Re: My latest contraption [Re: GY3] #1777673
03/12/15 04:08 PM
03/12/15 04:08 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Is this the slowest Blown Hemi in the world ?
Re: My latest contraption [Re: FastmOp] #1777674
03/12/15 04:27 PM
03/12/15 04:27 PM
washington
Bruce Offline
Bruce  Offline
washington
Nice setup for removing your blower. I would be more concerned with the strength of the ceiling beams, etc. Wouldn't want to find out it is too weak the hard way.
Just a thought from another Hemi lover.
Re: My latest contraption [Re: hemi-itis] #1777675
03/12/15 05:04 PM
03/12/15 05:04 PM
California
mickm Offline
mickm  Offline
California
In the past,whever I needed to remove the blower from the intake I would need 3 friends come over and "man" the serp belts to lift the blower off and set it into the cart.Kudos and thanks to Nitro Buzzard Ken for hooking me up with an "I" beam and trolly to go with it.Ken also installed the beam on the ceiling and fabricated the brackets to mount the Harbor Freight $50 25000 lb winch to the trolley and the bracket to hold the supporting straps attached to the blower.
I can now R&R the blower myself
damn! how heavy is that setup??
Re: My latest contraption [Re: hemi-itis] #1777676
03/12/15 05:10 PM
03/12/15 05:10 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I carry my 90# blower,carbs thru 4 doorways to the garage,put the blower on a mat on the fender,stand on the inner frame rail,waterpump and lift the blower on the intake.I need the exercise.I am glad you can put a nice lift like that in.
Re: My latest contraption [Re: Clanton] #1777677
03/12/15 10:18 PM
03/12/15 10:18 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I was just busting your chops. That Thing Is Old School tuff.
Re: My latest contraption [Re: hemi-itis] #1777678
03/12/15 11:12 PM
03/12/15 11:12 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Mr. P,it's for the blower only.I would not lift my iron headed hemi with that,It's a Chinese winch
Nice set up for what your doing.
Though the winch is most likely strong enough to pull the motor too, I would want to know what and how the
I Beam is attached to before I would try it.
Re: My latest contraption [Re: GY3] #1777679
03/13/15 12:45 AM
03/13/15 12:45 AM
Great Neck,LI,new york
hemi-itis Offline OP
Sorry, kinda ignorant on the blower thing, what do you do to R&R one then?
unless there is an issue,street blowers last quite a while.
I had mine "gone through" when I found the front gears messed up.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: My latest contraption [Re: FastmOp] #1777680
03/13/15 12:55 AM
03/13/15 12:55 AM
For a 3900 lb car that gets driven a few thousand miles a year it could be one of the slowest I have not tried more than 10 lbs of boost just yet. 113 mph in the 1/8 and 140 in the 1/4 almost respectable. I'm in the process of installing a racepak,then I won't be so nervous about throwing more boost at it.
Re: My latest contraption [Re: Bruce] #1777681
03/13/15 01:00 AM
03/13/15 01:00 AM
It's fine for lifting the blower,I wouldn't lift the engine.Bet this iron headed hemi with the blower,carbs & scoop weigh 1000 lbs
Re: My latest contraption [Re: Clanton] #1777682
03/13/15 01:05 AM
03/13/15 01:05 AM
Your a brute Mike,my back would break if I tried lifting it
Re: My latest contraption [Re: FastmOp] #1777683
03/13/15 01:07 AM
03/13/15 01:07 AM
I'm the slow poke!!
Re: My latest contraption [Re: hemi-itis] #1777684
03/13/15 10:32 AM
03/13/15 10:32 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Nice garage,I am just getting around to drywall,lighting. I have an engine leveler from HF but the process is just too slow for me.I hope the weather keeps up so we can be ready to have some fun.
Re: My latest contraption [Re: Clanton] #1777685
03/13/15 12:19 PM
03/13/15 12:19 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
I remember wrenching my back when I tried to carefully set my 8-71 down over the aluminum studs, by myself. My back was hurting for a few days.
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: My latest contraption [Re: DusterDave] #1777686
03/13/15 12:40 PM
03/13/15 12:40 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I did heavy lifting for 30 yrs at work so now that I am retired[56yrs old]I need to use muscles or loose them but I understand others working smart not hard.
Re: My latest contraption [Re: hemi-itis] #1777687
03/13/15 01:23 PM
03/13/15 01:23 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Hemi itis did you find some intake studs that work for you?
Re: My latest contraption [Re: hemi-itis] #1777688
03/13/15 07:20 PM
03/13/15 07:20 PM
anywhere@ anytime
actionange Offline
actionange  Offline
anywhere@ anytime
Ive got a question.
What am I doing wrong? my car ran 9.88@ 136.40 with a 1.37 60 foot. And it weighs 3750 race ready.
Does that blower add top end mph to go 3.5 mph faster at 3900 lbs?
Maybe I'll have to get me one of them...
Re: My latest contraption [Re: actionange] #1777689
03/14/15 01:20 AM
03/14/15 01:20 AM
Ive got a question.
My numbers are "so far " with just 10 lbs of boost should go up at the boost gets increased
Re: My latest contraption [Re: actionange] #1777690
03/14/15 10:57 PM
03/14/15 10:57 PM
Ive got a question.
Ange,your not doin anything wrong,you have that car flyin for what your working with. I've had this combo for many years and just haven't turned the wick up,,,,,,yet
This season I will see some new bestestezz
Re: My latest contraption [Re: Clanton] #1777691
03/14/15 11:01 PM
03/14/15 11:01 PM
Mike,I was told that installing the manifold over the 16 studs is nearly impossible. Went with ARP bolts
