Metal debris in my engine #2047543
04/05/16 11:48 PM
04/05/16 11:48 PM
fredericksburg,va
cudaman1969 Offline OP
fredericksburg,va
Never had an engine blow up or wipe a cam, so I need some ideas on how to clean up the inside of block. I bought a 5.7 with a piggy-backed rod bearing and the metal grit is everywhere (not sure if lifters would be contaminated). Everything is coming apart, so what's the best way of cleaning? What about cam bearings?
Re: Metal debris in my engine [Re: cudaman1969] #2047603
04/06/16 01:07 AM
04/06/16 01:07 AM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Use degreaser, hot soapy water, solvent ect to break down the oil film and use engine cleaning brushes and go thru all the oil galleries.
Cam bearings should be replaced if they are scratched up.
Re: Metal debris in my engine [Re: cudaman1969] #2047650
04/06/16 02:31 AM
04/06/16 02:31 AM
fredericksburg,va
fredericksburg,va
Not sure I got a good deal now. I'll do what you say with cleaning. What about sticking magnets on the block while
cleaning?
Re: Metal debris in my engine [Re: cudaman1969] #2047657
04/06/16 02:44 AM
04/06/16 02:44 AM
Tacoma, Washington USA
Adam71Charger Offline
The best solvent for sludge is lacquer thinner! Cuts through absolutely anything instantly
Re: Metal debris in my engine [Re: cudaman1969] #2047679
04/06/16 03:48 AM
04/06/16 03:48 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Hot tank? Bueller? The time you save will be worth it.
Re: Metal debris in my engine [Re: cudaman1969] #2047685
04/06/16 04:05 AM
04/06/16 04:05 AM
Riverside, Ca
R70RUNNER Offline
R70RUNNER  Offline
Riverside, Ca
Modern Hemi I assume, don't forget to toss the intake manifold in the trash if there's any doubt about the extend of damage and if it went through the combustion chamber. The debris is known to get into the plastic and then come back out into the new build. It's impossible to clean them.
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
Re: Metal debris in my engine [Re: R70RUNNER] #2047877
04/06/16 12:37 PM
04/06/16 12:37 PM
fredericksburg,va
fredericksburg,va
From looking so far, basically crank journal and rod eat up, still running before getting pulled. Can feel metal partials imbedded in other rod bearings, like sandpaper. What's the filter for, chunks?
Re: Metal debris in my engine [Re: cudaman1969] #2047892
04/06/16 12:53 PM
04/06/16 12:53 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
The filter is for chunks that make it into the pan and pickup tube.
The trash that killed your bottom end never made it that far.
If you can feel it the filter would have caught it.
- Stu Harmon
Re: Metal debris in my engine [Re: cudaman1969] #2047916
04/06/16 01:28 PM
04/06/16 01:28 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Unless your engine has a filter without a bypass, over 80% of your oil is not being filtered.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Metal debris in my engine [Re: cudaman1969] #2048020
04/06/16 03:20 PM
04/06/16 03:20 PM
fredericksburg,va
fredericksburg,va
I've come to the conclusion filters are useless on race engines then, just a restriction. Big Magnet in the pan would work better. Lol
Re: Metal debris in my engine [Re: cudaman1969] #2048050
04/06/16 03:53 PM
04/06/16 03:53 PM
Houston
I
it's Bob Offline
it's Bob  Offline
I
Houston
Well, there are a lot of non-magnetic, non-ferrous metals in an engine these days.
Re: Metal debris in my engine [Re: cudaman1969] #2048237
04/06/16 07:44 PM
04/06/16 07:44 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The lifters will be contaminated too , I spun a bearing on a 383 many years ago , it had a cam and lifters I just put in a few hundred miles before the bearing spun. I opened them up and flush them with brake wash and ran the solution thru a white rag , every lifter had metal in it .
Re: Metal debris in my engine [Re: JohnRR] #2048257
04/06/16 08:07 PM
04/06/16 08:07 PM
fredericksburg,va
fredericksburg,va
I'll have to look and see if I can pull the roller lifters apart, major bummer.
Re: Metal debris in my engine [Re: cudaman1969] #2048258
04/06/16 08:08 PM
04/06/16 08:08 PM
Park Forest, IL
slantzilla Offline
Happy Birthday slantzilla  Offline
Park Forest, IL
Another vote for having it tanked. It's really not that expensive to start with.
Re: Metal debris in my engine [Re: slantzilla] #2048353
04/06/16 10:06 PM
04/06/16 10:06 PM
fredericksburg,va
fredericksburg,va
Do you mean hot tanked?
Re: Metal debris in my engine [Re: cudaman1969] #2048373
04/06/16 10:28 PM
04/06/16 10:28 PM
PA.
"Little"John
"Little"John
PA.
Most hot tanking is now discontinued because of pollution concerns but most machine shops have updated ways of cleaning blocks that come out very nice. They still need scrubbed at home before assembly but it a simple process after they do their thing.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
