Re: '65 Dodge grilles SUCK!
[Re: GY3]
#1601836
04/01/14 07:21 PM
04/01/14 07:21 PM
Posts: 4,684 Wichita
GY3
Wichita
[Re: GY3]
#1601837
04/01/14 07:24 PM
04/01/14 07:24 PM
Posts: 21,523 N.E. OHIO, USA
A12
N.E. OHIO, USA
All the little" teeth" are a pain in the rear to get straight and polished!
This one had quite a few bumps and bruises when I started...
and you're right they do let a lot of air in for radiator and the intake, definitely SUCKS in a good way
Nice job
[Re: GY3]
#1601838
04/01/14 07:28 PM
04/01/14 07:28 PM
GY3
Wichita
Here is the headlight surround. It had lots of little dents around the perimeter and some deep scratches on the outside edge. I've started masking off the black to be painted but wow, what a job. Starting to think an airbrush might be the way to go?
[Re: GY3]
#1601840
04/01/14 10:31 PM
04/01/14 10:31 PM
Posts: 7,541 Albany, NY
67SATisfaction
The member whose name is actually Art
Albany, NY
I've got a '65 Satellite grille and headlight doors I need to get started on refinishing…. I'm comfortable straightening, sanding, buffing and polishing, but..
…may I ask you to share your method of stripping the anodizing off before you start polishing? I tried oven cleaner and it was... well… less than a success.
Much obliged, - Art
65 Satellite hardtop 361/4bbl console 727 2.76 67 Satellite convert 383/2bbl column 727 3.23 67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd 67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd 71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd 82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle 75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF 77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF 07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
[Re: Commando1]
#1601842
04/02/14 01:20 PM
04/02/14 01:20 PM
Posts: 505 Northampton Pa
65 NSS 500
Northampton Pa
Wow looks good. what paint for the black area are you using? Is it a flat black.. I need to do mine and yours looks good.
1965 Coronet 500
340 40+ Passon 4sp
12.90 2.6 60' street tires
[Re: 67SATisfaction]
#1601847
04/04/14 04:38 PM
04/04/14 04:38 PM
65 NSS 500
Northampton Pa
So after removing the anodizing you don't have to do any treatment or anything.. Just polish and keep up with it. Anodizing was just to protect the aluminum . I appreciate the help just don't want to screw up my trim if I do this.
1965 Coronet 500
340 40+ Passon 4sp
[Re: 65 NSS 500]
#1601848
04/04/14 09:10 PM
04/04/14 09:10 PM
GY3
Wichita
The grille in my '63 330 has been done for 5+ years and still looks good.
It is garaged 99% of the time, though.
If the car is going to sit out in the weather you could always have it re-anodized.
