Small block oil pan question
#1982262
01/02/16 09:39 PM
01/02/16 09:39 PM
Posts: 1,123 Seaford Delaware
JSR1485
Seaford Delaware
What is better to use in a Bracket car ? Kevko M301 pan? I have old Super Stock style pan with the tie rod tube or should I get a Stefs or Charlie's pan? or Milodon?
What do you guys use?
Switched to the dark side...
Re: Small block oil pan question
[Re: DavidDean]
#1982283
01/02/16 10:11 PM
01/02/16 10:11 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
I am using the Kevco M301 pan. It is a 6 qt. I shift at 6800 and use a stock oil pump.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
[Re: JSR1485]
#1983566
01/04/16 05:46 PM
01/04/16 05:46 PM
JSR1485
Seaford Delaware
I have no problem with the Kevko pan and header clearance , Myron your right about the SS pan it is a P I N A to pull the engine with it. The only reason I was thinking of the SS pan was the pickup for it runs straight down and the pickup area is boxed in with some trap doors
[Re: JSR1485]
#1983706
01/04/16 08:49 PM
01/04/16 08:49 PM
Posts: 4,976 new jersey usa
11secdart
new jersey usa
I had a Milodon that the center link went thru, looked cool but was a pia when pulling the motor. Milodon makes another one but the way it kicks out on both sides would be a problem for my Tubular Automotive headers as they are close to the oil pan. I 've had the Moroso 8 qt. on my past three motors as well as my new 408.
[Re: 11secdart]
#1983819
01/04/16 11:16 PM
01/04/16 11:16 PM
Posts: 3,517 pacific northwest
Stroker Scamp
pacific northwest
Moroso here, TTI headers,stock steering
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip 73 Duster 340 street strip 12.79 @ 105
[Re: JSR1485]
#1985941
01/07/16 11:39 PM
01/07/16 11:39 PM
Posts: 7,506 Az
Crizila
Az
What do you guys use? I run an 8 qt Milodon in my late B. Had to make a slight mod to the K member. Headers fit fine.
Fastest 300
[Re: Crizila]
#1986593
01/08/16 11:26 PM
01/08/16 11:26 PM
Posts: 1,675 Mi.
G-Money1320
Mi.
I run the Milodon 8 qt. in my 69 Dart with TTI headers and all stock suspension, all good but as Myron said the stock K frame needs a notch on the right side.
416 stroker from Nick at Compu-flow. 11.14 in full street trim. Seems like a new best every time out. 11.06 open headers----so far!!
[Re: JSR1485]
#1986711
01/09/16 02:12 AM
01/09/16 02:12 AM
Posts: 8,022 Tulsa OK
Bad340fish
Tulsa OK
Same here with the Milodon and TTI headers, no complaints.
68 Barracuda Formula S 340
