suggestions for a low 11 sec. b-body 440 combo ??? #191551
01/12/09 04:44 PM
01/12/09 04:44 PM
duluth mn.
dragula426 Offline OP
duluth mn.
it's time to freshen and or change the combo in my 69 sat.street car. i torched a head gasket this fall and now have been thinking of changing things up a bit. the current engine is a 440 w/flat top arias pistons, bme rods, stock crank, a straightline roller(258 268 @.050), w/ edelbrocks, m-1 intake and a 850 holley. the car has a ptc 9" converter(3800 or so stall) 4.10 dana.the car has power steering, heater, radio etc. it weighs 3780w/ me in it.
right now the car runs 11.80s thru exhaust n/a and 10.20's w nos. i think it's sort of a pooch on the motor and for longevity was thinking of eliminating the juice all together. i want to use the edelbrocks on another project,and have access to a set of ported 906's. so, let's hear of some combos w/ ported 906's and a more of an (old school..meaning 108 centerline)flat tappet camshaft.maybe the old 590 mopar cam? am i out of line to think that there should be a combo to run in the low to mid 11's with fairly conservative parts?? let's hear what you have. thanks
Re: suggestions for a low 11 sec. b-body 440 combo ??? [Re: dragula426] #191552
01/12/09 05:31 PM
01/12/09 05:31 PM
Las Vegas NV
moparmanjames Offline
Las Vegas NV
What are the specs on the cam? does it have decent headers?
I would run the ported 906's with the .590 cam, throw in bigger valves, a 5000 stall converter and maybe some 1.6 rockers and a 1050 Dominator and that should get you there, it's a heavy car though so you might need more gear too.
Re: suggestions for a low 11 sec. b-body 440 combo ??? [Re: moparmanjames] #191553
01/12/09 08:12 PM
01/12/09 08:12 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
If you fine tune your combo it should have low 11's in it now. I have run 11.50's @ almost 117 with a stock bottom end 440 other then the .030 over KB pistons. I use 906's I ported myself and the MP .557 cam and I have it at 10.0 comp. My 63 goes just over 3700 with me and the rollbar. But its a street car I drive everywhere including to the track. It has a Dynamic 9.5 street/strip converter and I use 4.30's with 29 x 11.5 Hoosier QTP tires. I see no reason that if I ever take the time for some fine tuning 11.30's could be had in my combo. You can see my full combo at this link. But honestly I would leave the Eddy's on your combo and work with it. What comp are you running now ?? Ron
http://www.1962to1965mopar.ornocar.com/mmo82008.html
Re: suggestions for a low 11 sec. b-body 440 combo ??? [Re: 383man] #191554
01/12/09 08:37 PM
01/12/09 08:37 PM
PA
ajcasini Offline
ajcasini  Offline
PA
I put together a pretty good combo this winter. Ran 10.90's in good air and 11.1's in the heat. I did have the edelbrock aluminum heads.
Chrysler Steel Crank
6.760 Ohio Crank HBeam's
.030 SRP FT 10.5 to 1 Comp
Weiand Team G Intake with matched ports
Comp Cam
SOLID-Very strong mid and upper rpm
.016 .018
2500 to 6500
23-232-428 XS282S
244 252 duration @.050
Lift .520 .540 centerline 110º
Set it up at 110 centerline
1.5 ratio rockers
1 3/4 header tubes
5000 stall ATI 8"
28 x 9 x 15 slicks
4.10 gear
850 cfm Barry Grant Race Demon
IMO the heads are worth .3 on the track.
AJ
Re: suggestions for a low 11 sec. b-body 440 combo ??? [Re: dragula426] #191555
01/12/09 08:47 PM
01/12/09 08:47 PM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
I think your old engine had a lot more in it. I had a throw together cast crank 440. In a 3600 pound 65 plymouth it ran a best of 11.70. but most of the time was a 11.80-11.90 car.Sorry not trying to diss your car it looks awesome. I just think you have a lot more in your old engine. best of luck to you. Mopar65
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: suggestions for a low 11 sec. b-body 440 combo ??? [Re: ajcasini] #191556
01/12/09 08:49 PM
01/12/09 08:49 PM
Las Vegas NV
Las Vegas NV
Comp Cam
.016 .018
2500 to 6500
23-232-428 XS282S
1.5 ratio rockers
1 3/4 header tubes
5000 stall ATI 8"
28 x 9 x 15 slicks
4.10 gear
AJ
how much did the car weigh, what was the elevation?
Re: suggestions for a low 11 sec. b-body 440 combo ??? [Re: moparmanjames] #191557
01/12/09 08:56 PM
01/12/09 08:56 PM
PA
ajcasini Offline
ajcasini  Offline
PA
Car weighs 3650 with driver and elevation is: ~1400ft.
I am running open headers as well.
AJ
Re: suggestions for a low 11 sec. b-body 440 combo ??? [Re: ajcasini] #191558
01/12/09 09:23 PM
01/12/09 09:23 PM
Las Vegas NV
Las Vegas NV
AJ
Thanks, nice build.
Re: suggestions for a low 11 sec. b-body 440 combo ??? [Re: mopar65] #191559
01/12/09 10:28 PM
01/12/09 10:28 PM
duluth mn.
duluth mn.
thanks everyone for the suggestions! I WAS WRONG..the converter flashed @ 4200.
ron.... they are flat tops w/ valve reliefs so, comp ratio is ?? i do know that it will run on if i run 91 octane.
mopar man...tti 2-1/8th step. i know probably too big, but they fit so good, they are staying.
cam specs attached.
i know there is some more to be had w/ this combo if i super tuned it, it most likely would like more gear and a looser converter, but i drive this thing everywhere rain or shine! i've driven it 2 hours away to brainerd for a test day and then back with no probs. i want to keep alot of that street ability but want to gain more power and torque thru the whole rpm range (this cam i think is limiting torque down low. what do you think??) since the engine pings/ runs on if i run straight 91 pump gas, i figure i should make it funner to drive (since i have to run race gas anyway) so, keep the combos/ideas/critiques coming! i'm all ears
Re: suggestions for a low 11 sec. b-body 440 combo ??? [Re: dragula426] #191560
01/12/09 10:42 PM
01/12/09 10:42 PM
South Dakota
dakotahotrodder Offline
South Dakota
Is that a solid roller? I've got a straightline solid flat tappet cam with 248/260, .555 lift that I really like. With e-heads& flat tops (10.8:1), m1, & 950 it made 571hp & 573tq. I've gone 10.93 at 3700 lbs w/ 8" converter & 4.10's. That roller of yours sounds like something my motor would like.
Re: suggestions for a low 11 sec. b-body 440 combo ??? [Re: dakotahotrodder] #191561
01/12/09 10:52 PM
01/12/09 10:52 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
The combo in my signature is pretty close to what you describe.
So far has run a best of 11.33 with a 4900 flash 8 inch converter and ran a best of 11.49 with a 4200 flash 9.5 converter. I think I can get in the 11.20s as it sits with some chassis tuning. 60s are pretty bad as my best is only a 1.6 even.
Ported 452's(no clue on flow numbers), comp solid [Email]259@.050[/Email], 10.6 comp, 950 Holley, 2 inch hookers, 4.30 gears. All passes have been corked with 3 inch to Edelbrock RPM mufflers, then to 2 1/2 tailpipes. No X or H pipe either. Car weighs 3800 lbs, give or take a few.
By the way it runs fine on pump 91 and the 8 inch converter is almost identical on the street to the 9.5. In fact the 8 inch is WAY tighter on the street than a 10 inch I had in the car 15 years or so ago.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: suggestions for a low 11 sec. b-body 440 combo ??? [Re: dragula426] #191562
01/13/09 01:51 AM
01/13/09 01:51 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
cam specs attached.
Thats a bummer you have to run race gas. I built a .042 quench in my 906 headed 440 and I run on 92 pump all the time with 38 total timing. I guess mine would run fine on 91 but I never tried it. I also run mine thru the pipes but its a 3" system so it may not go faster uncapped. That race gas can get very pricey. And thats one nice Plymouth you got. Ron
Re: suggestions for a low 11 sec. b-body 440 combo ??? [Re: dragula426] #191563
01/13/09 08:47 AM
01/13/09 08:47 AM
gregsdart Offline
gregsdart  Offline
With the cost of the 440source heads, or eddys, i wouldn't put any money into crack prowen older castings unless i was going to do all the work and already had them. There is absolutely no substitute for big cubes when it comes to street and manners in the same package. My idea of the best setup is the longest stroke you can put in the motor,if you need crank work. There are 4.5 arms out there for the tall deck block. With what you have, they will make a high to mid ten second ride out of your car because they will use up all of the head flow with a stock type port window by 6000 rpm! My first big motor was a 4.5 stroke 4.350 bore 440 making 535 cubes, with ported 906 heads. Went 10.20s at 3400 lbs, cracked the heads and i lost all that expensive porting work! Nice thing about the motor was it only needed a 5700 rpm shift point with a 590 cam . I did use a 1.7 erson rocker on the heads, which worked at those low rpms just fine and helped out the cam quite a bit.
Re: suggestions for a low 11 sec. b-body 440 combo ??? [Re: gregsdart] #191564
01/13/09 10:47 AM
01/13/09 10:47 AM
Cheswick, PA
Bob_Spelic Offline
Bob_Spelic  Offline
Cheswick, PA
My 446 combo:
TRW 10.5:1 old school TRW 2295 forged pistons
eagle 6.76 H-beams
Stock steel crank
Port Eddelbrocks flowing in the 290/212
76cc chamber
Cam is a solid flat tappet 108 centerline
268/276 @ .050, .600 lift in at 104
M1 manifold with a 1050 dominator
2" tti headers
4.10 gear, 31x10.5W slicks
Torqueflight
3750 pounds with driver
Only had it out once last year. Ran a 11.44 @ 2080DA and a 11.32@ 1520DA
Bob Spelic
Re: suggestions for a low 11 sec. b-body 440 combo ??? [Re: dragula426] #191565
01/13/09 11:57 AM
01/13/09 11:57 AM
South Carolina, United States
carolinacuda Offline
I agree with others, you shld have more in that combo you have. The combo I have in my 74 cuda is pretty mild with stock suspension and run 11.50 @ 117 mph. 446, with stock rods
30 over
trw 2355 pistons W/10.5 comp.
hughes solid flat tappet 252/256, 572/279 @108
victor int
mghty demon 850
indy EZ's (with just a port match)
Hooker 1-7/8 headers
3.91 with M/T ET.radials (275/60/15)
TCI 10'stall 3500-3800
With some more suspension upgrades I feel confident it will run 11.20-30's
Re: suggestions for a low 11 sec. b-body 440 combo ??? [Re: dragula426] #191566
01/13/09 01:00 PM
01/13/09 01:00 PM
Ontario,Canada
firefighter3931 Offline
Ontario,Canada
Yes the big step headers are hurting bottom end power & torque.
The cam's lsa is too wide for a 10.5:1 440....something with a tighter 108* lsa would be much better.
Randy (Lab Rat) has a very similar combo....almost identical in fact and went from a 112 lsa cam to a 108 lsa cam and picked up a couple of tenths. He stated that the midrange power was dramaticly improved and his 60 ft times reflected that. His converter also flashed up higher with the newfound bottom end power as well...
Ron
Re: suggestions for a low 11 sec. b-body 440 combo ??? [Re: firefighter3931] #191567
01/13/09 02:38 PM
01/13/09 02:38 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Your combo looks like it should be going faster than it is. Look at 383man's combo, he's got a great old-school combo putting down excellent numbers for a street/strip car. Nothing fancy there except for some well matched components.
Maybe that cam of yours is hurting you. You say it'll diesel if you run on 91, and with all that duration that makes me wonder. You've got enough duration, but on that 112 lobe seperation you are hurting your top end/mid range.
Re: suggestions for a low 11 sec. b-body 440 combo ??? [Re: ajcasini] #191568
01/13/09 04:20 PM
01/13/09 04:20 PM
Walton's Mountain, Pa
Steve1118 Offline
Steve1118  Offline
AJ, where is that crate Hemi you had in there for a while? I thought it ran real well for what it was.
If you are looking to pitch it I've got some room in my garbage can up here on the mountain...
"Old age and treachery trumps youth and enthusiasm, every time!"
East Central Director / Chrysler Power Magazine
www.reasbeckracing.webs.com
Re: suggestions for a low 11 sec. b-body 440 combo ??? [Re: Steve1118] #191569
01/13/09 05:18 PM
01/13/09 05:18 PM
PA
ajcasini Offline
ajcasini  Offline
PA
Still have the crate HEMI. It did run very well. Went fastest of 11.20 @ 119. I have it in the garage, needs a good freshen and some more cam.
It will be back eventually.
How have you been?
AJ
Re: suggestions for a low 11 sec. b-body 440 combo ??? [Re: dragula426] #191570
01/13/09 05:54 PM
01/13/09 05:54 PM
land of 10,000______'s
BDS871Cuda Offline
BDS871Cuda  Offline
Close to the weight of yours. My 65 Sport Fury
tip the scale just over 4000 lbs.
440+ .030 steel crank, stock rods.
Ross 10.5
Iron 452 casting heads with (Line Perf. porting)
Ultradyne .590/.613 cam
Demon 825 cfm race carb
Mopar M1
MSD
727 w/turbo action RMVB /T.A. J 4500 stall
Dana 60 4.88 w/ 31X18.5 QTP's
11.16 at 118 Cedar Falls Iowa
Had a Holley 750 DP and Mopar dist. and chrome
box at first and did a best 11.38
the old 750 with tired mopar dist was tossed
for the Race Demon and MSD and did 11.16 best.
I wish I would of swapped the 4.88 for 4.56's.
Car ran out of breath at 1000-1100 ft.
Snap your neck, mega G-force launch, is all I want!
