not sure if you will see gains with the t/r was the indy ported ,i think if you port a 772 and converted to yours it will make more power or a sheet metal the rp s move some air 360 cfm just my 2 cents.
Ian, my intake is not ported.
After a discussion I had with Brett a while back, I was planning on getting rid of my 4150 to 4500 adapter and opening it up for the dominator.
But every time I walk into my garage I see that pro dominator tunnel ram sitting there. Seems a shame not to use it if can be made to work well.
