Re: Organosol "The Bulletin" January 15, 1969
[Re: RoadRunnerJD]
#21216
12/18/05 01:57 AM
12/18/05 01:57 AM
Posts: 21,945 N.E. OHIO, USA
A12
N.E. OHIO, USA
Your library of info is amazing! Do you think this is how the hood is done? I know that my hood is too gritty the way it is now and I'm kind of leaning toward the way it looks in the current special Hot Rod which is way smoother.
John, someone that I respect quite a lot with Mopar restoration told me to look for paint code 9407 that this may be the "missing link" for the A12 and AAR/T/A hood paint. I asked if anyone here knew what 9407 was but as of now no reply.
I have this (see attachment) and the Dupont, R-M, and PPG paint chips but there is nothing on 9407 or any black except the 88L and Organosol.
MikeR
[Re: RoadRunnerJD]
#21220
12/19/05 02:52 PM
12/19/05 02:52 PM
Posts: 2,657 Nashville, TN
MOPARMIKE69
Nashville, TN
I wonder if it's a PPG number? I have been using PPG Duracryl #9355 but it's just too gritty.
That is what I have found to be the best solution to this Organisol paint situation. I painted 4 different 6bbl hoods over the years all with trying different thinner levels, temperature , air pressure etc. Always too much grit.
I shot PPG 9355 and used the slowest reducer. I was able to make a normal pass, followed by a pass going across what I just shot. It goes on like primer looking like it will be rough, but it flows out and lays down really nice with the slow reducer. I let it flash and then two more passes, criscrossing. Here is a picture of the results. Not an A12 hood but it is on a plastic bubble and a fiberglass hood scoop. I loved the way it cooperated and turned out. It matches the finish on an original A12 hood dead on.
69 Road Runner vert 69 GTX hard top 70 Road Runner 4 speed 70 Hemi Cuda vert
[Re: Fasbird]
#21222
12/19/05 06:24 PM
12/19/05 06:24 PM
Posts: 1,355 maine
LO23
maine
[Re: QuickSilver]
#21224
12/19/05 07:10 PM
12/19/05 07:10 PM
A12
N.E. OHIO, USA
Are you sure the PPG number isn't 9437? I have some of this and it is labled 9437 organisol in which I used to restore the tail light panel on a 69 R/T Charger and it turned out perfect. Man did it dry down very nice. I can't wait to spray my hood. Not to gritty at all and just the look I want for mine!
Quicksilver, maybe it is 9437? I have to call. (Does this 9437 have a name?)
MikeR
[Re: Fasbird]
#21225
12/19/05 11:30 PM
12/19/05 11:30 PM
MOPARMIKE69
Nashville, TN
The original PPG number was DDL 9355, the "L" means laquer. Most paint suppliers do not mix laquer anymore. They can pull up the 9355 formula in the computer and mix it as an enamel. It works much better than the laquer. That is why you can use the slower reducer. The code is correct. After using this I would never shoot the laquer Or"crap"asol again. Same correct formula just enamel. Organasol works well on small panels etc. but when you try to spray it on large areas it goes on too dry, therefore it gets rough. It leaves uneven stripes because of the over spray from the gun on a large area.
[Re: MOPARMIKE69]
#21226
12/20/05 01:53 AM
12/20/05 01:53 AM
Posts: 4,912 The Dark Side
Fasbird
The Dark Side
That's why I asked the above question. Laquer and reducer don't mix well.
[Re: QuickSilver]
#21228
12/20/05 07:54 PM
12/20/05 07:54 PM
Posts: 1,355 maine
LO23
maine
you can also get "organosol black" 9355 mixed in dcc low gloss "concept" ppg also. lead free formula special low gloss color mix:6 pts paint;2 pts dt reducer;1 pt dcx61
[Re: Danan]
#21231
01/06/06 12:37 AM
01/06/06 12:37 AM
Posts: 1,145 ontario calif
ns1aar
ontario calif
The stuff I got says 9346 on the can went on real easy and looks good seems to have the right texture also.Used it on my AAR
[Re: ns1aar]
#21232
01/09/06 04:53 PM
01/09/06 04:53 PM
i also need to get the Organisol for my tail light panel for my 69 Charger. Has anyone used the Organisol paint from Totally Auto? Is it any good or close to what the original stuff was?
thanks,
Brian
[Re: RoadRunnerJD]
#21234
01/26/06 06:20 PM
01/26/06 06:20 PM
Just tried ordering the Organisol from Totally Auto and the lady said that 1968-1970 Chargers were a smooth finish and was just a semi flat black paint. Kinda contradicts what the TSB attachement says.
[Re: JeffsCustomPaint]
#21239
03/27/07 05:30 AM
03/27/07 05:30 AM
Posts: 6,310 colorado
a12superbee
colorado
Thanks for posting those Jeff. Do you have any shots close up that might show the texure you achieved using this technique?
I can't afford this.
mark
[Re: a12superbee]
#21241
03/27/07 09:38 AM
03/27/07 09:38 AM
BradH
Same here... because it doesn't look like it has any texture at all in your pictures.
[Re: BradH]
#21242
03/27/07 09:50 AM
03/27/07 09:50 AM
Posts: 5,160 Texas
dannysbee
Texas
Jeffs hood looks like the hood of my R4 Bee I got in 74.
Getting old just means you were smarter than some and luckier than others.
[Re: cataclysm80]
#21246
10/18/07 03:07 PM
10/18/07 03:07 PM
A12
N.E. OHIO, USA
Tav
Don't wait for me, I originally posted this December 17, 2005 and Jeff dug it up and it to the top. If I were painting an AAR, T/A hood or an A12 Lift-Off-Hood I would seriously look into this "Note";
NOTE: Engine exterior area of hood to be painted with 2183385 Exterior Air Dry Organsol Paint AX5DX8 Black, prior to installing hood retaining parts. 1-16-69
Painters out there, does this make any sense? Are the paint codes still relevant?
MikeR
I'm with you on this
BTW Tav, you seem to be waiting for something (from me?? ) in another few re-posts of mine, anything I can do to help let me know because I'm a little
MikeR
[Re: A12]
#21249
10/18/07 09:15 PM
10/18/07 09:15 PM
Posts: 2,908 Franklinville,NJ
JeffsCustomPaint
Franklinville,NJ
I originally posted this December 17, 2005 and Jeff dug it up and it to the top. MikeR
Mike i read that this thread was mentioned in Lon's thread about his hood and i seen that some people wanted to see pics of the hood i did upclose and they were after i last posted so i responded to that not to really dig it out and bump it but it is a good thread and people still need to do the organosol but sometime can't find info on it. It's a good thread to save
#21250
10/18/07 09:46 PM
10/18/07 09:46 PM
A12
N.E. OHIO, USA
Jeff,  I'm happy that it came back up, I was just kind of responding to the  from Tav, like someone was waiting for the other shoe to drop from me  MikeR
[Re: QuickSilver]
#21251
10/18/07 10:01 PM
10/18/07 10:01 PM
A12
N.E. OHIO, USA
Not sure if this helps but that AX5DX8 black seems to be an actual factory< in house> paint code. I know from working in the chrysler facility I was stationed at all of our quart cans and gallon cans of paint material all had an extra label secured over the original along with extra paint codes on it. This was to reduce the amount of lunch pail theft as you weren't really sure of what you were taking without peeling the outside label off. Just a thought. My paint supplier told me that the only codes for organisol in his books from 1969 were the 9355 which probably is correct for doing the rocker blackout as well as the tail panels for chargers etc. as listed on that TSB. He did give me another product which I had forgotten about which is called High Performance Black DDL 9381. That number has been changed to DDL 9423. I remember painting the glass hood for my dads T/A Challenger with this years ago and it seems like it might be the right stuff. I am going over to his shop and look around and see if I can find that gallon can. Has anyone tried using the DDL9423?
Joey, for sure that is the factory paint code (AX5DX8) for the A12 hoods (and maybe the AAR/T/A too?) and then the 9407 was from memory by a good friend and excellent source and he may be off on the last two numbers because he used the "94" several times until he settled for 9407. The DDL9423 may be the "missing link" for the closest match to the hood paint
MikeR
[Re: A12]
#21252
10/18/07 10:09 PM
10/18/07 10:09 PM
Posts: 6,252 Zzyzx Road
beepbeep
moparts member
moparts member
Zzyzx Road
None of the Organosols today are anywhere near the originals, both the metallic and suede used originally is no longer available.
9381 is a Ford color that was used on the shaker hoods and scoops.
Amazing how an unchallenged lie can become the absolute truth.
[Re: beepbeep]
#21253
10/18/07 10:29 PM
10/18/07 10:29 PM
A12
N.E. OHIO, USA
August 30, 2007 Authentic Restoration Products from Roger Gibson Auto Restoration E-mail: sixpackfrank@aol.com Web: www.rogergibsonautorestoration.com
ORGP/ORGQ Organosol - authentic black textured finish for hoods, tail panels…………Qt $95.00 ***ONCE AGAIN AVAILABLE*** .................................Pint $50.00
I'm pretty sure this is the latest version and not from the original supply that was supposedly around for a while. Anyone talk to Frank lately about it?
MikeR
[Re: 420SIX]
#21255
10/19/07 11:33 AM
10/19/07 11:33 AM
Not an A12 owner guys but my Roadrunner does have the black out hood treatment. Is this the same paint? Thanks guys.
[Re: beepbeep]
#21257
10/19/07 02:33 PM
10/19/07 02:33 PM
Posts: 542 Buckle of corn belt ,c. lll.
420SIX
Frank says their formula is made from the last of the original PPG stuff..The 9355 formula is going to be wrong.......
Unless something has changed very recently RG's organosol was urathane not lacquar.
It is acrylic lacquer
[Re: 420SIX]
#21258
10/19/07 11:06 PM
10/19/07 11:06 PM
Posts: 636 California
sixpaktoogo
California
Just bought some from him a few months ago. Doesn't say in his catalog that it's lacquer, and most of his other specialty paints are enamel! I called and asked Frank what I'm supposed to do with it since my car is painted in urethane enamel. He told me that it's my painter's problem!! What a tool!
[Re: 420SIX]
#21259
10/20/07 01:16 PM
10/20/07 01:16 PM
This should not matter, since lacuer was used over enamel originaly without any catylization like is used today.
simply try a test spray to make sure it does not lift on a scrap piece of metal. Your painter "should" know if he can do this or not. (I have only used it over enamel).
Now to the texture of hood blackout.
1). 9423 IS NOT IT.
2). For comparison of an original fine texture which i think is being referred to? look at original untouched dash and steering column paint, you will see that it is not the same as deck trim panel paint 9355, and is comparable to the hood black out texture.
3). Could it be that there was another paint vendor that supplied product to chrysler?
YES, Now which one was it?
Since that mfg no longer has laquers (you will have to find a very old mixing bench and formulas), it is going to require more use of ones resourses to come up with the comparison paint.
Mike
I have LOTS experinece with OE textured paints.
#21260
10/21/07 12:51 PM
10/21/07 12:51 PM
sixpaktoogo
California
Lacquer was able to be applied over factory paint because it was baked enamel, not fresh urethane. Even if it doesn't lift on a test panel, I would NEVER take a chance on spraying lacquer over a freshly enameled car, catylized or not!
[Re: 420SIX]
#21263
01/29/08 03:32 PM
01/29/08 03:32 PM
I have used both the PPG Duracryl Organosol and the PPG DCC urethane Organosol.I also have several examples of original Organosol on my original paint 69 Road Runner fender and 69 Charger tailpanel,as well as other original paint Organosol finishes I have studied.Here's what I found: PPG Organosol mixed in DCC urethane is very close.Nice semi smooth finish and semi flat black finish.Closely matches original Chrysler finish which is actually metallic flat black. PPG organosol mixed in Duracryl lacquer produces a gritty finish more like dash panels etc.While it is a cool finish,it is not correct in my opinion.I have seen original AAR cudas,A12 cars and V21 Road Runners,Chargers and 71 Dusters etc,and they never had the gritty finish like we see on the show cars nowdays. Yes the textured organosol looks cool-but it does not look correct to me.
#21265
01/30/08 06:01 PM
01/30/08 06:01 PM
Posts: 4,150 VA
RapidRunner
VA
Who knows? The Shadow Knows! But he ain't on this fraking forum!
"This restoration is a test,, It is ONLY a test, Had this been an actual Restoration I would have received instructions on what to do and where to get the MONEY!"
[Re: A12]
#21266
01/30/08 09:30 PM
01/30/08 09:30 PM
Posts: 3,020 Long Island, NY
shakerjoe
Long Island, NY
Another FYI
my birthday in mopar history - yeh baby
[Re: A12]
#21270
11/30/08 05:02 PM
11/30/08 05:02 PM
Posts: 1,489 west kentucky
gomangoRTSE
west kentucky
This is a lil off the subject matter, but whats the correct organsol formula for the tail panels on the 1970 RT/SE cars?? I thought it had some gray in it, or am I mistaken?? Thanks
[Re: DAYCLONA]
#21274
07/22/09 08:19 PM
07/22/09 08:19 PM
Posts: 1,294 Ontario, Canada
FJ5_Fish
Ontario, Canada
I have a bunch of low mile original cars - a bunch with Organosol painted areas. The stuff that Badalson sells is as close to dead nuts as you can buy if applied properly. There are not too many people that painted a lot of lacquer back in the 60's and 70's around these days. Painting lacquer is totally unique and what techniques that apply to acrylic urethane, base-clear etc. does not look right with laquer. Original Organosol has suede (for texture) and a tiny bit of metallic in it - it's there, look. Roger did devise an acrylic urethane formula when the original stuff disappeared - it was decent but a little too textured. The stuff Frank found is good and I have used it on an A12, an AAR and a T/A and will use it on a Daytona and a 70 Charger.
BTW - an earlier poster commented on Charger tail panels being flat black and not Organosol. This is 50% correct. The factory engineering shows both paints as an option for the tail panels...I think it may have depended on the plant (state law?). My original stuff also varies in texture from car to car. This is probably because of a lot of different factors - pressure, thinner, temp etc. etc.
As for the person that called Frank a "tool". I could only wish for more tools like him in our hobby - I would fill my toolbox right up with those tools any day. He sells a lot of great paints - he is not a painter. He will tell you he is not a painter. An experienced painter is the only one I would ask about paint compatibility. A lot of people think if they spend 20 bucks they are entitled to 20 hours of information - He has always been generous to the hobby with information on original cars but can't afford to answer hours of questions that many people ask him (and Roger) every day. I myself have kept him on the phone with questions far too long and realize - this dude is trying to run a business and make a living. Enuff said about that - time for a beer!
[Re: DAYCLONA]
#21276
07/24/09 04:23 PM
07/24/09 04:23 PM
Posts: 1,120 Ont, Canada
moparo
Ont, Canada
I never had to ask a paint supplier how to use the products they sell. Any painter which knows about these paints will be able to apply Franks paints.
I have seen his organosol put on top base clear and acr. enamel.
What does this have to do with Re: Organosol "The Bulletin" January 15, 1969 anyway?
performancecarrestorations.com
[Re: Alaska_A12]
#21278
12/14/09 02:46 AM
12/14/09 02:46 AM
A12
N.E. OHIO, USA
I remember the question used to be "what paint was used on the lift-off-hood?" It seems that it's pretty much a fact that it was and is organosol so for those of us that have used the word ORGANOSOL and never really knew what the heck it is here is the definition: Go here and click on the little speaker [< so you can pronounce it like an expert | V http://mw1.meriam-webster.com/medical/organosol Main Entry: or·gan·o·sol Pronunciation: \ȯr-ˈgan-ə-ˌsäl, -ˌsȯl\ Function: noun : a sol in which an organic liquid forms the dispersion medium 1. organosol definition or·ga·no·sol (ôr gan′ə säl′) noun a colloid consisting of a solid within an organic liquid. 2. organosol [ȯr′gan·ə‚sȯl] (materials) Finely divided or colloidal suspension of insoluble material in a suspending organic liquid; known as plastisol when the solid is a synthetic resin suspended in an organic liquid; used for coatings, moldings, and casting of films. A dispersion of very finely divided resin particles that are suspended in an organic-liquid mixture which cannot dissolve the resin at normal temperatures. 3. Organosol... A plastisol to which a solvent has been added. 4. organosol Pronunciation: ōr-gan′ō-sol A hydrosol with an organic liquid instead of water as the dispersion means. MikeR
[Re: jrwoodjoe]
#21279
11/16/10 02:09 PM
11/16/10 02:09 PM
Posts: 3,624 Fort Worth, Texas
xs29j8
Fort Worth, Texas
Just bumping this up to see if anyone has anything new to add on this subject since I will need to advise my paint guy.
Thanks, Joe
I just bought a very expensive gallon of the DDL9355 Organosol Black Acrylic Lacquer for doing the taillight panels of my cars, as well as my Challenger T/A hood & 69 Road Runner hoods.
Bumping the thread to see what the latest advice on applying the DDL9355 lacquer over a modern PPG base/clear coat paint would be.
A few questions too...
1) Is a barrier required because it is a lacquer?
2) What is the shelf life of an un-opened can of DDL9355... I have another can of DDL9355 about 10 years old or so, and when shaken it sloshes around like it was just canned. Thinking about trying this old batch first, and resealing it in four quart or eight pint cans immediately after opening... thoughts? What is the oldest mix anyone has successfully used?
3) With the old batch I bought DTL876 thinner, what thinners are available now that can be used?
4) Are the old and new batch likely to be different due to substitutions of components?
5) Are other additives like hardeners, accelerators, etc normally required when applying DDL9355? Does it depend whether is a hood or taillight panel?
6) What is the latest on modern non-lacquer Organosol substitutes? Safer to apply on modern paints?
Any application advice or links to good material would be appreciated. I am gathering this information to give to the painter, who has not sprayed Organosol before...
Thanks... Allen
[Re: xs29j8]
#21282
11/16/10 09:56 PM
11/16/10 09:56 PM
Posts: 3,319 Chicago Burbs
sthemi
Chicago Burbs
Also a Hobby painter here, Tom is right on his suggestions. Currently available thinners will work. The slowest thinner is DTL 105, I believe.. Sealing the modern paint is critical. Laquer will try to eat into the lower coats and cause all kinds of problems.. On my Roadrunner I used the DP epoxy primer with the textured Laquer on the dash, good results.. For the hood, I used the Concept version of Organisol, (DCC) on top of the clear coat with no sealer it came out looking good as well. I didnt want to risk the laquer on top of the modern paint.
[Re: ThermoQuad]
#21284
11/19/10 07:54 PM
11/19/10 07:54 PM
A12
N.E. OHIO, USA
I also like the use of the Concept version of Organisol (DCC) for hood treatments such as the Roadrunner & GTX. Note the texture finish is not the same as the DDL, but it is what's best unless its a 100 pt show poodle.
The person that painted my '69 GTX thinks the same way as you Tom. When the hood stripes were being painted I sent everything I had and everything from (early on in) this thread to him and he just couldn't bring himself to using any of the formulas for the '69 GTX hood stripes He mixed up what he felt was correct and sprayed it and I never did get the final mix info from him........so far. I think it's close to correct, well it's porous enough like I remember my RR was back in '69 for the Simonize wax to make a mess of the edges
MikeR
[Re: ThermoQuad]
#21285
11/19/10 08:11 PM
11/19/10 08:11 PM
Posts: 8,526 Tenn.
jrwoodjoe
Tenn.
Tom, thanks for posting the info and sharing it with others. Curious, what (if anything) do you do differently when spraying the DDC?
[Re: UCUDANT]
#21296
12/14/11 01:16 PM
12/14/11 01:16 PM
MOPARMIKE69
Nashville, TN
For those who think that original organosol was rough to the touch, here is a pic of an original 5600 mile A-12 bee hood. You can easily drag a rag across the hood and not have any catching. This is as good as it gets for how the finish of the hood really was.
[Re: MOPARMIKE69]
#21298
12/14/11 05:37 PM
12/14/11 05:37 PM
Posts: 5,160 Texas
dannysbee
Texas
Mike I have been telling them the same thing for years. The A12's were hoods were not painted with the same stuff the AAR's or T/A's hoods were painted with.
[Re: dannysbee]
#21299
12/14/11 06:47 PM
12/14/11 06:47 PM
A12
N.E. OHIO, USA
Danny, what were the A12's painted with?
MikeR
[Re: A12]
#21300
12/14/11 06:59 PM
12/14/11 06:59 PM
Posts: 5,160 Texas
dannysbee
Texas
Mike I don't know the code for it I just know the hoods did not have the texture that the restored cars have today. Possibly a flat black lacquer with a hot thinner. I got another question. Who painted the hoods the factory or the sub contractor that built the hoods?
[Re: dannysbee]
#21301
12/14/11 08:33 PM
12/14/11 08:33 PM
A12
N.E. OHIO, USA
Pretty sure the hoods were painted by the vendor (fixed it, #22)......with;
"2183385 Exterior Air Dry Organsol Paint AF5DX8 Black,"
The hoods were made in Canada in Toronto.
MikeR
[Re: A12]
#21302
12/14/11 10:35 PM
12/14/11 10:35 PM
Posts: 18,199 Mass
DAYCLONA
Mass
Pretty sure the factory painted the hoods......with;
MikeR
The Hoods were made in Canada, but Creative was the conversion point, did Creative Industries paint the hoods?
[Re: DAYCLONA]
#21303
12/14/11 11:29 PM
12/14/11 11:29 PM
A12
N.E. OHIO, USA
MikeR
Creative Industries didn't have anything to do with the A12's because the A12 package was an option to the base 383 RR and SB and it was mostly additions and deletions to items that were all capable of being installed on the standard assembly line. The only items that didn't or couldn't be put on the normal running assembly line were the carbs, air cleaner, hood pins and the hood/hood pin bezels, and scoop decals....the 440 engine installed just like a 383 or Hemi along with the trans, Dana, brakes, etc. just a few things at the end of the standard assembly line.
MikeR
[Re: dannysbee]
#21305
12/15/11 02:51 AM
12/15/11 02:51 AM
A12
N.E. OHIO, USA
The hoods were painted by the vendor (fixed it #22)......with;
MikeR
And there ls the problem everyone is pretty sure but no one knows for sure. The hoods could have been been painted by the supplier possibly the factory. Could have been organisol or possibly the paint they used for the blackout on the front of the cars. Until someone finds someone that was involved in the building of the cars and painting of the hoods, I will have to believe in what I found on the A12 car I purchased in 1974 and the original hoods I bought over the years. A flat black paint with little to no texture.
Danny I'll just say: (I fixed it, I should have read the bulletin I posted years ago duh)
I'm sure the hoods were painted with:
MikeR
[Re: MOPARMIKE69]
#21306
12/15/11 10:29 AM
12/15/11 10:29 AM
Posts: 5,160 Texas
dannysbee
Texas
I'm sure the factory painted the hoods with:
MikeR
Mike R I would like to see an example of the paint code you have on a hood. The picture posted is very close to originals I have seen.
[Re: dannysbee]
#21307
12/15/11 11:01 AM
12/15/11 11:01 AM
A12
N.E. OHIO, USA
MikeR
Danny I agree with you and Mike and everyone else that says the A12 hoods and even the '68 and '69 RR GTX etc., hood treatment did NOT have much texture if any The question I was trying to answer was if the hood manufacture painted the hoods and if the paint was organosol. The part number (2183385), paint code and the description above were right from a factory document for the A12 lift off hoods......can anyone check that AFX5DF code and part number to see what it might be?
Thanks,
MikeR
and here even the underside of a 1969 media photo of an A12 hood show NO texture in the paint. I know it's the underside but it would show some in spots if it did. I have an original A12 hood and the bezels have never been removed when I do remove them I'll post photos but we all know there will be very little if much texture
[Re: A12]
#21308
12/15/11 12:33 PM
12/15/11 12:33 PM
MOPARMIKE69
Nashville, TN
The hoods were recieved at the factory already painted by the supplier. See line 22 of attached factory bulletin.
[Re: MOPARMIKE69]
#21310
12/15/11 12:45 PM
12/15/11 12:45 PM
A12
N.E. OHIO, USA
Now there's a real brain fart on my part, should have re-read that page or at least remembered it, thanks Mike.
but the paint info is what was spec'd for the hoods, that one I know for sure.
duh on me the hoods were painted by the vendor in Toronto and handled with care
MikeR
[Re: MOPARMIKE69]
#21311
12/15/11 12:49 PM
12/15/11 12:49 PM
A12
N.E. OHIO, USA
Very close???? That is an original 5600 mile untouched hood. Not only is it close, it is the real deal, exactly as it left the factory, untouched hood. (with incorrect facing decals, Thats for you A12 )
That's twice today, first with Step 22 and now the decals......I'm logging off
MikeR
[Re: MOPARMIKE69]
#21312
12/15/11 12:49 PM
12/15/11 12:49 PM
Posts: 5,160 Texas
dannysbee
Texas
Mike I would have to see and touch it before I would say it is exactly. Certainly not trying to cast any doubt.  That is how the decals look "right" to me.
[Re: ThermoQuad]
#21316
04/11/12 04:49 PM
04/11/12 04:49 PM
A12
N.E. OHIO, USA
Has anyone asked their local ppg dealer for "2183385 Exterior Air Dry Organsol Paint AF5DX8 Black??????????????????????,"
or do i have to do it...
x2 Paleeeeeze
[Re: ThermoQuad]
#21317
04/11/12 05:47 PM
04/11/12 05:47 PM
Posts: 4,720 North Central USA (MN-WI area)
MuscleMopars
You do it.....please....and get back to us...
Thanks, Eric email eric@musclemopars.com 715-426-HEMI (Shop) 612-669-CARS (Cell and Texts)Go to my Moparts "Profile" to see my web site
[Re: ThermoQuad]
#21322
04/27/12 06:47 AM
04/27/12 06:47 AM
Posts: 5,190 upstate western ny
sogtx
upstate western ny
Ok , getting ready to paint a12 hood ....
not going organisol , rather shoot myself .
Anything new on alternatives . Do the decals stick ?
Is there minimal metal flake hiding on an orig a12 hood ?
I dont think so , but ..... Figured id stir it up.
Might just use a SEM product ... We can argue about what was and is for years ..
I like it smooth , my 71 orig ag was smooth , No towels stuck , but wax did.
The hood decals need to lay on flat to the scoop A12 stickers would never had stAyed on all these Years, if been painted with textured..
[Re: sogtx]
#21323
07/02/12 04:37 PM
07/02/12 04:37 PM
Posts: 1,032 Ohio
dobie
Ohio
Hey guys, according to my shop, the DDL 9355 is not a working code.
Any other ideas?
1968 Plymouth Road Runner
383 4 speed
[Re: dannysbee]
#21325
07/04/12 07:01 PM
07/04/12 07:01 PM
Posts: 409 Kentucky USA
RR6BBL1969
Kentucky USA
PPG got the paint for mine and it was exactly like the orogonal.
[Re: sailboat]
#21331
03/30/13 01:44 PM
03/30/13 01:44 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
When we did an aar hood, followed this bulletin exactly and my dad sprayed it. He was painting cars weekly in laquer at a body shop he owned in the 70s... anyways it came out more textured. When I spray my challenger t/a clone, I'll be using something other than the original formula to get it more smooth.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: ThermoQuad]
#21334
05/17/13 08:35 AM
05/17/13 08:35 AM
Posts: 1,032 Ohio
dobie
Ohio
So, Im confused....
Is the proper stuff DDL9355 or DDL9359?
383 4 speed
[Re: A12]
#21336
02/21/14 07:02 PM
02/21/14 07:02 PM
A12
N.E. OHIO, USA
