Hey folks, looking for some help/opinion on swaping my 360-3 for Pro Dominator.
My current combo is as follows;
468 ci
360-3 w/ 1050 dominator
360-1 245 rp
12.4-1
Solid Roller
724/693
277/284 @ .050
110 lsa installed at 106
1 7/8 tti
904 / 5200 stall
3.91 Gear
3200 lb a-body
I would like to run the pro dominator on this combo.
I have talked to a few very knowledgable people on this, and as expected the opinions vary.
First question is, will I see gains going to the w2 pro dominator on this combo ( I realize we will have to change to rec port)
Second question, what size carbs should I use.
Looking forward to the responses on this.
Les.
I would consider changing the cam at the same time. You can use less duration to get the same peak RPM. If you don't get a cam for a TR, you will see a soft middle RPM, and a very narrow power curve. A tunnel ram can and will make more power everywhere if the cam timing is correct.
I think tunnel ram intakes can run a narrower LSA to keep them from making power past peak any further than you need to.
I'd do it in a heartbeat. Also, thumperdart or jmark should go through the carbs.
