and as far as the bands, i beleive they changed the way the band is made.. but not positive..but im sure a trans guy will clear this up..
here are the specs from my manual as well. Some of the web sites i listed above (TCI) gives different specs depending on the type of band you are using.Maybe that will give you the info you need.
from my 72-79 manual, low and reverse band adj.Tighten the adjusting screw to 72 inch lbs. (8 Nm).
Fig. 2: Low-reverse band adjusting screw location
Back off the adjusting screw as follows:
A-727-2 turns
6 cly through 73 A-904T/A-999-3 1/4 turns, 74 and later41 in pounds then back off 7 turns
