426 Hemi deck height change
#1675557
09/22/14 03:05 AM
09/22/14 03:05 AM
Posts: 8,275 fredericksburg,va
cudaman1969
fredericksburg,va
My block is already decked 1/8 inch, how much more can i take off? Reason being i have some issues on the deck and shaving would clear it up, then i would just add a spacer to get back to stock height. Any thoughts anyone? Its a 1968 block
Re: 426 Hemi deck height change
[Re: cudaman1969]
#1675558
09/22/14 11:27 AM
09/22/14 11:27 AM
Posts: 2,652 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
Wow, bad deal. I guess you could deck to clean up, then use the spacer and double head gaskets. I would probably use head studs if I could since you have less head threads. Unless you are married to this block I would look for another.
2011 Drag Pak Challenger
[Re: rickseeman]
#1675559
09/22/14 01:58 PM
09/22/14 01:58 PM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
THAT IS NOT AN ISSUE WE SHAVE WAY MORE THAN THAT ON SUPER STOCK BLOCKS
JAKES AUTOMOTIVE
[Re: cudaman1969]
#1675563
09/23/14 11:17 AM
09/23/14 11:17 AM
Posts: 75,023 U.S.S.A.
JohnRR
U.S.S.A.
Thanks for the answers. I'm thinking i need another 1/8 inch. Bob you said steel shim under the spacer, would copper work over and under better? I could cut the copper flush to the spacer, rings are lower so no interferance just don't want any gaps. Should i drill and tap the bolt holes deeper, i'm using studs?
The block is already cut .125 and you need to take off another .125 ?
What about welding up the scars ?
[Re: JohnRR]
#1675564
09/23/14 07:46 PM
09/23/14 07:46 PM
Posts: 2,113 Byron, NY
W.I.N. Racing
Byron, NY
Good question... whats wrong with the deck....Have cut as much .220 off iron Hemi decks in the past with no issues.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
