'65 Dodge grilles SUCK! #1601835
04/01/14 07:20 PM
04/01/14 07:20 PM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
All the little" teeth" are a pain in the rear to get straight and polished!
This one had quite a few bumps and bruises when I started...
Re: '65 Dodge grilles SUCK! [Re: GY3] #1601836
04/01/14 07:21 PM
04/01/14 07:21 PM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
2.
Re: '65 Dodge grilles SUCK! [Re: GY3] #1601837
04/01/14 07:24 PM
04/01/14 07:24 PM
N.E. OHIO, USA
A12 Online content
A12  Online Content
N.E. OHIO, USA
and you're right they do let a lot of air in for radiator and the intake, definitely SUCKS in a good way
Nice job
Re: '65 Dodge grilles SUCK! [Re: GY3] #1601838
04/01/14 07:28 PM
04/01/14 07:28 PM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
Here is the headlight surround.
It had lots of little dents around the perimeter and some deep scratches on the outside edge.
I've started masking off the black to be painted but wow, what a job.
Starting to think an airbrush might be the way to go?
Re: '65 Dodge grilles SUCK! [Re: GY3] #1601839
04/01/14 09:47 PM
04/01/14 09:47 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Just takes a little time !
Re: '65 Dodge grilles SUCK! [Re: GY3] #1601840
04/01/14 10:31 PM
04/01/14 10:31 PM
Albany, NY
67SATisfaction Offline
The member whose name is actually Art
Albany, NY
I've got a '65 Satellite grille and headlight doors I need to get started on refinishing…. I'm comfortable straightening, sanding, buffing and polishing, but..
…may I ask you to share your method of stripping the anodizing off before you start polishing? I tried oven cleaner and it was... well… less than a success.
Much obliged,
- Art
65 Satellite hardtop 361/4bbl console 727 2.76
67 Satellite convert 383/2bbl column 727 3.23
67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd
67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd
71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd
82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle
75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF
77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF
07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
Re: '65 Dodge grilles SUCK! [Re: 62maxwgn] #1601841
04/02/14 10:19 AM
04/02/14 10:19 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
You should be selling "NOS" parts on ebay.
Nice work!
Re: '65 Dodge grilles SUCK! [Re: Commando1] #1601842
04/02/14 01:20 PM
04/02/14 01:20 PM
Northampton Pa
65 NSS 500 Offline
65 NSS 500  Offline
Northampton Pa
Wow looks good. what paint for the black area are you using? Is it a flat black.. I need to do mine and yours looks good.
1965 Coronet 500 340 40+ Passon 4sp 12.90 2.6 60' street tires
Re: '65 Dodge grilles SUCK! [Re: 67SATisfaction] #1601843
04/02/14 01:30 PM
04/02/14 01:30 PM
Northampton Pa
65 NSS 500 Offline
65 NSS 500  Offline
Northampton Pa
Much obliged,
- Art
I am curious also. Whatever you are doing it looks like it works..Any tips are appreciated..
Re: '65 Dodge grilles SUCK! [Re: 65 NSS 500] #1601844
04/02/14 09:14 PM
04/02/14 09:14 PM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
Heavy Duty Easy Off.
Make sure it's warm when you do it.
The fume free doesn't work.
How did you paint yours, maxwagon? I did my 63 330 grille paint but the headlight surrounds on the 65 are much more complicated to mask...
Re: '65 Dodge grilles SUCK! [Re: GY3] #1601845
04/02/14 10:48 PM
04/02/14 10:48 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
sodium hydroxide...Lye...is what you want to strip the anodizing..Most local hardware stores carry the chrystalized stuff in a plastic bottle used for a heavy duty drain cleaner/opener...I made up a throw-away container out of a cardboard box and some heavy plastic...Big enough to do the 65 dodge grille and some trim...
I taped off the headlight bezels with "fine line" plastic tape for the striped areas... Worked great... I'll get some pics of the finished product and post them later...
Re: '65 Dodge grilles SUCK! [Re: screamindriver] #1601846
04/04/14 11:27 AM
04/04/14 11:27 AM
Albany, NY
Albany, NY
Thanks for the anodizer-removal info!
- Art
Re: '65 Dodge grilles SUCK! [Re: 67SATisfaction] #1601847
04/04/14 04:38 PM
04/04/14 04:38 PM
Northampton Pa
65 NSS 500 Offline
65 NSS 500  Offline
Northampton Pa
So after removing the anodizing you don't have to do any treatment or anything.. Just polish and keep up with it. Anodizing was just to protect the aluminum . I appreciate the help just don't want to screw up my trim if I do this.
Re: '65 Dodge grilles SUCK! [Re: 65 NSS 500] #1601848
04/04/14 09:10 PM
04/04/14 09:10 PM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
The grille in my '63 330 has been done for 5+ years and still looks good.
It is garaged 99% of the time, though.
If the car is going to sit out in the weather you could always have it re-anodized.
Re: '65 Dodge grilles SUCK! [Re: GY3] #1601849
04/07/14 10:29 PM
04/07/14 10:29 PM
Harrisburg, Pa.
Harrisburg, Pa.
Here's the pics I took today... Cars been sitting in the booth so I opened the doors and snapped a few...
Re: '65 Dodge grilles SUCK! [Re: screamindriver] #1601850
04/07/14 10:32 PM
04/07/14 10:32 PM
Harrisburg, Pa.
Harrisburg, Pa.
Here's a close-up of the headlight bezel...Polished out and taped off with fineline tape...Lots of masking with the 65 grille...
Re: '65 Dodge grilles SUCK! [Re: screamindriver] #1601851
04/07/14 10:35 PM
04/07/14 10:35 PM
Harrisburg, Pa.
Harrisburg, Pa.
Last one...A side shot...As stated the aluminum trim seems to hold up very well without the annodizing on it... I've done quite a few and all the trim needs is a little TLC from time to time... On a side note I ended up with rechromed front and rear bumpers on this one...Got the B/E&A trunk medallion...Beautiful piece of craftsmanship from Mike and it really made the back end..
