Re: suggestions for a low 11 sec. b-body 440 combo ???
[Re: ajcasini]
#191556
01/12/09 08:49 PM
01/12/09 08:49 PM
Posts: 1,260 Las Vegas NV
moparmanjames
Las Vegas NV
I put together a pretty good combo this winter. Ran 10.90's in good air and 11.1's in the heat. I did have the edelbrock aluminum heads.
Chrysler Steel Crank 6.760 Ohio Crank HBeam's .030 SRP FT 10.5 to 1 Comp Weiand Team G Intake with matched ports Comp Cam SOLID-Very strong mid and upper rpm .016 .018 2500 to 6500 23-232-428 XS282S 244 252 duration @.050 Lift .520 .540 centerline 110º Set it up at 110 centerline 1.5 ratio rockers 1 3/4 header tubes 5000 stall ATI 8" 28 x 9 x 15 slicks 4.10 gear 850 cfm Barry Grant Race Demon
IMO the heads are worth .3 on the track.
AJ
how much did the car weigh, what was the elevation?
[Re: ajcasini]
#191558
01/12/09 09:23 PM
01/12/09 09:23 PM
moparmanjames
Las Vegas NV
Car weighs 3650 with driver and elevation is: ~1400ft.
I am running open headers as well.
AJ
Thanks, nice build.
[Re: dakotahotrodder]
#191561
01/12/09 10:52 PM
01/12/09 10:52 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
The combo in my signature is pretty close to what you describe. So far has run a best of 11.33 with a 4900 flash 8 inch converter and ran a best of 11.49 with a 4200 flash 9.5 converter. I think I can get in the 11.20s as it sits with some chassis tuning. 60s are pretty bad as my best is only a 1.6 even. Ported 452's(no clue on flow numbers), comp solid [Email]259@.050[/Email], 10.6 comp, 950 Holley, 2 inch hookers, 4.30 gears. All passes have been corked with 3 inch to Edelbrock RPM mufflers, then to 2 1/2 tailpipes. No X or H pipe either. Car weighs 3800 lbs, give or take a few. By the way it runs fine on pump 91 and the 8 inch converter is almost identical on the street to the 9.5. In fact the 8 inch is WAY tighter on the street than a 10 inch I had in the car 15 years or so ago.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
[Re: dragula426]
#191562
01/13/09 01:51 AM
01/13/09 01:51 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
thanks everyone for the suggestions! I WAS WRONG..the converter flashed @ 4200.
ron.... they are flat tops w/ valve reliefs so, comp ratio is ?? i do know that it will run on if i run 91 octane.
mopar man...tti 2-1/8th step. i know probably too big, but they fit so good, they are staying. cam specs attached.
i know there is some more to be had w/ this combo if i super tuned it, it most likely would like more gear and a looser converter, but i drive this thing everywhere rain or shine! i've driven it 2 hours away to brainerd for a test day and then back with no probs. i want to keep alot of that street ability but want to gain more power and torque thru the whole rpm range (this cam i think is limiting torque down low. what do you think??) since the engine pings/ runs on if i run straight 91 pump gas, i figure i should make it funner to drive (since i have to run race gas anyway) so, keep the combos/ideas/critiques coming! i'm all ears
Thats a bummer you have to run race gas. I built a .042 quench in my 906 headed 440 and I run on 92 pump all the time with 38 total timing. I guess mine would run fine on 91 but I never tried it. I also run mine thru the pipes but its a 3" system so it may not go faster uncapped. That race gas can get very pricey. And thats one nice Plymouth you got. Ron
[Re: dragula426]
#191563
01/13/09 08:47 AM
01/13/09 08:47 AM
Posts: 10,010 Frostbitefalls MN (Rocky&Bullw...
gregsdart
With the cost of the 440source heads, or eddys, i wouldn't put any money into crack prowen older castings unless i was going to do all the work and already had them. There is absolutely no substitute for big cubes when it comes to street and manners in the same package. My idea of the best setup is the longest stroke you can put in the motor,if you need crank work. There are 4.5 arms out there for the tall deck block. With what you have, they will make a high to mid ten second ride out of your car because they will use up all of the head flow with a stock type port window by 6000 rpm! My first big motor was a 4.5 stroke 4.350 bore 440 making 535 cubes, with ported 906 heads. Went 10.20s at 3400 lbs, cracked the heads and i lost all that expensive porting work! Nice thing about the motor was it only needed a 5700 rpm shift point with a 590 cam . I did use a 1.7 erson rocker on the heads, which worked at those low rpms just fine and helped out the cam quite a bit.
[Re: dragula426]
#191565
01/13/09 11:57 AM
01/13/09 11:57 AM
Posts: 150 South Carolina, United States
carolinacuda
I agree with others, you shld have more in that combo you have. The combo I have in my 74 cuda is pretty mild with stock suspension and run 11.50 @ 117 mph. 446, with stock rods 30 over trw 2355 pistons W/10.5 comp. hughes solid flat tappet 252/256, 572/279 @108 victor int mghty demon 850 indy EZ's (with just a port match) Hooker 1-7/8 headers 3.91 with M/T ET.radials (275/60/15) TCI 10'stall 3500-3800 With some more suspension upgrades I feel confident it will run 11.20-30's
[Re: dragula426]
#191566
01/13/09 01:00 PM
01/13/09 01:00 PM
Posts: 1,646 Ontario,Canada
firefighter3931
Ontario,Canada
Yes the big step headers are hurting bottom end power & torque.
The cam's lsa is too wide for a 10.5:1 440....something with a tighter 108* lsa would be much better.
Randy (Lab Rat) has a very similar combo....almost identical in fact and went from a 112 lsa cam to a 108 lsa cam and picked up a couple of tenths. He stated that the midrange power was dramaticly improved and his 60 ft times reflected that. His converter also flashed up higher with the newfound bottom end power as well...
Ron
[Re: ajcasini]
#191568
01/13/09 04:20 PM
01/13/09 04:20 PM
Posts: 2,763 Walton's Mountain, Pa
Steve1118
AJ, where is that crate Hemi you had in there for a while? I thought it ran real well for what it was. If you are looking to pitch it I've got some room in my garbage can up here on the mountain...
"Old age and treachery trumps youth and enthusiasm, every time!" East Central Director / Chrysler Power Magazine www.reasbeckracing.webs.com
[Re: Steve1118]
#191569
01/13/09 05:18 PM
01/13/09 05:18 PM
Posts: 686 PA
ajcasini
PA
Still have the crate HEMI. It did run very well. Went fastest of 11.20 @ 119. I have it in the garage, needs a good freshen and some more cam.
It will be back eventually.
How have you been?
AJ
[Re: dragula426]
#191570
01/13/09 05:54 PM
01/13/09 05:54 PM
Posts: 1,949 land of 10,000______'s
BDS871Cuda
Close to the weight of yours. My 65 Sport Fury tip the scale just over 4000 lbs.
440+ .030 steel crank, stock rods. Ross 10.5 Iron 452 casting heads with (Line Perf. porting) Ultradyne .590/.613 cam Demon 825 cfm race carb Mopar M1 MSD
727 w/turbo action RMVB /T.A. J 4500 stall
Dana 60 4.88 w/ 31X18.5 QTP's
11.16 at 118 Cedar Falls Iowa
Had a Holley 750 DP and Mopar dist. and chrome box at first and did a best 11.38
the old 750 with tired mopar dist was tossed for the Race Demon and MSD and did 11.16 best. I wish I would of swapped the 4.88 for 4.56's. Car ran out of breath at 1000-1100 ft.
Snap your neck, mega G-force launch, is all I want!
