Re: Broke the trans again [Re: fourgearsavoy] #1437815
05/17/13 10:46 PM
05/17/13 10:46 PM
Great Neck,LI,new york
hemi-itis Offline OP
Maybe it's time for a change
Ya know,,,,,there is still a clutch pedal in the car
But I like pushing buttons
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Broke the trans again [Re: hemi-itis] #1437816
05/17/13 11:04 PM
05/17/13 11:04 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
I have that lightweight plutonium/unobtainium shifter material that was scientificly balanced.
I should be in the Keys for that race
ALL 'dat trick material isn't going to help you there ....
And WITCH race 'itis ? .... there are THREE RACES in 'da Keys ... two in KW and one in Marathon ....
...and next year Sarasota will have TWO races ....
Re: Broke the trans again [Re: dOc !] #1437817
05/18/13 01:46 AM
05/18/13 01:46 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Its funny all the talk about switching to GM transmissions in cars and all the really fast Duramax diesel guys talk about switching to Dodge transmissions in their drag trucks.
Mopar to the bone!!!
Re: Broke the trans again [Re: dOc !] #1437818
05/18/13 12:13 PM
05/18/13 12:13 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
'itis ... it is that heavy shifter and all those gauges that is weighing-the-car-down and putting strain on the drivetrain ...
Re: Broke the trans again [Re: hemi-itis] #1437819
05/18/13 03:56 PM
05/18/13 03:56 PM
fullmetaljacket Offline
CRT, A&A and finally go over to Curt here in Brooklyn and give the Maestro a try. He should make that thing wail and leave no parts trail.
Re: Broke the trans again [Re: fullmetaljacket] #1437820
05/18/13 06:51 PM
05/18/13 06:51 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
If your going to stay with the 727, id talk to COPE,
Saying you would never put a t400 in there.....You just don't realize what parts are available and whats really better to handle the power.
I talked to Cope and Rossler when I had enough of broken trans and parts...Cheaper in the long run to put a GOOD unit in there that will handle all that you can put in front of it
....BAD A$$ STREET CAR.....
Re: Broke the trans again [Re: n20mstr] #1437821
05/18/13 07:33 PM
05/18/13 07:33 PM
off the grid
340B5 Offline
340B5  Offline
off the grid
A Rossler would probably slow you down but wouldn't stop you.
Glad the damage was minimal. Could have gotten UGLY
Yeah, it's got a smallblock.
Re: Broke the trans again [Re: hemi-itis] #1437822
05/19/13 04:37 AM
05/19/13 04:37 AM
Norrland, Sweden
Swedcharger67 Offline
Norrland, Sweden
Could an alignment problem with the crankshaft contribute to the failure?
I'm right now installing a stiff, SFI-approved flexplete and I guess this will put higher requirements on the alignment of the input shaft with the crankshaft?
Martin, 67 Charger, 512 cui, E85, MegaSquirt MS3X sequential ignition & injection
Re: Broke the trans again [Re: Swedcharger67] #1437823
05/19/13 11:37 AM
05/19/13 11:37 AM
That "stock" retainer hub seems to be alright till about 700 ft lbs.The new stuff is good to well over 2000 ft lbs.The only thing left is the stock output shaft which will stay on my bucket list.I had to tap into my data logger fund to buy theses parts
Re: Broke the trans again [Re: hemi-itis] #1437824
05/19/13 11:50 PM
05/19/13 11:50 PM
Ma
Voluster Offline
Voluster  Offline
Ma
I broke one of those in the burnout box
Re: Broke the trans again [Re: hemi-itis] #1437825
05/19/13 11:54 PM
05/19/13 11:54 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
AREN'T YOU about 2200 pounds with all those gauges and HEFTY shifter ?.....
Re: Broke the trans again [Re: dOc !] #1437826
05/20/13 12:13 AM
05/20/13 12:13 AM
2200 lbs would make me about a second and a 1/2 faster
