Header bolt holes that connect with water jacket... #1854422
06/22/15 04:39 PM
06/22/15 04:39 PM
NorCal
fatsat Offline OP
fatsat  Offline OP
NorCal
Do some header bolt holes on big block connect with the water jacket? If so which ones. 1970 383.
Re: Header bolt holes that connect with water jacket... [Re: fatsat] #1854477
06/22/15 05:29 PM
06/22/15 05:29 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Yes they do unless you have aluminum heads.IIRC they all go to water.Rocky
Chrysler Firepower
Re: Header bolt holes that connect with water jacket... [Re: fatsat] #1854516
06/22/15 06:24 PM
06/22/15 06:24 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Stock iron heads and MP stage 6 based aluminum heads , except for the E brock based heads ... they ALL go into water .
Re: Header bolt holes that connect with water jacket... [Re: fatsat] #1854531
06/22/15 06:40 PM
06/22/15 06:40 PM
what works for me is to use the OE shouldered studs & trim the outer fine threaded portion so there is only enough thread left to end up flush with the nut when tightened (keep in mind your gasket thickness choice) as any further protruding threads is a waste & hampers header fitment. You can also get high grade nuts that are half the thickness of the OE ones for even more gain
Re: Header bolt holes that connect with water jacket... [Re: fatsat] #1854827
06/22/15 11:40 PM
06/22/15 11:40 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
I second the use of shouldered studs...Try hard to use them and save yourself a big headache....Standard header bolts will all leak eventually I've tried everything...Some are sealed initially but after a few heat cycles they weep...And if you crank on them they'll leak...And..You get the picture...
Re: Header bolt holes that connect with water jacket... [Re: fatsat] #1854901
06/23/15 01:03 AM
06/23/15 01:03 AM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
Another vote for shouldered studs.
Re: Header bolt holes that connect with water jacket... [Re: Magnum] #1854910
06/23/15 01:18 AM
06/23/15 01:18 AM
IN
ahy Offline
ahy  Offline
IN
Various sealants can be used to seal the threads... teflon pipe dope is usually considered the best.
Re: Header bolt holes that connect with water jacket... [Re: ahy] #1854962
06/23/15 02:29 AM
06/23/15 02:29 AM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Permatex thread sealant...
Too close for studs with my Hooker's...
ARP stainless bolts...
Leak free for many moons...
Re: Header bolt holes that connect with water jacket... [Re: fatsat] #1855090
06/23/15 12:01 PM
06/23/15 12:01 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I always used antisieze.Never a leak even when we ran bolts and not studs.Rocky
Chrysler Firepower
Re: Header bolt holes that connect with water jacket... [Re: fatsat] #1855202
06/23/15 02:47 PM
06/23/15 02:47 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
I use ARP thread sealant and Stage 8 locking header bolts and never had any leaks.
