Page 2 of 3 1 2 3
Re: aluminum block on the street? [Re: an8sec70cuda] #1543821
12/05/13 01:07 PM
12/05/13 01:07 PM
fullmetaljacket Offline
Thank you 9-70
That there at least gives an incentive to some that have the capital and patience to build such a motor.
Those KB's are pricey, but they do have a much better reputation then most others. If I were to go AL, I'd save my dollars and go KB, but iron will have to be the hamster for now.
BEST in Detroit was my builder and I have seen a few Aluminum projects on the operation table there.
Re: aluminum block on the street? [Re: fullmetaljacket] #1543822
12/05/13 01:18 PM
12/05/13 01:18 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Are these a thing of the past? and (putting current factory OE blocks aside) why have so few builders achieved a good natured Aluminum block on the street?
I believe you dont see many alum blocks on the street
is that they dont need it.. they arent making the big
power or that they dont want to spend the money on
the alum block... if its a street car and the standard
block will work WHY pay the price
Re: aluminum block on the street? [Re: MR_P_BODY] #1543823
12/05/13 01:24 PM
12/05/13 01:24 PM
dogdays Offline
dogdays  Offline
Because it allows one to take weight off the front end, most Mopar big block musclecars were pretty front-heavy, and use a bigger engine.
Think of it this way: You only pay for the aluminum block once, but you reap the benefits every time you drive it.
R.
Re: aluminum block on the street? [Re: dogdays] #1543824
12/05/13 01:36 PM
12/05/13 01:36 PM
MR_P_BODY Offline
MR_P_BODY  Offline
R.
I understand the weight issue but MOST street car guys
dont care that much... and most dont string out the
revs to worry about busting the engine... hell, most
are very happy with a stroker kit
Re: aluminum block on the street? [Re: MR_P_BODY] #1543825
12/05/13 01:41 PM
12/05/13 01:41 PM
If it were me and I was starting anew, I'd build an aluminum block for the weight savings right where it counts most. Less power to push a lightweight down stream is a more reliable package I believe.
Though iron holds the heat better and a certain amount of heat is HP.
Sometimes the cost of something even if it is pricey might out weigh the cost of headaches and sweaty stressful labor down the road and track.
P-body, correct me if I'm wrong, but I suspect that your car there does not need much HP to get steaming because of its overall weight. Smart package.
Some cars just don't have the lean to be mean, so your car is performing the opposite of a heavy engine package.
I'm a street car guy and maybe a fanatic at this issue, but if I were in the position where Aluminum blocks were as reliable as they seem nowadays, I'd save my pennies and go Alcoa in a NY minute.
Re: aluminum block on the street? [Re: fullmetaljacket] #1543826
12/05/13 02:08 PM
12/05/13 02:08 PM
organ
maximum entropy Offline OP
organ
thanks for all the input, guys. i would do it for all the above reasons- my stock block is probably close to the limit as far as reliability is concerned. i wouldn't have to worry about that anymore, and i could (and probably will) hang a pro charger or some kinda hair dryer on it without a second thought. or spray it. and knock 100 pounds off the nose. my stock block is the only thing i worry about when wringing it's neck, and i'm gonna do something about it. the thought of spending thousands of dollars to add weight to the nose of the car (aftermarket iron block) is unappealing to me. may as well spend a little more and add lightness at the same time...
Re: aluminum block on the street? [Re: fullmetaljacket] #1543827
12/05/13 02:30 PM
12/05/13 02:30 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Your correct... both of my cars are on the light side..
the P-Body is much lighter than than my Rampage but
neither of them need big HP to be quick... but both
of them have iron blocks.. I sold my alum SB block
some years back... but I have made the chassis light
to help cover the weight issue... yes if you were
starting from scratch then it might help but I need
the front weight in the race car because of the weight
bias in it now... its 48/52 with me in it
Re: aluminum block on the street? [Re: maximum entropy] #1543828
12/05/13 02:35 PM
12/05/13 02:35 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Well thats the thing... if you are at the limits of
the block AND you plan on replacing it then yes I
would go alum VS a iron one
Re: aluminum block on the street? [Re: maximum entropy] #1543829
12/05/13 02:57 PM
12/05/13 02:57 PM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
I went with the aluminum and it is about 150 lbs lighter than the iron block . (137 lbs. advertised)
Like you said, it was a dream of mine to have/build this engine. I have not been on long distance drives with it yet, just around town a bit, and I am very happy with the results.
I had an issue with the head gaskets, (World Block takes different ones) and after that was fixed, it has been all good. I would do it again.
Mark
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: aluminum block on the street? [Re: Moneypit6] #1543830
12/05/13 03:08 PM
12/05/13 03:08 PM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
Do you know what the newest KB blocks are? Wet or dry? I've been trying to justify doing this myself for the weight savings. It's a pretty expensive 60 lb or so savings!
Mine weighed about 140#. An iron block capable of 4.500 probably weighs 300#.
Even a stock piece of crap 440 block weighs 100+ more than a KB and isn't a 3rd the strength, or repairable.
Put a price on driving over your crankshaft at 160+mph.
Re: aluminum block on the street? [Re: Hemi Allstate] #1543831
12/05/13 03:16 PM
12/05/13 03:16 PM
The question coming here is, Who is reliable enough to build an aluminum engine that will be nice and make flight.
It sounds like Performance only has a good rep and as far as closer to the North East coast, I would bet on both BEST in Detroit and BGR in PA.
By the sound of these things, it's like getting the right Doctor for the right treatment is at play. Some iron block builders may know their stuff, but not every nook and cranny on the alloy blocks to stay civil.
Re: aluminum block on the street? [Re: fullmetaljacket] #1543832
12/05/13 03:18 PM
12/05/13 03:18 PM
an8sec70cuda Offline
I went w/ the aluminum block mainly b/c a good iron block wasn't available at the time. The World blocks weren't out yet and I wasn't gonna take a chance on a mega block (if I could find one for sale) that was gonna need a bunch of machine work to be useable.
Also, I'd rather have 5 grand in a block that's repairable instead of having 4 grand or more in an iron block that becomes a boat anchor if you grenade it.
I have a cast iron 4.5" bore World Hemi block on my engine stand right now...talk about a HUGE weight difference b/t it and my KB block!!! That bare World iron block feels as heavy as a complete 440 shortblock.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: aluminum block on the street? [Re: an8sec70cuda] #1543833
12/05/13 03:26 PM
12/05/13 03:26 PM
Let it be said, let it be done. Some day I'll be full aluminum.
I guess I'll then have to change to FULLALUMINUMJACKET. LOL
Re: aluminum block on the street? [Re: fullmetaljacket] #1543834
12/05/13 04:21 PM
12/05/13 04:21 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
Aluminum block here.
Mopar Performance
Re: aluminum block on the street? [Re: an8sec70cuda] #1543835
12/05/13 04:39 PM
12/05/13 04:39 PM
so 6-70. I presume you are running a dry sleeve aluminum Hemi block?
I only ask, because it seems that Keith Black does not produce dry sleeve aluminum 440 blocks with all the features of their new Hemi block. I love the double cross bolted features and extra thick sleeves.
When time and budget allows, I would much rather build an aluminum Wedge before a Hemi. It's just that my car now is set up for a Wedge exclusively.
Re: aluminum block on the street? [Re: fullmetaljacket] #1543836
12/05/13 04:52 PM
12/05/13 04:52 PM
Yes, it has dry sleeves. I believe all of their blocks are dry sleeve now.
CHIP
Re: aluminum block on the street? [Re: an8sec70cuda] #1543837
12/05/13 05:11 PM
12/05/13 05:11 PM
Cab_Burge Online work
Cab_Burge  Online Work
I would call KB,562-869-1518 and see if they still make both wet and dry sleeves, as far as I know all the street aluminum Hemi blocks where dry sleevess The race blocks have removeable wet sleeves
Re: aluminum block on the street? [Re: an8sec70cuda] #1543838
12/05/13 05:26 PM
12/05/13 05:26 PM
Roger that.
Thank you.
I just got a quick response answer from Ken at KB indicating that yes, their new blocks both Hemi/440 are indeed dry sleeve. The only drawback in my configuration is that all the blocks are machined for an external oil pick up and my stock location oil pick up is already stretched to its limits because of its placement and how the engine nestles in the cradle. I don't want to be the hand that rocks the cradle at this point in time.
Anyway, good to know before hand.
60-100 pounds shaved off is juicy fruit to nibble on though.
Re: aluminum block on the street? [Re: fullmetaljacket] #1543839
12/05/13 06:31 PM
12/05/13 06:31 PM
California
mickm Offline
mickm  Offline
California
so what are the advantages/disadvantages to aluminum blocks other than weight. and the cool factor?
Re: aluminum block on the street? [Re: fullmetaljacket] #1543840
12/05/13 06:52 PM
12/05/13 06:52 PM
Newfoundland,Canada
avenger572 Offline
avenger572  Offline
Newfoundland,Canada
Kb block in mine now 10 years,broke a rod 3 years ago had to put a couple of sleeves and some welding. After putting about 400 passes on it sense with no issues . Some street use aswell just needs a good cooling system .
Page 2 of 3 1 2 3
