904 band adjustment........ #194362
01/15/09 12:49 PM
01/15/09 12:49 PM
Chicken coop
dustergirl340 Offline OP
Chicken Little
Chicken Little
Chicken coop
What is the adjustment for the low reverse band on a 1976 slant six 904 transmission?
The book says 7 1/2 turns for a 1974-'76, and 3 1/4 turns for a 1968-'73.
What is the difference between the years on these bands? 7 1/2 seems an awful lot.
Re: 904 band adjustment........ [Re: dustergirl340] #194363
01/15/09 01:20 PM
01/15/09 01:20 PM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
i think its 72 in pounds then back off 2.5 turns.. but here a bump.. I will run out side and check my book
Re: 904 band adjustment........ [Re: Dakota_Don] #194364
01/15/09 01:23 PM
01/15/09 01:23 PM
Columbus, Ohio
wheelsup68dart Offline
Columbus, Ohio
ABOVE POST IS CORRECT
Re: 904 band adjustment........ [Re: wheelsup68dart] #194365
01/15/09 01:25 PM
01/15/09 01:25 PM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
Re: 904 band adjustment........ [Re: Dakota_Don] #194366
01/15/09 01:34 PM
01/15/09 01:34 PM
my 77 chry shop manual shows 7 turns backed off from 41 inch lbs(slant 6 w 904)for the low/reverse(internal)band as opposed to the usual figure of 72 inch lbs & 4 turns for a 318/360(1977) from 72 inch lbs. EDIT the kickdown (front) band is 2 turns(back from 72 inch lbs) for /6/318/360(2 & 4 bbl on the 360) in 1977
Re: 904 band adjustment........ [Re: dustergirl340] #194367
01/15/09 01:46 PM
01/15/09 01:46 PM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
and as far as the bands, i beleive they changed the way the band is made.. but not positive..but im sure a trans guy will clear this up..
here are the specs from my manual as well. Some of the web sites i listed above (TCI) gives different specs depending on the type of band you are using.Maybe that will give you the info you need.
from my 72-79 manual, low and reverse band adj.Tighten the adjusting screw to 72 inch lbs. (8 Nm).
Fig. 2: Low-reverse band adjusting screw location
Back off the adjusting screw as follows:
A-727-2 turns
6 cly through 73 A-904T/A-999-3 1/4 turns, 74 and later41 in pounds then back off 7 turns
Re: 904 band adjustment........ [Re: Dakota_Don] #194368
01/15/09 02:33 PM
01/15/09 02:33 PM
Oklahoma
Mopar72Man Offline
Mopar72Man  Offline
Oklahoma
this is supposed to be done with a 'beam' style inch/lb wrench.
correct?
72 Challenger - will be sublime, little 340 904, 8 3/4" - Under Construction
Re: 904 band adjustment........ [Re: Mopar72Man] #194369
01/15/09 02:49 PM
01/15/09 02:49 PM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
the one i use has a dail on it, and its made by snap-on
Re: 904 band adjustment........ [Re: Mopar72Man] #194370
01/15/09 03:38 PM
01/15/09 03:38 PM
this is supposed to be done with a 'beam' style inch/lb wrench. correct?
if it's an inch lb unit & accurate your good. My Sears beam one has worked good for me.
Re: 904 band adjustment........ [Re: RapidRobert] #194371
01/15/09 05:57 PM
01/15/09 05:57 PM
scratchnfotraction Offline
so when that said 74 and later
41 inch pounds back off 7 turns
that would cover an 84 904 lock-up as well?
any one with an 84 book?
7 turns just seems to be a lot
what happens if its not turned out that many times?
Re: 904 band adjustment........ [Re: scratchnfotraction] #194372
01/15/09 06:59 PM
01/15/09 06:59 PM
We're waiting for Kunkel to come to
Re: 904 band adjustment........ [Re: RapidRobert] #194373
01/15/09 08:41 PM
01/15/09 08:41 PM
Chicken coop
Chicken Little
Chicken Little
Chicken coop
thanks for the info guys!
Re: 904 band adjustment........ [Re: dustergirl340] #194374
01/15/09 09:07 PM
01/15/09 09:07 PM
CT
turbocolt2.4L Offline
CT
I would go 2 to 2.5 turns from 72 ILBS.
Re: 904 band adjustment........ [Re: dustergirl340] #3089436
10/26/22 04:45 PM
10/26/22 04:45 PM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
Who would've thought many yrs later I need the 74 up specs .
Re: 904 band adjustment........ [Re: Dakota_Don] #3089509
10/26/22 08:43 PM
10/26/22 08:43 PM
delhi,il
trw1982 Offline
trw1982  Offline
delhi,il
here is spec from 1984 truck service manual.
Re: 904 band adjustment........ [Re: Dakota_Don] #3089645
10/27/22 01:30 PM
10/27/22 01:30 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Keep in mind that there are two different style rear bands, the solid (single wrap) and the split (double wrap). The latter usually needs a looser adjustment (more turns out)
