Re: Metal debris in my engine
[Re: cudaman1969]
#2047685
04/06/16 04:05 AM
04/06/16 04:05 AM
Posts: 4,861 Riverside, Ca
R70RUNNER
Riverside, Ca
Modern Hemi I assume, don't forget to toss the intake manifold in the trash if there's any doubt about the extend of damage and if it went through the combustion chamber. The debris is known to get into the plastic and then come back out into the new build. It's impossible to clean them.
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
[Re: R70RUNNER]
#2047877
04/06/16 12:37 PM
04/06/16 12:37 PM
Posts: 8,337 fredericksburg,va
cudaman1969
fredericksburg,va
Modern Hemi I assume, don't forget to toss the intake manifold in the trash if there's any doubt about the extend of damage and if it went through the combustion chamber. The debris is known to get into the plastic and then come back out into the new build. It's impossible to clean them. From looking so far, basically crank journal and rod eat up, still running before getting pulled. Can feel metal partials imbedded in other rod bearings, like sandpaper. What's the filter for, chunks?
[Re: cudaman1969]
#2047892
04/06/16 12:53 PM
04/06/16 12:53 PM
Posts: 28,069 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
From looking so far, basically crank journal and rod eat up, still running before getting pulled. Can feel metal partials imbedded in other rod bearings, like sandpaper. What's the filter for, chunks? The filter is for chunks that make it into the pan and pickup tube. The trash that killed your bottom end never made it that far. If you can feel it the filter would have caught it.
[Re: cudaman1969]
#2047916
04/06/16 01:28 PM
04/06/16 01:28 PM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Modern Hemi I assume, don't forget to toss the intake manifold in the trash if there's any doubt about the extend of damage and if it went through the combustion chamber. The debris is known to get into the plastic and then come back out into the new build. It's impossible to clean them. From looking so far, basically crank journal and rod eat up, still running before getting pulled. Can feel metal partials imbedded in other rod bearings, like sandpaper. What's the filter for, chunks? Unless your engine has a filter without a bypass, over 80% of your oil is not being filtered.
[Re: cudaman1969]
#2048237
04/06/16 07:44 PM
04/06/16 07:44 PM
Posts: 75,083 U.S.S.A.
JohnRR
U.S.S.A.
Never had an engine blow up or wipe a cam, so I need some ideas on how to clean up the inside of block. I bought a 5.7 with a piggy-backed rod bearing and the metal grit is everywhere (not sure if lifters would be contaminated). Everything is coming apart, so what's the best way of cleaning? What about cam bearings? The lifters will be contaminated too , I spun a bearing on a 383 many years ago , it had a cam and lifters I just put in a few hundred miles before the bearing spun. I opened them up and flush them with brake wash and ran the solution thru a white rag , every lifter had metal in it .
[Re: JohnRR]
#2048257
04/06/16 08:07 PM
04/06/16 08:07 PM
cudaman1969
fredericksburg,va
Never had an engine blow up or wipe a cam, so I need some ideas on how to clean up the inside of block. I bought a 5.7 with a piggy-backed rod bearing and the metal grit is everywhere (not sure if lifters would be contaminated). Everything is coming apart, so what's the best way of cleaning? What about cam bearings? The lifters will be contaminated too , I spun a bearing on a 383 many years ago , it had a cam and lifters I just put in a few hundred miles before the bearing spun. I opened them up and flush them with brake wash and ran the solution thru a white rag , every lifter had metal in it . I'll have to look and see if I can pull the roller lifters apart, major bummer.
[Re: cudaman1969]
#2048258
04/06/16 08:08 PM
04/06/16 08:08 PM
Posts: 20,204 Park Forest, IL
slantzilla
Park Forest, IL
Another vote for having it tanked. It's really not that expensive to start with.
[Re: cudaman1969]
#2048373
04/06/16 10:28 PM
04/06/16 10:28 PM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Another vote for having it tanked. It's really not that expensive to start with. Do you mean hot tanked? Most hot tanking is now discontinued because of pollution concerns but most machine shops have updated ways of cleaning blocks that come out very nice. They still need scrubbed at home before assembly but it a simple process after they do their thing.
