BB oil pan removal in car? #1452137
06/13/13 10:10 AM
06/13/13 10:10 AM
Spring Mount, PA
MOPAULY Offline OP
MOPAULY  Offline OP
Spring Mount, PA
Can you replace a stock 383 oil pan in place? it *looks* like there is enough clearance to do it, but looks can be deceiving. I have a pinhole leak in the pan and am just going to replace the whole thing.
Re: BB oil pan removal in car? [Re: MOPAULY] #1452138
06/13/13 10:38 AM
06/13/13 10:38 AM
The Garden State
LimelightCuda Offline
The Garden State
My car has a 440 and the oil pan was leaking. I was able to remove the pan while the engine was in the car to replace the gasket. If I remember correctly I think I had to raise the engine up a little to get enough clearance to remove the pan.
I found that my pan was bent and I straightened it out as best as I could. It still leaks slightly but it is much, much better than before.
Anyway, my car is an E-Body. You didn't mention what body type of car you have. I've never done this job on a B or A body. Good luck.
Phil
1970 Barracuda Gran Coupe
1970 A66 Challenger Convertible
Re: BB oil pan removal in car? [Re: MOPAULY] #1452139
06/13/13 11:18 AM
06/13/13 11:18 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Yes you can do it , you need to disconnect the centerlink and swing it out of the way.
Re: BB oil pan removal in car? [Re: JohnRR] #1452140
06/13/13 01:54 PM
06/13/13 01:54 PM
The Garden State
The Garden State
John is correct. I did take out the center link when I did mine which was last year.
Phil
Re: BB oil pan removal in car? [Re: JohnRR] #1452141
06/13/13 02:39 PM
06/13/13 02:39 PM
Western Washington
Sixgun Offline
Sixgun  Offline
Western Washington
Been there, done that.Works.
I'm 55 now, no time to waste. Not a week goes by that I don't hear about someone passing on.Let's get out there,smoke some tires,have a beer with a good friend,do what you have always wanted to do.I am pretty sure no one will ever say on their deathbed "gee I'm glad my life was calm and boring"
Re: BB oil pan removal in car? [Re: JohnRR] #1452142
06/13/13 02:52 PM
06/13/13 02:52 PM
Spring Mount, PA
MOPAULY Offline OP
MOPAULY  Offline OP
Spring Mount, PA
I was wondering if I would need to do that, makes sense. car is a 68 B body.
Re: BB oil pan removal in car? [Re: JohnRR] #1452143
06/13/13 02:54 PM
06/13/13 02:54 PM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
Re: BB oil pan removal in car? [Re: MOPAULY] #1452144
06/13/13 03:16 PM
06/13/13 03:16 PM
Cab_Burge Online work
Cab_Burge  Online Work
You will need a 1/2 inch box end wrench with a slight step, offset, on the front four bolts, maybe the front six bolts, been to long since doing one in a 1966-70 BB B body
Re: BB oil pan removal in car? [Re: Cab_Burge] #1452145
06/13/13 04:41 PM
06/13/13 04:41 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
I changed one a few years ago. I think with a floor jack it can be done pretty easily. I don't recall taking the c link out. I remember a few bolt s being hard to get at without raising it up and/or using shallow sockets.
I want my fair share
Re: BB oil pan removal in car? [Re: SomeCarGuy] #1452146
06/13/13 05:18 PM
06/13/13 05:18 PM
JohnRR Offline
JohnRR  Offline
Your memory isn't as good as it used to be then ... The centerlink is behind the sump and under the rear of the pan , the only way you pulled the pan without pulling the centerlink was you either pulled the K frame or the engine was half way out of the engine compartment ...
Re: BB oil pan removal in car? [Re: JohnRR] #1452147
06/13/13 09:35 PM
06/13/13 09:35 PM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
Re: BB oil pan removal in car? [Re: terzmo] #1452148
06/13/13 10:51 PM
06/13/13 10:51 PM
IN
ahy Offline
ahy  Offline
IN
Another thought. If the pan is OK except for the pinhole, epoxy repair will work. Drain oil, de-grease around the leak, sand the paint off around the leak and de-grease really well again then lay some JB weld on. You can smooth it off a bit when hard and touch up the paint.
Re: BB oil pan removal in car? [Re: ahy] #1452149
06/13/13 11:07 PM
06/13/13 11:07 PM
S.I. N.Y.
1MYTGTX Offline
1MYTGTX  Offline
S.I. N.Y.
Like others said it can be done. Its worse if you are running a windage tray..... PITA to get it to line up right & not screw up the gaskets
1MYTGTX
Re: BB oil pan removal in car? [Re: ahy] #1452150
06/14/13 05:28 PM
06/14/13 05:28 PM
Spring Mount, PA
MOPAULY Offline OP
MOPAULY  Offline OP
Spring Mount, PA
That, sir, is exactly what I am doing tomorrow morning so I can further tune the car this weekend. I did order a new pan from Summit, as the more I thought about it the more I was concerned that I even had a pinhole at all...but for the short term it will be a good fix.
Re: BB oil pan removal in car? [Re: Cab_Burge] #1452151
06/14/13 06:34 PM
06/14/13 06:34 PM
Albany, NY
67SATisfaction Offline
The member whose name is actually Art
Albany, NY
...and one of the four front bolts will slip from your fingers, drop somewhere in the k-frame, never to be found... DAMHIK!! @#^%$*&&!!
The front four were the most difficult, so just take your time.
- Art
65 Satellite hardtop 361/4bbl console 727 2.76
67 Satellite convert 383/2bbl column 727 3.23
67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd
67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd
71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd
82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle
75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF
77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF
07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
