Re: BB oil pan removal in car?
[Re: MOPAULY]
#1452138
06/13/13 10:38 AM
06/13/13 10:38 AM
Posts: 357 The Garden State
LimelightCuda
The Garden State
My car has a 440 and the oil pan was leaking. I was able to remove the pan while the engine was in the car to replace the gasket. If I remember correctly I think I had to raise the engine up a little to get enough clearance to remove the pan.
I found that my pan was bent and I straightened it out as best as I could. It still leaks slightly but it is much, much better than before.
Anyway, my car is an E-Body. You didn't mention what body type of car you have. I've never done this job on a B or A body. Good luck.
Phil
1970 Barracuda Gran Coupe 1970 A66 Challenger Convertible
[Re: JohnRR]
#1452140
06/13/13 01:54 PM
06/13/13 01:54 PM
LimelightCuda
The Garden State
John is correct. I did take out the center link when I did mine which was last year.
Phil
[Re: JohnRR]
#1452143
06/13/13 02:54 PM
06/13/13 02:54 PM
Posts: 2,060 Pendleton NY
terzmo
Pendleton NY
Yes you can do it , you need to disconnect the centerlink and swing it out of the way.
[Re: MOPAULY]
#1452144
06/13/13 03:16 PM
06/13/13 03:16 PM
Posts: 43,315 Bend,OR USA
Cab_Burge
I was wondering if I would need to do that, makes sense. car is a 68 B body.
You will need a 1/2 inch box end wrench with a slight step, offset, on the front four bolts, maybe the front six bolts, been to long since doing one in a 1966-70 BB B body
[Re: Cab_Burge]
#1452145
06/13/13 04:41 PM
06/13/13 04:41 PM
Posts: 10,234 Someplace you aren't
SomeCarGuy
I changed one a few years ago. I think with a floor jack it can be done pretty easily. I don't recall taking the c link out. I remember a few bolt s being hard to get at without raising it up and/or using shallow sockets.
I want my fair share
[Re: SomeCarGuy]
#1452146
06/13/13 05:18 PM
06/13/13 05:18 PM
Posts: 75,098 A Banana Republic near you.
JohnRR
Your memory isn't as good as it used to be then ... The centerlink is behind the sump and under the rear of the pan , the only way you pulled the pan without pulling the centerlink was you either pulled the K frame or the engine was half way out of the engine compartment ...
[Re: JohnRR]
#1452147
06/13/13 09:35 PM
06/13/13 09:35 PM
terzmo
Pendleton NY
[Re: ahy]
#1452149
06/13/13 11:07 PM
06/13/13 11:07 PM
Posts: 3,967 S.I. N.Y.
1MYTGTX
S.I. N.Y.
Like others said it can be done. Its worse if you are running a windage tray..... PITA to get it to line up right & not screw up the gaskets
1MYTGTX
[Re: ahy]
#1452150
06/14/13 05:28 PM
06/14/13 05:28 PM
Posts: 7,843 Spring Mount, PA
MOPAULY
Spring Mount, PA
Another thought. If the pan is OK except for the pinhole, epoxy repair will work. Drain oil, de-grease around the leak, sand the paint off around the leak and de-grease really well again then lay some JB weld on. You can smooth it off a bit when hard and touch up the paint.
That, sir, is exactly what I am doing tomorrow morning so I can further tune the car this weekend. I did order a new pan from Summit, as the more I thought about it the more I was concerned that I even had a pinhole at all...but for the short term it will be a good fix.
[Re: Cab_Burge]
#1452151
06/14/13 06:34 PM
06/14/13 06:34 PM
Posts: 7,545 Albany, NY
67SATisfaction
The member whose name is actually Art
Albany, NY
...and one of the four front bolts will slip from your fingers, drop somewhere in the k-frame, never to be found... DAMHIK!! @#^%$*&&!!
The front four were the most difficult, so just take your time. - Art
65 Satellite hardtop 361/4bbl console 727 2.76 67 Satellite convert 383/2bbl column 727 3.23 67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd 67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd 71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd 82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle 75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF 77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF 07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
