Re: 904 band adjustment........
[Re: Dakota_Don]
#194366
01/15/09 01:34 PM
01/15/09 01:34 PM
RapidRobert
my 77 chry shop manual shows 7 turns backed off from 41 inch lbs(slant 6 w 904)for the low/reverse(internal)band as opposed to the usual figure of 72 inch lbs & 4 turns for a 318/360(1977) from 72 inch lbs. EDIT the kickdown (front) band is 2 turns(back from 72 inch lbs) for /6/318/360(2 & 4 bbl on the 360) in 1977
[Re: RapidRobert]
#194371
01/15/09 05:57 PM
01/15/09 05:57 PM
Posts: 15,487 Florida
scratchnfotraction
so when that said 74 and later 41 inch pounds back off 7 turns that would cover an 84 904 lock-up as well? any one with an 84 book? 7 turns just seems to be a lot what happens if its not turned out that many times?
[Re: Dakota_Don]
#3089645
10/27/22 01:30 PM
10/27/22 01:30 PM
Posts: 25,894 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Keep in mind that there are two different style rear bands, the solid (single wrap) and the split (double wrap). The latter usually needs a looser adjustment (more turns out)
