Re: Header bolt holes that connect with water jacket...
[Re: fatsat]
#1854477
06/22/15 05:29 PM
06/22/15 05:29 PM
Posts: 21,074 Niles , Ohio
therocks
Niles , Ohio
Yes they do unless you have aluminum heads.IIRC they all go to water.Rocky
Chrysler Firepower
[Re: fatsat]
#1854516
06/22/15 06:24 PM
06/22/15 06:24 PM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
Stock iron heads and MP stage 6 based aluminum heads , except for the E brock based heads ... they ALL go into water .
[Re: fatsat]
#1854531
06/22/15 06:40 PM
06/22/15 06:40 PM
RapidRobert
what works for me is to use the OE shouldered studs & trim the outer fine threaded portion so there is only enough thread left to end up flush with the nut when tightened (keep in mind your gasket thickness choice) as any further protruding threads is a waste & hampers header fitment. You can also get high grade nuts that are half the thickness of the OE ones for even more gain
[Re: fatsat]
#1855090
06/23/15 12:01 PM
06/23/15 12:01 PM
therocks
Niles , Ohio
I always used antisieze.Never a leak even when we ran bolts and not studs.Rocky
Chrysler Firepower
