413 Truck Block Date Identification?? #2039466
03/27/16 12:44 AM
03/27/16 12:44 AM
Louisville, KY
E
E-Ticket Offline OP
E-Ticket  Offline OP
E
Louisville, KY
This truck engine I have.....I guess Chrysler in their infinite wisdom and stamping skills decided that this is sufficient enough to identify this block as a 1977??? Anyone else seen any similar casting stamps like this on a 1977 engine?
"Fat drunk and stupid is no way to go through life son......"
http://www.youtube.com/watch?v=bK-Dqj4fHmM
Re: 413 Truck Block Date Identification?? [Re: E-Ticket] #2039562
03/27/16 09:38 AM
03/27/16 09:38 AM
Des Moines IA
Soopernaut Offline
Soopernaut  Offline
Des Moines IA
Could it be a 71?
1970 Dodge d100/eventually going on a 77 D100 frame
Re: 413 Truck Block Date Identification?? [Re: E-Ticket] #2039608
03/27/16 11:24 AM
03/27/16 11:24 AM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
I'd guess it's 71
Re: 413 Truck Block Date Identification?? [Re: E-Ticket] #2039778
03/27/16 03:37 PM
03/27/16 03:37 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
There's a difference between stamped numbers and raised casting numbers.
Are there any other stamped numbers on the block i.e. data pad or pan rail? By "stamped" I mean actually stamped, not raised casting numbers.
Re: 413 Truck Block Date Identification?? [Re: E-Ticket] #2039935
03/27/16 07:05 PM
03/27/16 07:05 PM
Louisville, KY
E
E-Ticket Offline OP
E-Ticket  Offline OP
E
Louisville, KY
Yep....I should have clarified that as "raised casting".... In looking at it, it looks more like a 1 to me more so than a 7 but I was told it was a 77 engine...??
Re: 413 Truck Block Date Identification?? [Re: E-Ticket] #2040133
03/28/16 12:05 AM
03/28/16 12:05 AM
ND
dodgedon Offline
dodgedon  Offline
ND
I know you could get a 413 in 75. Could this be a warranty block? My dad has a 66 CT800 that had a warranty block installed in the 70's. I will check it out for sure, as i believe he has the paper work for it still.
I thought I should correct this...I believe you could get a 413 in the 77 D800.
67 Charger 383 auto
75 Dodge CNT 800 CAT Diesel
2012 Ram Crew cab 5.7 4x4
Re: 413 Truck Block Date Identification?? [Re: E-Ticket] #2040193
03/28/16 01:07 AM
03/28/16 01:07 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Maybe 71 was the last casting date for the 413? Mopar might cast a load of them and the supply lasted through nearly to the end? The only things the 413 was available in were big trucks and RV chassis, how many do you suppose they expected to sell with special order 413s? Some of the end production trucks and RVs came with 440s, which could indicate they finally ran out of 413 blocks and filled the remaining orders with 440s.
I know it wasn't unusual to see Dodge chassis under RVs that were 2-3 year old manufactured chassis sold under the newer RVs. It would not be out of the realm of believing Mopar used a warehouse full of old 413 castings until they were gone. Gene
Re: 413 Truck Block Date Identification?? [Re: E-Ticket] #2040233
03/28/16 02:30 AM
03/28/16 02:30 AM
Louisville, KY
E
E-Ticket Offline OP
E-Ticket  Offline OP
E
Louisville, KY
I'm not up on this era of the 413's and it seems like I have seen these engine's in the heavier trucks (D400 & up trucks) and RV's after 71 through 77 or so, so I guess any thing is possible?? The more I look at the number, the more I am thinking it is a 71 motor....??
Re: 413 Truck Block Date Identification?? [Re: E-Ticket] #2040341
03/28/16 11:50 AM
03/28/16 11:50 AM
ND
dodgedon Offline
dodgedon  Offline
ND
I think it looks like 71 also. I agree the 440's were used in RV's in the late years but Never in the Large D series trucks bigger than D600. These 413's were not the typical Car and pickup style heads and water pump. More like industrial type engines... Extra heavy duty!
67 Charger 383 auto
Re: 413 Truck Block Date Identification?? [Re: E-Ticket] #2040560
03/28/16 05:47 PM
03/28/16 05:47 PM
Rio Linda, CA
Rio Linda, CA
Again, are there any stamped numbers on the data pad or pan rail?
Re: 413 Truck Block Date Identification?? [Re: E-Ticket] #2040817
03/28/16 11:24 PM
03/28/16 11:24 PM
Louisville, KY
E
E-Ticket Offline OP
E-Ticket  Offline OP
E
Louisville, KY
Here is a pic of the pad.
Re: 413 Truck Block Date Identification?? [Re: E-Ticket] #2040966
03/29/16 03:18 AM
03/29/16 03:18 AM
Rio Linda, CA
Rio Linda, CA
H is the year code for 1972, so the casting date is 11-5-71.
Re: 413 Truck Block Date Identification?? [Re: John_Kunkel] #2041660
03/30/16 01:46 AM
03/30/16 01:46 AM
Louisville, KY
E
E-Ticket Offline OP
E-Ticket  Offline OP
E
Louisville, KY
Thank You....!!!.... up
Re: 413 Truck Block Date Identification?? [Re: E-Ticket] #2042987
03/31/16 09:28 PM
03/31/16 09:28 PM
Louisville, KY
E
E-Ticket Offline OP
E-Ticket  Offline OP
E
Louisville, KY
OK.......looking at this picture of the engine in whole.....what do you see?? I413 Engine right??
Re: 413 Truck Block Date Identification?? [Re: E-Ticket] #2043209
04/01/16 12:14 AM
04/01/16 12:14 AM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
That is a 413 industrial.
Apparently they have very good/strong blocks that some say can be bored to 440 size but I've never read any proof of it
Re: 413 Truck Block Date Identification?? [Re: E-Ticket] #2043223
04/01/16 12:31 AM
04/01/16 12:31 AM
Louisville, KY
E
E-Ticket Offline OP
E-Ticket  Offline OP
E
Louisville, KY
Yep.....they say they are an underbored 440 with extra thick ribbing on the side of the block, no casting numbers, just the casting date, better known as the cold weather blocks that can be bored to a standard 426 or 440 bore sizes, have great steel cranks with extra thick forged balancers. Also say that they have very good LY rods in them.
Re: 413 Truck Block Date Identification?? [Re: E-Ticket] #2043229
04/01/16 12:40 AM
04/01/16 12:40 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
They also have some very funky heads... eek
JB Rhinehart, Realist
A-Body's RULE!
Re: 413 Truck Block Date Identification?? [Re: Rhinodart] #2043553
04/01/16 02:37 PM
04/01/16 02:37 PM
dogdays Offline
dogdays  Offline
And "they" might be completely full of $hit.
Do yourself a favor and sonic check the block before you start any plans. Otherwise the wisdom that "they" spew may be the same as all those "440 Hemis" that you hear about when talking to the ignorant.
Give a bunch of people anything out of the ordinary and they will make up a ton of stories about it and believe everything they invent.
R.
Re: 413 Truck Block Date Identification?? [Re: E-Ticket] #2043571
04/01/16 03:00 PM
04/01/16 03:00 PM
MA
Greg55_99 Offline
Greg55_99  Offline
MA
Since I have one of those 413's from back in the day, how does that waterpump housing work with those heads?
Greg
Re: 413 Truck Block Date Identification?? [Re: Greg55_99] #2043715
04/01/16 06:00 PM
04/01/16 06:00 PM
Rio Linda, CA
Rio Linda, CA
The water pump setup in that pic isn't correct, the industrial 413 has the water pump housing mounted high on the heads.
