Page 4 of 7 1 2 3 4 5 6 7
Re: Organosol "The Bulletin" January 15, 1969 [Re: DAYCLONA] #21274
07/22/09 08:19 PM
07/22/09 08:19 PM
Ontario, Canada
FJ5_Fish Offline
FJ5_Fish  Offline
Ontario, Canada
I have a bunch of low mile original cars - a bunch with Organosol painted areas. The stuff that Badalson sells is as close to dead nuts as you can buy if applied properly. There are not too many people that painted a lot of lacquer back in the 60's and 70's around these days. Painting lacquer is totally unique and what techniques that apply to acrylic urethane, base-clear etc. does not look right with laquer. Original Organosol has suede (for texture) and a tiny bit of metallic in it - it's there, look. Roger did devise an acrylic urethane formula when the original stuff disappeared - it was decent but a little too textured. The stuff Frank found is good and I have used it on an A12, an AAR and a T/A and will use it on a Daytona and a 70 Charger.
BTW - an earlier poster commented on Charger tail panels being flat black and not Organosol. This is 50% correct. The factory engineering shows both paints as an option for the tail panels...I think it may have depended on the plant (state law?). My original stuff also varies in texture from car to car. This is probably because of a lot of different factors - pressure, thinner, temp etc. etc.
As for the person that called Frank a "tool". I could only wish for more tools like him in our hobby - I would fill my toolbox right up with those tools any day. He sells a lot of great paints - he is not a painter. He will tell you he is not a painter. An experienced painter is the only one I would ask about paint compatibility. A lot of people think if they spend 20 bucks they are entitled to 20 hours of information - He has always been generous to the hobby with information on original cars but can't afford to answer hours of questions that many people ask him (and Roger) every day. I myself have kept him on the phone with questions far too long and realize - this dude is trying to run a business and make a living. Enuff said about that - time for a beer!
Re: Organosol "The Bulletin" January 15, 1969 [Re: ThermoQuad] #21275
07/22/09 09:17 PM
07/22/09 09:17 PM
Long Island NY
ErikR Offline
ErikR  Offline
Long Island NY
Tom, please post some pics! I'll have the NOS pint waiting for when you can tell me how to spray my car properly. Thanks again
Re: Organosol "The Bulletin" January 15, 1969 [Re: DAYCLONA] #21276
07/24/09 04:23 PM
07/24/09 04:23 PM
Ont, Canada
moparo Offline
moparo  Offline
Ont, Canada
I never had to ask a paint supplier how to use the products they sell. Any painter which knows about these paints will be able to apply Franks paints.
I have seen his organosol put on top base clear and acr. enamel.
What does this have to do with Re: Organosol "The Bulletin" January 15, 1969 anyway?
performancecarrestorations.com
Re: Organosol "The Bulletin" January 15, 1969 [Re: moparo] #21277
12/11/09 05:37 PM
12/11/09 05:37 PM
The Last Frontier
Alaska_A12 Offline
Alaska_A12  Offline
The Last Frontier
Resurrecting this thread. About to have my hood done.
ANYTHING NEW TO ADD?
______________________________________________ http://regcars.homestead.com/car107.html
Re: Organosol "The Bulletin" January 15, 1969 [Re: Alaska_A12] #21278
12/14/09 02:46 AM
12/14/09 02:46 AM
N.E. OHIO, USA
A12 Online content OP
A12  Online Content OP
N.E. OHIO, USA
I remember the question used to be "what paint was used on the lift-off-hood?" It seems that it's pretty much a fact that it was and is organosol so for those of us that have used the word ORGANOSOL and never really knew what the heck it is here is the definition:
Go here and click on the little speaker [< so you can pronounce it like an expert
V
http://mw1.meriam-webster.com/medical/organosol
Main Entry: or·gan·o·sol
Pronunciation: \o&#775;r-&#712;gan-&#601;-&#716;säl, -&#716;so&#775;l\
Function: noun
: a sol in which an organic liquid forms the dispersion medium
1. organosol definition
or·ga·no·sol (ôr gan&#8242;&#601; säl&#8242;)
noun
a colloid consisting of a solid within an organic liquid.
2. organosol [&#559;r&#8242;gan·&#601;‚s&#559;l]
(materials)
Finely divided or colloidal suspension of insoluble material in a suspending organic liquid; known as plastisol when the solid is a synthetic resin suspended in an organic liquid; used for coatings, moldings, and casting of films.
A dispersion of very finely divided resin particles that are suspended in an organic-liquid mixture which cannot dissolve the resin at normal temperatures.
3. Organosol...
A plastisol to which a solvent has been added.
4. organosol
Pronunciation: &#333;r-gan&#8242;&#333;-sol
A hydrosol with an organic liquid instead of water as the dispersion means.
MikeR
Re: Organosol "The Bulletin" January 15, 1969 [Re: jrwoodjoe] #21279
11/16/10 02:09 PM
11/16/10 02:09 PM
Fort Worth, Texas
xs29j8 Offline
xs29j8  Offline
Fort Worth, Texas
Just bumping this up to see if anyone has anything new to add on this subject since I will need to advise my paint guy.
Thanks, Joe
I just bought a very expensive gallon of the DDL9355 Organosol Black Acrylic Lacquer for doing the taillight panels of my cars, as well as my Challenger T/A hood & 69 Road Runner hoods.
Bumping the thread to see what the latest advice on applying the DDL9355 lacquer over a modern PPG base/clear coat paint would be.
A few questions too...
1) Is a barrier required because it is a lacquer?
2) What is the shelf life of an un-opened can of DDL9355... I have another can of DDL9355 about 10 years old or so, and when shaken it sloshes around like it was just canned. Thinking about trying this old batch first, and resealing it in four quart or eight pint cans immediately after opening... thoughts? What is the oldest mix anyone has successfully used?
3) With the old batch I bought DTL876 thinner, what thinners are available now that can be used?
4) Are the old and new batch likely to be different due to substitutions of components?
5) Are other additives like hardeners, accelerators, etc normally required when applying DDL9355? Does it depend whether is a hood or taillight panel?
6) What is the latest on modern non-lacquer Organosol substitutes? Safer to apply on modern paints?
Any application advice or links to good material would be appreciated. I am gathering this information to give to the painter, who has not sprayed Organosol before...
Thanks... Allen
Re: Organosol "The Bulletin" January 15, 1969 [Re: FJ5_Fish] #21280
11/16/10 04:22 PM
11/16/10 04:22 PM
Answering the call of the wild
ThermoQuad Offline
ThermoQuad  Offline
Here is the latest revision
Organisol Black Revised 11-2010
DDL9359
Disclaimer: I am no expert, but I am a painter and I have done my fair share of wresting with this paint. I have no experience putting DDL9355 over catalyzed paints as I was taught the arts when lacquer and enamel were all we had. When I paint it now it’s always on a primer or black lacquer surface The problem I see is this lacquer paint needs to be applied wet and thin which means a lot of solvent will try to bite into the enamel or urethane surface it’s being applied to.
You must lay the paint down wet or the texture will stand up instead of lay down and you will have an extremely rough finish that attracts everything.
Paint surfaces horizontal if possible
Use the slowest thinner and add some retarder as well if it is above 80 degrees. If possible use over black primer like DP90
Patience.
Allow surfaces to dry for at least 30 days before painting cover coats. This is important.
Works best painted over a black painted surface
Black DP90 is ok but black paint is better
Put 2 light but wet cover coats of semi gloss black lacquer over colored primers
Allow to dry at least 24 hrs or more before organosoling,
Use a gun with a big tip 1.6mm or larger
Cross coat the large area surfaces in 3 directions –eliminates streaking of texture diag first, short length, long length with large overlapping passes. It must go on wet!
Test spray before committing to car. Practice a little. Use SLOW thinner !!!! Lay on WET!
Patience!!!!! Thin 125%, 150% last 2 coats
After getting full coverage of texture typically 4 coats thin each progressive coat to 150% Use your judgment Think about 6 -8 coats.
Allow each coat to dry for at least 30 min.
Patience.
Texture must cover surface completely-there should be no gaps in the texture. The purpose of laying it on cross coating & wet is to get the texture to lay down flat.
Edge it in with a touch up gun first
Use fine line tape on all paint edge breaks
Do the bottom side of the hood first-part of your practice
Paint all other surfaces at the same time as the top side of the hood.
Across the tops of the fender & across the front header panel be sure to add 1-2 extra coats of Organosol to resist wear of the paint from stones, fender covers etc..
Notes for the pic:
This was real NOS organosol paint.
Just to paint this hood took 4 hours.
Re: Organosol "The Bulletin" January 15, 1969 [Re: ThermoQuad] #21281
11/16/10 08:04 PM
11/16/10 08:04 PM
Fort Worth, Texas
xs29j8 Offline
xs29j8  Offline
Fort Worth, Texas
Thanks for the update Tom... I was hoping you would chime in!
Re: Organosol "The Bulletin" January 15, 1969 [Re: xs29j8] #21282
11/16/10 09:56 PM
11/16/10 09:56 PM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
Also a Hobby painter here,
Tom is right on his suggestions. Currently available thinners will work.
The slowest thinner is DTL 105, I believe..
Sealing the modern paint is critical. Laquer will try to eat into the lower coats and cause all kinds of problems..
On my Roadrunner I used the DP epoxy primer with the textured Laquer on the dash, good results..
For the hood, I used the Concept version of Organisol, (DCC) on top of the clear coat with no sealer it came out looking good as well.
I didnt want to risk the laquer on top of the modern paint.
Re: Organosol "The Bulletin" January 15, 1969 [Re: sthemi] #21283
11/19/10 05:49 PM
11/19/10 05:49 PM
ThermoQuad Offline
ThermoQuad  Offline
I also like the use of the Concept version of Organisol (DCC) for hood treatments such as the Roadrunner & GTX. Note the texture finish is not the same as the DDL, but it is what's best unless its a 100 pt show poodle.
Re: Organosol "The Bulletin" January 15, 1969 [Re: ThermoQuad] #21284
11/19/10 07:54 PM
11/19/10 07:54 PM
N.E. OHIO, USA
N.E. OHIO, USA
The person that painted my '69 GTX thinks the same way as you Tom. When the hood stripes were being painted I sent everything I had and everything from (early on in) this thread to him and he just couldn't bring himself to using any of the formulas for the '69 GTX hood stripes He mixed up what he felt was correct and sprayed it and I never did get the final mix info from him........so far. I think it's close to correct, well it's porous enough like I remember my RR was back in '69 for the Simonize wax to make a mess of the edges
MikeR
Re: Organosol "The Bulletin" January 15, 1969 [Re: ThermoQuad] #21285
11/19/10 08:11 PM
11/19/10 08:11 PM
Tenn.
jrwoodjoe Offline
jrwoodjoe  Offline
Tenn.
Tom, thanks for posting the info and sharing it with others. Curious, what (if anything) do you do differently when spraying the DDC?
Re: Organosol "The Bulletin" January 15, 1969 [Re: jrwoodjoe] #21286
11/20/10 11:27 AM
11/20/10 11:27 AM
ThermoQuad Offline
ThermoQuad  Offline
You must lay the DCC on wet just like the regular DDL, with overlapping and cross coating. Then again any good painter always puts the paint down wet...that's the dance.
Re: Organosol "The Bulletin" January 15, 1969 [Re: ThermoQuad] #21287
09/14/11 11:29 PM
09/14/11 11:29 PM
N.E. OHIO, USA
N.E. OHIO, USA
for someone that was looking for this
MikeR
Re: Organosol "The Bulletin" January 15, 1969 [Re: A12] #21288
09/15/11 12:24 PM
09/15/11 12:24 PM
pa.
dan9 Offline
dan9  Offline
pa.
My buddy at the paint store took a lot of interest in trying to find the replacement for the original organosol. He contacted PPG and they sold me a metalic black from a newer Chrysler product and a can of flattening agent in a kinda paste form. The black metalic flakes were colored, not just the old style silver flakes. It also came with directions as to the amount of agent to be used to get to the desired finish. I don't know that it is 100% they way they left the factory but i am very happy with mine. It is hard to tell which are right but you sure can tell when they are wrong.
Re: Organosol "The Bulletin" January 15, 1969 [Re: dan9] #21289
09/15/11 12:55 PM
09/15/11 12:55 PM
Fort Worth, Texas
xs29j8 Offline
xs29j8  Offline
Fort Worth, Texas
My C500 taillight panel was painted with the old batch of organosol that I bought many years ago. The gallon container had never been opened, and the can had been stored in climate controlled conditions. The painter mixed the paint with a shaker prior to opening, and said it looked totally fresh when he opened the can... like it had been canned the day before. He immediately resealed the contents in four one quart cans, using one later to paint the taillight panel.
The lacquer based organosol was applied without a problem:
Re: Organosol "The Bulletin" January 15, 1969 [Re: xs29j8] #21290
09/15/11 02:29 PM
09/15/11 02:29 PM
Mopar World Headquarters
P1970HeMICuDA Offline
Over the past few months, I have used Urethane reducer to thin some lacquer based products- results have been excellent on top of Base clear paint.
Re: Organosol "The Bulletin" January 15, 1969 [Re: P1970HeMICuDA] #21291
12/13/11 05:58 PM
12/13/11 05:58 PM
N.E. OHIO, USA
N.E. OHIO, USA
lots of good info in this thread
MikeR
Re: Organosol "The Bulletin" January 15, 1969 [Re: A12] #21292
12/13/11 06:23 PM
12/13/11 06:23 PM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
FYI A12 asked me to add this info to this post so.....
I used something my painter and I found, Planet colors Rugged Tones, Black Texture (Durable/High wear) PCR2 Paint. this pic shows better than their actual paint chart sample which appeared more like bed liner. It's a modern paint, mimics organisol very well, should resist wax, can be applied over the actual paint. For those who want less texture it may be worth experimenting with
Re: Organosol "The Bulletin" January 15, 1969 [Re: UCUDANT] #21293
12/13/11 06:43 PM
12/13/11 06:43 PM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
An old weathered 1972 Cuda V21 car fender close up
