Broke the trans again
#1437795
05/16/13 11:53 PM
05/16/13 11:53 PM
Posts: 12,589 Great Neck,LI,new york
hemi-itis
Went for a ride Tuesday night and had the chance to try WOT on a nice 2 lane concrete highway.At the top of 2nd just when I clicked high gear I heard and felt a major BOOM under my feet .Clicked the key off and watched out the rearview mirror expecting see all kinda parts trailing me.Rolled to the side of the road and looked under the car to see everything in place and nothing leaking so I restarted the engine and went through the gears,but nothing happened After I got a ride to get my flatbed,towed it back to my shop,put it up on jackstands and pulled the pan to find NOTHING but clean fluid Pulled the unit out last night and called it a day.Went and pulled the trans apart today and found a broken retainer hub on the back of the input shaft. I see a new heavy duty maybe billit replacement in my future. Who should I get a new one from?TCS,Cope,,,,,or???
Re: Broke the trans again
[Re: hemi-itis]
#1437797
05/17/13 12:58 AM
05/17/13 12:58 AM
Posts: 4,302 Nebraska
72Swinger
Nebraska
TCS sells some nice input shafts that are bigger diameter at the hub end.
Mopar to the bone!!!
[Re: hemi-itis]
#1437803
05/17/13 03:02 PM
05/17/13 03:02 PM
Posts: 1,855 Staten Island N.Y.
Dap
Staten Island N.Y.
When I had mine apart the last time I found six cracks in mine. Time for an upgrade while you are there.
PRH446 10.084 @ 135.21 mph N/A through chambered mufflers,3300lbs. Stock stroke wedge
[Re: 540dust]
#1437808
05/17/13 10:16 PM
05/17/13 10:16 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
I have never had enough power to do the damage I am seeing here. I have broken extension housings and blown the servos out of the case due to bad or badly installed snap rings. It seems to me you might be wise to invest in either a PG or a TH400 with an Ultrabell. There has to be a point where it just makes sense to change, but I don't know where that is.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: hemi-itis]
#1437813
05/17/13 10:29 PM
05/17/13 10:29 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Thats been cracked for a while... shouldnt blow that going into high(less torque at that point) plus it has some shine and smooth edges.... JMO
