Re: My latest contraption
[Re: hemi-itis]
#1777675
03/12/15 05:04 PM
03/12/15 05:04 PM
Posts: 4,179 California
mickm
California
In the past,whever I needed to remove the blower from the intake I would need 3 friends come over and "man" the serp belts to lift the blower off and set it into the cart.Kudos and thanks to Nitro Buzzard Ken for hooking me up with an "I" beam and trolly to go with it.Ken also installed the beam on the ceiling and fabricated the brackets to mount the Harbor Freight $50 25000 lb winch to the trolley and the bracket to hold the supporting straps attached to the blower. I can now R&R the blower myself
damn! how heavy is that setup??
[Re: hemi-itis]
#1777676
03/12/15 05:10 PM
03/12/15 05:10 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
I carry my 90# blower,carbs thru 4 doorways to the garage,put the blower on a mat on the fender,stand on the inner frame rail,waterpump and lift the blower on the intake.I need the exercise.I am glad you can put a nice lift like that in.
[Re: hemi-itis]
#1777678
03/12/15 11:12 PM
03/12/15 11:12 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Mr. P,it's for the blower only.I would not lift my iron headed hemi with that,It's a Chinese winch
Nice set up for what your doing.
Though the winch is most likely strong enough to pull the motor too, I would want to know what and how the
I Beam is attached to before I would try it.
[Re: Clanton]
#1777682
03/13/15 01:05 AM
03/13/15 01:05 AM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
Your a brute Mike,my back would break if I tried lifting it
[Re: Clanton]
#1777685
03/13/15 12:19 PM
03/13/15 12:19 PM
Posts: 1,845 Tampa
DusterDave
Tampa
I remember wrenching my back when I tried to carefully set my 8-71 down over the aluminum studs, by myself. My back was hurting for a few days.
Gone to the dark side with an LS3 powered '57 Chevy 210
[Re: DusterDave]
#1777686
03/13/15 12:40 PM
03/13/15 12:40 PM
Clanton
northern,Ohio,USA
I did heavy lifting for 30 yrs at work so now that I am retired[56yrs old]I need to use muscles or loose them but I understand others working smart not hard.
[Re: hemi-itis]
#1777688
03/13/15 07:20 PM
03/13/15 07:20 PM
Posts: 1,627 anywhere@ anytime
actionange
anywhere@ anytime
Is this the slowest Blown Hemi in the world ?
For a 3900 lb car that gets driven a few thousand miles a year it could be one of the slowest I have not tried more than 10 lbs of boost just yet. 113 mph in the 1/8 and 140 in the 1/4 almost respectable. I'm in the process of installing a racepak,then I won't be so nervous about throwing more boost at it.
Ive got a question. What am I doing wrong? my car ran 9.88@ 136.40 with a 1.37 60 foot. And it weighs 3750 race ready. Does that blower add top end mph to go 3.5 mph faster at 3900 lbs? Maybe I'll have to get me one of them...
[Re: actionange]
#1777690
03/14/15 10:57 PM
03/14/15 10:57 PM
hemi-itis
Ange,your not doin anything wrong,you have that car flyin for what your working with. I've had this combo for many years and just haven't turned the wick up,,,,,,yet This season I will see some new bestestezz
