Small block oil pan question #1982262
01/02/16 09:39 PM
01/02/16 09:39 PM
Seaford Delaware
JSR1485 Offline OP
JSR1485  Offline OP
Seaford Delaware
What is better to use in a Bracket car ?
Kevko M301 pan?
I have old Super Stock style pan with the tie rod tube or should I get a Stefs or Charlie's pan? or Milodon?
What do you guys use?
Switched to the dark side...
Re: Small block oil pan question [Re: JSR1485] #1982270
01/02/16 09:49 PM
01/02/16 09:49 PM
ccarson Offline
ccarson  Offline
I use a rear sump 8 qt Milodon truck pan.
But I dont have the stock K member and Recirculating ball steering to contend with.
Re: Small block oil pan question [Re: JSR1485] #1982276
01/02/16 10:01 PM
01/02/16 10:01 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
I have 2 kevco pans I like the kickout they have. I would think the stefs or Charlie's would fit better
Re: Small block oil pan question [Re: DavidDean] #1982283
01/02/16 10:11 PM
01/02/16 10:11 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
I am using the Kevco M301 pan. It is a 6 qt. I shift at 6800 and use a stock oil pump.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: Small block oil pan question [Re: JSR1485] #1983446
01/04/16 03:00 PM
01/04/16 03:00 PM
Locomotion Offline
Locomotion  Offline
Gotta pay close attentionto header clearance. There may be issues with the old SS pan with drag link hole and seems like not worth the extra work to R&R. The Milodon 8 qt. prevents some headers from fitting (Notch in K-member to clear the right/front corner of the pan helps R&R also.), but TTI is one that does fit well. I believe their 7 qt. pans solve any header clearance issues.
I have the Miloddon 8 qt. on my 360 in the pic with scraper and stock pump.
How is your ground clearance? Milodon 8 qt. is a bit shallower than a Moroso 8 qt. and likely the SS pan. Their 7 qt. is even better.
Re: Small block oil pan question [Re: JSR1485] #1983490
01/04/16 04:09 PM
01/04/16 04:09 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
Header clearance was a real problem on my kevco with my hooker headers. I had to modify the pan and move header tubes.
Re: Small block oil pan question [Re: JSR1485] #1983506
01/04/16 04:22 PM
01/04/16 04:22 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I run Milodon 8 quart pans and have to section the passengers side to clear my Hedman's.
Re: Small block oil pan question [Re: JSR1485] #1983566
01/04/16 05:46 PM
01/04/16 05:46 PM
Seaford Delaware
JSR1485 Offline OP
JSR1485  Offline OP
Seaford Delaware
I have no problem with the Kevko pan and header clearance ,
Myron your right about the SS pan it is a P I N A to pull the engine with it.
The only reason I was thinking of the SS pan was the pickup for it runs straight down and the pickup area is boxed in with some trap doors
Re: Small block oil pan question [Re: JSR1485] #1983706
01/04/16 08:49 PM
01/04/16 08:49 PM
new jersey usa
11secdart Online content
11secdart  Online Content
new jersey usa
I had a Milodon that the center link went thru, looked cool but was a pia when pulling the motor. Milodon makes another one but the way it kicks out on both sides would be a problem for my Tubular Automotive headers as they are close to the oil pan. I 've had the Moroso 8 qt. on my past three motors as well as my new 408.
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: Small block oil pan question [Re: 11secdart] #1983819
01/04/16 11:16 PM
01/04/16 11:16 PM
pacific northwest
Stroker Scamp Offline
pacific northwest
Moroso here, TTI headers,stock steering
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: Small block oil pan question [Re: Stroker Scamp] #1985420
01/07/16 05:32 AM
01/07/16 05:32 AM
renton , washington
P
perfmachst Offline
perfmachst  Offline
P
renton , washington
the pan off a Dakota pickup 318 fits , rear sump style.
Re: Small block oil pan question [Re: JSR1485] #1985941
01/07/16 11:39 PM
01/07/16 11:39 PM
Az
Crizila Offline
Crizila  Offline
Az
Kevko M301 pan?
I run an 8 qt Milodon in my late B. Had to make a slight mod to the K member. Headers fit fine.
Fastest 300
Re: Small block oil pan question [Re: Crizila] #1986593
01/08/16 11:26 PM
01/08/16 11:26 PM
Mi.
G-Money1320 Offline
G-Money1320  Offline
Mi.
I run the Milodon 8 qt. in my 69 Dart with TTI headers and all stock suspension, all good but as Myron said the stock K frame needs a notch on the right side.
416 stroker from Nick at Compu-flow. 11.14 in full street trim. Seems like a new best every time out.
11.06 open headers----so far!!
Re: Small block oil pan question [Re: JSR1485] #1986711
01/09/16 02:12 AM
01/09/16 02:12 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Same here with the Milodon and TTI headers, no complaints.
68 Barracuda Formula S 340
