: R3DART]
#2268774
03/13/17 06:52 PM
03/13/17 06:52 PM
Posts: 22,696 Bitopia
jcc
Bitopia
Thanks for the replies fella's, I appreciate it.
Bore: 4.185 Stroke: 4.250 What block? Is that a 2.0 Rod crank? Pump gas at 12.4 CR? Any projection on HP? Yours sounds nice. I am working on a similar slightly smaller motor, but 7000 is too risky for my application
[Re: R3DART]
#2268899
03/13/17 09:50 PM
03/13/17 09:50 PM
Posts: 5,618 long island NY
Ari440
long island NY
two 750s over a 1050 dominater was two tenths on my combo.... 511ci INDY heads
1.39 9.85 - 137 mph
[Re: Thumperdart]
#2268901
03/13/17 09:51 PM
03/13/17 09:51 PM
Ari440
long island NY
Gotcha...........I prefer what works over "looks" any day......... put two 750s on
1.39 9.85 - 137 mph
[Re: jcc]
#2268916
03/13/17 10:02 PM
03/13/17 10:02 PM
Posts: 205 Edmonton Alberta, Canada
R3DART
Bore: 4.185 Stroke: 4.250 What block? Is that a 2.0 Rod crank? Pump gas at 12.4 CR? Any projection on HP? Yours sounds nice. I am working on a similar slightly smaller motor, but 7000 is too risky for my application Thanks! -Ritter aluminum block. -Yes. 2.0 rod BPE crank -Yes, been running 94 octane pump gas - we did dyno it, was up over 700. Will get it to the track this summer and figure out where it's at.
[Re: Thumperdart]
#2268923
03/13/17 10:06 PM
03/13/17 10:06 PM
R3DART
Gotcha...........I prefer what works over "looks" any day......... Yeah, I hear what you are saying. That's the reason I'm asking for opinions. If it's gonna make me go backwards, no point. If it's gonna work better and look cool, I'm good with that!
[Re: R3DART]
#2269012
03/13/17 11:31 PM
03/13/17 11:31 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
My high 9 second 73 Dart was a good tenth and a half quicker with the TR than a single Dominator. I loved it, seemed more streetable and the 60 foot was the same or better than the Dominator.
[Re: R3DART]
#2269030
03/13/17 11:56 PM
03/13/17 11:56 PM
Bad340fish
Tulsa OK
I have a W2 416 with the Indy-3 intake. It is fuel injected with a 1000CFM throttle body on it. It is actually pulling some vacuum on the throttle body at wide open. I bought a nice W2 Pro Dominator from a moparts member to have converted to EFI so I can add another 1000CFM throttle body.
