426 Hemi deck height change #1675557
09/22/14 03:05 AM
09/22/14 03:05 AM
fredericksburg,va
cudaman1969 Offline OP
fredericksburg,va
My block is already decked 1/8 inch, how much more can i take off? Reason being i have some issues on the deck and shaving would clear it up, then i would just add a spacer to get back to stock height. Any thoughts anyone? Its a 1968 block
Re: 426 Hemi deck height change [Re: cudaman1969] #1675558
09/22/14 11:27 AM
09/22/14 11:27 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Wow, bad deal. I guess you could deck to clean up, then use the spacer and double head gaskets. I would probably use head studs if I could since you have less head threads. Unless you are married to this block I would look for another.
2011 Drag Pak Challenger
Re: 426 Hemi deck height change [Re: rickseeman] #1675559
09/22/14 01:58 PM
09/22/14 01:58 PM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
THAT IS NOT AN ISSUE WE SHAVE WAY MORE THAN THAT ON SUPER STOCK BLOCKS
JAKES AUTOMOTIVE
Re: 426 Hemi deck height change [Re: JAKE68] #1675560
09/22/14 02:26 PM
09/22/14 02:26 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
We use to shave .200+ years ago when piston choise was limited.We have saved many of the blocks from those days by using spacers and steel shim head gaskets.If your not going to cut more than .120 you can always get a custom MLS gasket to bring the deck back to spec.
Re: 426 Hemi deck height change [Re: B G Racing] #1675561
09/22/14 09:08 PM
09/22/14 09:08 PM
fredericksburg,va
fredericksburg,va
Thanks for the answers. I'm thinking i need another 1/8 inch. Bob you said steel shim under the spacer, would copper work over and under better? I could cut the copper flush to the spacer, rings are lower so no interferance just don't want any gaps. Should i drill and tap the bolt holes deeper, i'm using studs?
Re: 426 Hemi deck height change [Re: cudaman1969] #1675562
09/23/14 08:24 AM
09/23/14 08:24 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Embossed copper shim gaskets will work,thick smooth copper might not seal well.If you have aprox.1" of thread you should be fine.
Re: 426 Hemi deck height change [Re: cudaman1969] #1675563
09/23/14 11:17 AM
09/23/14 11:17 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The block is already cut .125 and you need to take off another .125 ?
What about welding up the scars ?
Re: 426 Hemi deck height change [Re: JohnRR] #1675564
09/23/14 07:46 PM
09/23/14 07:46 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
Good question... whats wrong with the deck....Have cut as much .220 off iron Hemi decks in the past with no issues.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: 426 Hemi deck height change [Re: W.I.N. Racing] #1675565
09/24/14 09:29 AM
09/24/14 09:29 AM
fredericksburg,va
fredericksburg,va
The issue is not so much the deck but cylinder-deck. I've been trying to think of different ways of fixing the problem without making new problems. Some previous owner went wild with a grinder creating a chamfer for the intake valve that got real close to a push rod hole(all eight) was pondering welding but what can of worms will that open up so milling just enough to take the chamfer out some seems the easiest way. If i had a couple of 3500 hundred dollar bills laying around i could buy a better block then throw all what i got away and start over, so i'm trying to fix what i got, once.
Re: 426 Hemi deck height change [Re: cudaman1969] #1675566
09/24/14 10:36 AM
09/24/14 10:36 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Decks get welded all the time , you should be able to weld most of that chamfer up and then kiss the deck to clean it up.
