Re: 413 Truck Block Date Identification??
[Re: E-Ticket]
#2039778
03/27/16 03:37 PM
03/27/16 03:37 PM
Posts: 25,757 Rio Linda, CA
John_Kunkel
Rio Linda, CA
There's a difference between stamped numbers and raised casting numbers.
Are there any other stamped numbers on the block i.e. data pad or pan rail? By "stamped" I mean actually stamped, not raised casting numbers.
[Re: E-Ticket]
#2040133
03/28/16 12:05 AM
03/28/16 12:05 AM
Posts: 516 ND
dodgedon
ND
I know you could get a 413 in 75. Could this be a warranty block? My dad has a 66 CT800 that had a warranty block installed in the 70's. I will check it out for sure, as i believe he has the paper work for it still.
I thought I should correct this...I believe you could get a 413 in the 77 D800.
67 Charger 383 auto 75 Dodge CNT 800 CAT Diesel 2012 Ram Crew cab 5.7 4x4
[Re: E-Ticket]
#2040341
03/28/16 11:50 AM
03/28/16 11:50 AM
Posts: 516 ND
dodgedon
ND
I think it looks like 71 also. I agree the 440's were used in RV's in the late years but Never in the Large D series trucks bigger than D600. These 413's were not the typical Car and pickup style heads and water pump. More like industrial type engines... Extra heavy duty!
[Re: E-Ticket]
#2040560
03/28/16 05:47 PM
03/28/16 05:47 PM
John_Kunkel
Rio Linda, CA
Yep....I should have clarified that as "raised casting".... In looking at it, it looks more like a 1 to me more so than a 7 but I was told it was a 77 engine...?? Again, are there any stamped numbers on the data pad or pan rail?
[Re: E-Ticket]
#2040966
03/29/16 03:18 AM
03/29/16 03:18 AM
John_Kunkel
Rio Linda, CA
H is the year code for 1972, so the casting date is 11-5-71.
[Re: E-Ticket]
#2043209
04/01/16 12:14 AM
04/01/16 12:14 AM
Posts: 4,254 Canada
WO23Coronet
Canada
That is a 413 industrial.
Apparently they have very good/strong blocks that some say can be bored to 440 size but I've never read any proof of it
[Re: Greg55_99]
#2043715
04/01/16 06:00 PM
04/01/16 06:00 PM
John_Kunkel
Rio Linda, CA
The water pump setup in that pic isn't correct, the industrial 413 has the water pump housing mounted high on the heads.
